Question about Jabra BT350 Wireless Headset
Headset will not charge. Lights to indicate charging flash red then blue for 1 second and then no LED indicators are on.
SOURCE: Unit won't charge and I get no lights
I have the same problem. it's due to a faulty pover-cell inside the headset. i have also read that the charger can be inserted the wrong way, this would in turn kill the battery by giving it a reverse charge.(not sure about that) as i tried this after finding the unit defective and it will only plug in one way.. the only suggestion that i can give is contact Jabra directly. iv'e read that they will replace any headset in this range for free, here is the address for their site. http://www.jabra.com/Sites/Jabra/UK-UK/pages/Contact.aspx Hope this helps.
Posted on Sep 20, 2007
SOURCE: BT500V won't charge
Check the date on the side of the box if it is one just purchaced. I had the same problem both new. the date on my box said 20/07 indicting it is 1 year old and sat on the shelf for that time.
Like any battery it will die .
If you just bought it and have the sale docket contact the Jabra Support number in your country they may repalcer it with a 2008 model.
Hope this helps
Posted on Feb 08, 2008
SOURCE: Jabra BT500 won't turn on or indicate charging
Hello all...
I had this exact same problem, and had a couple hours on my hands to kill, so I opened up my headset. ***PLEASE NOTE - This WILL void your warranty*** Once the headset was open, I took a quick look around, and noticed that one of the leads that attach the rechargable battery to the little circuit board was not connected. Being somewhat handy, I was able to use my soldering iron to re-attach the lead from the battery to the PCB. I plugged the unit into the charger to verify, then carefully put everything back together. A little dab of superglue in the joint above the volume controls, and my headset now works great! Be careful when putting the unit back together, as the first time I re-assembled it, the lead came off, and I had to take it all apart and re-solder it. The circuit board will move out of the way slightly (pulls away from the case) in order to give a better angle to solder the lead. It does not fully detach though, so be careful. In total, it took about 30 minutes of my time, which is way cheaper than a new headset =)
Tim
Posted on May 19, 2008
SOURCE: Jabra BT350 Bluetooth Headset
This is what I did:
1. open the headset by following these steps:
http://www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair/
2. measure the voltage of the battery. If it is too low, the internal charger circuit may not like it. Mine was 2.6v.
3. Charge the battery "manually" by connecting to 3 serially connected rechargeable batteries (final voltage should be around 3.7v). Three NiMH AA batteries are fine.
4. Reassemble and hope your headset is back to business.
  • 4 Answers
SOURCE: Jabra bt250v Indicator light doesn't remain on...
i have just repaired my bt250 with this problem, i hadn't used it for around 2 years and when i put it on charge just got i flash of blue led. the fix was to "jumpstart it" the headset needs to se some sort of battery voltage to start the charging process, i stripped mine right down but that was just to fiddley. IF YOU DO THIS IT WILL BE ENTIRLEY AT YOUR OWN RISK AND I TAKE NO RESPONSIBILITY IF YOU TRASH YOUR OTHERWISE USELESS HEADSET. ok all you need to do is very carefully remove back cover (undo 1 screw and ease it apart). be very carefull as there are delicate wires inside. lift the inner part out slowly and you will see the battery.it has some orange tape around the end and there is a small circuit board attached to it with a small red wire and a small black wire. look at the battery and you will see under the orange tape there are to larger tags.these are the main battery terminals, peel back the orange tape just until the tags are slightly exposed. now you need to solder a wire to each of them and DON'T TOUCH THEM TOGETHER. on the battery it says which tag is + and which is - make sure you mark your wires or get red and black ones. now i used the lead from the charger. look at it . it has a hole in the center of the pin that is the + so put the + wire in there. if you are not sure use a volt meter. now touch the - wire to the outer metal of the connector that is the - point on the charger connector. hold this for around 2 mins but no more. as the out put of the connector is 6.2v and the battery is only 3.7v the battery will get warm. if the battery is getting too hot in under 2 mins then take of charge. when you have done that and taken off the connector i recommend to use a volt meter and just put it on the battery wires you soldered on to check battery voltage. as long as it reads you should be ok. de solder your wires from the tags and rebuild headset then try and charge it. this worked for me. i am no electronics expert i just like to mess with broken stuff so i know it seems a bit dodgy to connect like this but i had nothing to lose and it worked.
