Question about Toshiba TP50H50 50" Rear Projection Television
My TP50H50 is turning on for a short time and goes off. Power light continues flashing. remote control or power button will not stop it from flashing. I have to unplug the tv and wait a minute or longer before it will come back on. most of the time now when I plug it back in you can hear a couple of clicks and the power light goes back to flashing, no picture. Every once in a while it will come on and stay on, but not very often. I removed the front panel and cleaned out dust. This seemed to help for a short time only. Is this fixable or should I look for a new TV. The picture on this one is great when it runs.
  • 3 more comments
  • Mike H Jan 01, 2011
    Since I am somewhat a novice, I have been in the back of this tv, and there are many boards. If you could point me in the right direction of the power board I am sure I can figure it out from there.....Thanks
    Is it possible for the tv to still work even with a dead power board?
    Can the power board be intermitent? If not, would you have another solution for the issue that I have explained above?
    Great explanation, thanks. I have looked at all the capacitors on and around the power supply board, and they look normal, no bulging that I could see. Is there another possible solution? By the way I put the tv back together and after a few tries with unplugging and plugging in the power,and the relay clicking in and out the tv is staying on for now.
    Great explanation thanks. I have looked at the capacitors on and around the power supply board and they all appear normal to me, no bulging is evident. Could there be another possible solution? By the way, I put the tv back together and after several tries with plugging and unplugging power cord and listening to the relay click in and out the tv is now staying on.
  • Toshiba Master
  • 6,993 Answers
you can get to the power board by tracing the AC wire right into the TV. AC wire is the wire that is plugged into the wall for electricity. Just trace this wire to the TV. The wire goes straight into the power board.
Once you are able to get to the spot where the wire passes into the TV, then you have gotten to the power board.
Good luck.
Posted on Jan 01, 2011
  • 1 more comment
  • Walesarumi
    Walesarumi Jan 01, 2011
    No, its not possible. The TV can never work with a bad power board.
  • Walesarumi
    The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
    The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
    I do not think it needs replacement, rather some defective capacitors are causing this issue.
    Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
    The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
    You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
    What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
    You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
    After replacing these capacitor(capacitors) most likely the normal operation will be restored.
    Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
    If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
    I hope this helps.
  • Walesarumi
    that's one funny thing about TV. Some times while tempering with it, it can just peak up and start working. This might have something to do with the line transformer.
    If the TV refuses to power on again, clean out all the components on the TV panel and power board with a paint brush.
    Maybe there is nothing pretty much wrong with the TV, it might just need servicing.
    Good luck again.
    Genius:
  • 1,622 Answers
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem....
Panasonic air con - when you turn the air con on it runs for about 3 mins and then the timer light flashes. Air con will not work.
• Once abnormality has occurred during operation, the unit
will stop its operation, and Timer LEDs blink.
• Although Timer LED goes off when power supply is turned
off, if the unit is operated under a breakdown condition, the
LED will light up again.
• In operation after breakdown repair, the Timer LED will no
more blink. The last error code (abnormality) will be stored in
IC memory.
• To make a diagnosis:
1. Timer LED start to blink and the unit automatically
stops the operation.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by
pressing the CHECK button continuously for 5 sec-
onds or without any operation the remote control for
30 seconds.
8. The LED will be off if the unit is turned off or the
RESET button on the main unit is pressed.
When you have the error code, we can work out what to do next.
Mar 27, 2015 | Panasonic Heating & Cooling
FUJITSU Indoor Inverter ASTA09LCC/ASTA12LCC airconditioning - not cooling
If the operation button is flashing 8 times, the timer light should also flash 4 times in each sequence. This indicates a failure of the PFC circuit in the outdoor unit which basically means a faulty outdoor board and will have to be replaced.
If the operation light is flashing 8 times by itself, the indoor controller board may have a fault. You can normally test this by putting the mode on the remote to 'Fan' and checking that the controls otherwise work normally - louvers work as directed and fan speed changes correctly when selected on the remote.
Most likely the fault lies in the outdoor board but you should contact a tech to diagnose correctly.
Sep 24, 2017 | Fujitsu 18C1 Air Conditioner
I want to program my dish network remote to my tv not my box
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the TV Mode button on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Jun 27, 2010 | Orion 076D0FH020 Remote Control
I have dish network and a new rca tv with dvd the
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Mar 11, 2010 | DISH Network 322 DTV Receiver
Looking for dish network codes for the Philips SRU3003 remote...
Jan 01, 2010 | Philips SRU3003 Remote Control
Hi i'm having problems programing my universal control
Make sure the device is on. Hold down the tv (or whichever device your trying to program) button and the power button simultaneously until the red light stays on solid. Then press the power button, it will flash one time, and keep pressing slowly letting it flash until the device turns off (mine took like 27 times, could be up to 100). Then press the stop button...and it is programmed.
Jan 03, 2009 | RCA Universal Remote 3 Device Remote...
Dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
Dec 31, 2008 | Disney 13" TV
Timer light is flashing but tv wont turn on!
When the timer light stoped flashing the remote control would not turn on the TV. The next time the light quit flashing I held the power button in on the TV for about 5 seconds and it came on and has had no problems since then with the remote or the local TV power button.
Greg Allen
Aug 29, 2008 | Mitsubishi Televison & Video
Cannot turn tv on!
hello, you do have a horrizontal problem, you may have a short parts on the said section, shorted horrizontal output transistor can couse this indicator to blink. when a shorted transistor then you may have a defective FBT. try to check some parts. ty
Dec 21, 2007 | Sony FD Trinitron WEGA KV-36FS320 36" TV
Remote control code
Dish Netork does not have the code for Olevia
but you can scan for the code using the infformation
here
Remote Code Power Scan
If your brand is not listed, use the following procedure to scan through all codes.
If you start the and do not press a button within 20 seconds, the remote will end the scan automatically.
1. Turn ON the unit you want to program the remote to control.
2. Press the Mode button on the remote until the appropriate mode light is flashes
3. Press the Address button. The mode light will start flashing slowly.
4. Press the Power button. The mode light will stop flashing and stay lit.
5. Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
6. When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
7. Press the Address button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
8. Turn the device back ON by pressing the Power button.
9. Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
10. If the other buttons work, follow the current settings procedure below to determine the current remote settings.
11. If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
12. The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Nov 23, 2007 | Olevia LT32HVM 32 in. LCD Television
Toshiba TP50H50 50" Rear Projection Television Logo
50 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