Posted on Dec 01, 2008
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
I have a Sennheiser MM100 Bluetooth headphones that has stopped responding. It will not turn on/off and the LED light is blinking a continuous blue. How do I get it to function again?
Found this online. Hope it helps you out.
Switching the headset on
To switch the headset on:
Press and hold the Play/Pause button for 2 seconds.
An ascending confirmation beep is heard in the headset and the LED indicates the current operating mode. Flashing in blue indicates that the battery charge status is OK; flashing in red indicates a low
battery (see page 6).
The LED flashes several times every second:
The headset is paired to one or several Bluetooth devices and tries to connect to one of these devices.
The LED flashes slowly (once every second):
The headset is paired to one or several Bluetooth devices. However, there is no current connection because the
Bluetooth device is switched off or out of range.
The LED flashes once every 3 seconds:
The headset is paired to one or several Bluetooth devices. However, there is neither an audio transmission nor an active call.
The LED is glowing slowly every 4 seconds:
The headset is paired to one or several Bluetooth devices, a sound file is received via A2DP and played back or
paused.
The LED flashes once every second:
The headset is paired to one or several Bluetooth devices and there is currently an active call.
If you switch on the headset and keep the Play/Pause button pressed for 5 seconds, the headset will go into pairing mode (see ?Pairing the headset? on page 9).
The LED flashes alternatingly in red and blue for up to 60 seconds:
The headset is not yet paired to any Bluetooth device. Pair it as described under ?Pairing the headset? on page 9.
Oct 31, 2012 | Audio Players & Recorders
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I can't connect with my phone
Please follow the detailed instructions below for the proper pairing of the headset with your phone.
CHARGING
Before using, you must first charge your headset.
20 minutes = minimum charge
2 hours = full charge
Light is solid red when battery is charging.
NOTE For the best user experience, keep your headset fully charged.
CAUTION Do not use headset while charging and do not connect the charger while the headset is in use.
POWERING
Press the control button for 2 seconds to power on. Press the control button for 3 seconds to power off.
PAIRING
Step One:
Prepare Phone- Turn on Bluetooth For most phones, go to Settings/Tools menu and select Bluetooth or Connectivity and select "On."
Step Two:
Prepare Headset- Pairing Mode Begin with headset turned off. Turn headset on (hold call control button for four seconds until the light flashes blue) and it will automatically go into pairing mode, flashing red and blue.
Step Three:
Pairing- Add Headset to Phone For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device, then Select "220Plantronics." For passkey enter
0000. Headset will flash blue when paired successfully. It is now powered on and ready to use.
NOTE: Normally you only need to pair the headset and handset once. If headset has been previously paired with another device, follow pairing instructions below.
If headset has been previously paired with another device, please follow these instructions for pairing a second time. Be sure the headset is fully charged.
1. Press and hold down the call control button for 8 seconds until the headset status
indicator begins to flash blue then red.The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing,use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
NOTE: The headset can pair to multiple Bluetooth devices, but will only connect to one device at a time. The headset will automatically connect to the last device to which it was connected.
Please don't forget to rate me if satisfied.Thanks for choosing Fixya.Good Luck.
Jun 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Okay i have the mad catz 8806 mic it flashes red and blue and charges fine but i cant talk into it and cant hear anyone through it at all it beeps and i hear that.
If the headset you have is the Item No. 8860 in order to use it you have to pair it.
If you are using it on a PS3 then be sure that you have selected the headset in the PlayStation's settings.
Pairing is a process of associating Bluetooth devices with each other. It will establish a permanent security link between the devices and enable quick access to the services provided without the need to re-enter Pass Keys. You will only need to pair your PS3 and the Headset once.
Paired devices remain paired even when:
-One of the devices is powered off.
-A service connection is interrupted or stopped.
-One or both devices are restarted.
Pairing the Headset with the PS3
Before the Headset can be used with the PS3, the two devices must be 'paired' so they can communicate with each other. Use a gaming controller for this procedure and ensure that the Headset is powered on (flashing blue LED light) and that it is not being charged via USB cable.
1. Power on your PS3 console.
2. Within the "Settings" menu, press X on "Accessory Settings."
3. Press X on the icon labeled: "Manage Bluetooth® Devices."
4. Scroll down and press X on the icon labeled: "Register New Device."
IMPORTANT: Depending on your model of the 8860 Bluetooth® Headset, your power button is either an oval shape with an icon of a circle with a line going through it (5a) or it is a button with a phone icon (5b). Please follow the appropriate next step depending on your model of the 8860.
5a. Once at the next screen, prepare the Headset to be paired with the PS3 by holding down the K1 button until the LED flashes Blue and Red (hold K1 approx 12 seconds).
5b. Once at the next screen, prepare the Headset to be paired with the PS3 by tapping the pairing button located next to the volume controls on the side until the LED flashes BOTH Blue and Red.
6. Once the Headset's LED indicator is alternately flashing Blue and Red (indicating the Headset is ready to be paired), press X on "Start Scanning."
7. Once Scan is complete, the PS3 will recognize all Bluetooth devices within range.
8. Locate "8860" from the list of available devices and press X on its icon to be prompted for a Pass Key
9. Enter 0000 (four zeros) as the Pass Key and press X on OK
10. You should then be taken to a new screen stating: "Register completed"
Troubleshooting
Q. The PS3 is unable find the Headset.
A. If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Q. The Headset cannot be activated after being charged for 20 minutes.
A. To activate the Headset, the battery needs to charge for at least 40 minutes. It is highly recommended to fully charge the battery before use.
Q. No indication of charging is shown.
A. If the Headset battery is empty or has not been used for a long time, it may take some time for the Headset LED indicator to show charging status with a steady Red light. Make sure the PLAYSTATION 3 is turned on. The 8860 cannot charge without the console being turned on.
Q. No sound can be heard from the Headset.
A. Please make sure of the following:
-Make sure that the two devices have been paired.
-Make sure that the Headset is turned on.
-Make sure that the two paired devices are within 30 Ft. (9.15 meters) of each other.
*** Do not try to pair the headset to the PLAYSTATION 3 when the headset is attached to the USB cable. If it is attached to the USB cable when trying to pair up, it won't pair with the PLAYSTATION 3. ***
Hope it helps
Apr 06, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
Installing mad catz ps3 bluetooth
In order to use it you have to pair it with the PS3.
Trouble Shooting
Feb 27, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
Im trying to hook up my mad catz bluetooth to my ps3 and i got it pass the scan part but it keeps saying theres a problem...PLEASE HELP
Is your PS3 seeing the Headset?
Is the headset in pairing mode?
Complete details below on how to connect it:
Trouble Shooting
Feb 22, 2011 | Mad Catz Bluetooth Headset for PlayStation...
I cant find instructions to sync my Mad Catz PS3 Blu tooth headset
Hope it helps:
Trouble Shooting
Jan 30, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
Bluetooth headset
USING THE HEADSET
US USING THE HEADSET
1. Headset
2. Control Button
3. Light Indicator
4. Microphone
5. Earloop
6. Speaker
7. Charging Jack
A. Charging
Charge for at least 20 minutes before
first use. Complete charging in 2 hours.
Headset will not function when charging.
B. On/Off, Volume↑↓
Press the Control Button for 2 seconds
to power on. Press the Control Button
C. Pairing
Begin with Headset turned off.
Press button for 6 seconds. Release
button when Light Indicator flashes
blue/red. Headset is ready to pair with
Bluetooth device.
D. Pairing
Use your device’s menu to begin
pairing mode and select “320
Plantronics” on the display. When
asked for passkey, enter “0000.”
Jul 13, 2008 | Plantronics Explorer 320 Wireless Headset
Jabra BT350 Wireless Headset Logo
29 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
