Question about CSi Speco Speco Technologies Dvr-pc8 8 Channel Pc Based Triplex Digital Video Record With 160gb Hard Drive
My Speco DV PC8 wont boot. There appears to be a constant alarm on the sensor/alm board. Disconnecting the sensor alarm board from the system does not resolve the boot problem. Symptoms Motherboard FAN starts/starts No Post Constant alarm - Sensor/Alm brd
  • 19,396 Answers
Hi.
Constant beeping during POST test (when booting) usually indicates hard drive failure. The internal hard drive will probably need replacement or re-formatting. Call Speco Technologies at the toll free number:1.800.645.5516
Here their web-page.
Regards.
Ginko.
Posted on Jan 08, 2011
How do i set the alarm on a t231
Setting The Alarm Time of T231
This Timex clock radio has dual alarms that can be set and used independently. The initial default alarm settings are 6:00 AM for Alarm 1 and 7:00 AM for Alarm 2. The procedure for
setting both alarms is the same.
NOTE: The alarm times can only be adjusted when the clock radio is in the OFF mode. If the radio is playing, press and hold the MODE/ALM RESET button until the display briefly shows
'OFF' and then reverts to the time.
1. Press and hold the ALM 1 button until the Alarm 1 time and the Alarm 1 Buzzer indicator begin flashing in the display, then release the button.
2. Press the HOUR / REV button to advance the display to the desired wake-up hour. Observe the PM indicator to confirm that you have set the wake-up hour correctly. If the PM indicator is
'On' the wake-up hour on the display is PM. If the PM indicator does not appear the wake-up hour on the display is AM.
3. Press the MIN / FF button to advance the display to the correct wake-up minute, and then release the button.
4. Press the ALM 1 button once more to confirm the wake-up time setting or after 10 seconds the display will stop flashing and the new wake-up time will be entered automatically. The
display will return to the correct time of day but the Buzzer indicator will remain 'on' in the display indicating that the Alarm 1 is now set to wake you to the buzzer.
5. To change the alarm mode from buzzer to radio, or to cancel the alarm, press the ALM 1 button again. Press the ALM 1 button once more to select the Radio alarm. Press the ALM 1 button once more to cancel the alarm function. The alarm indicators disappear and the display returns to the correct time.
6. Follow the same procedure to set the Alarm 2 wake-up time.
Sep 29, 2014 | Timex Audio Players & Recorders
Minolta di3010
LCC Shift Failure
• The Shifter Return Position Sensor (PC11-LCC) is not unblocked even after the set period of time has elapsed after the shift operation has begun (shifter is moved to the right). • The Shifter Return Position Sensor (PC11-LCC) is not unblocked even after the set pulse is detected by the Shift Motor Pulse Sensor (PC8-LCC) after the shift operation has begun (shifter is moved to the right). • The Shifter Home Position Sensor (PC12-LCC) is not unblocked even after the set pulse is detected by the Shift Motor Pulse Sensor (PC8-LCC) after the shift operation has begun (shifter is moved to the right). • The Shifter Home Position Sensor (PC12-LCC) is not unblocked even after the set period of time has elapsed after the return operation has begun (shifter is moved to the left). • The Shifter Home Position Sensor (PC12-LCC) is not unblocked even after the set pulse is detected by the Shift Motor Pulse Sensor (PC8-LCC) after the return operation has begun (shifter is moved to the left). • The Shifter Return Position Sensor (PC11-LCC) is not unblocked even after the set pulse is detected by the Shift Motor Pulse Sensor (PC8-LCC) after the return operation has begun (shifter is moved to the left).
1 Check the connector for proper connection, and correct as necessary. 2 PC8-LCC sensor check. 3 PC11-LCC sensor check. 4 PC12-LCC sensor check. 5 Replace PWB-C1 LCC.
Sep 09, 2014 | Konica Minolta Office Equipment & Supplies
How do you set this atomic clock C17D2090 (WIC#628865)
Instructions to set the C17D2090 atomic clock
A. To manually set the clock
1. Use the CAL/ALM button to toggle the display until it shows the calendar
2. Press and hold SET until the screen flashes "12hr"
3. Use the UP (antenna) and DOWN (alarm) buttons to change the settings
4. Press SET to set the value
This mode will let you set the 12/24 hours clock, the time, date and year. You should be in the right time zone before you start.
B. To set the alarm1 time
1. Use the CAL/ALM button to toggle the display until it shows the AL1 alarm time
2. Press and hold SET until the alarm time flashes
C. To set the alarm2 time
1. Use the CAL/ALM button to toggle the display until it shows the AL2 alarm time
D. To turn on alarm1
2. Use the DOWN (alarm) button to toggle the alarm on and off (a bell appears on the screen)
E. To turn on alarm2
F. To have the atomic clock set automatically
1. Press and hold the UP (antenna) button until a little triangle flashes on the screen
2. Wait for clock to set
3. To give up waiting, press the UP (antenna) button again.
G. To change the time zone
1. Tap the ZONE button to toggle between the 4 time zones
Aug 16, 2012 | Audio Players & Recorders
Beeping won't stop in Sportline 370 pedometer
Use MODE button to scroll to ALM (alarm) then press INFO button to change from ON to OFF. If that doesn't work use MODE button to scroll to PACE, then press INFO button to toggle from ON to OFF.
Feb 27, 2012 | Sportline 370 Traq Motion Sensor Pedometer...
Atomic travel alarm clock. Model number C17D2090 WIC#693047. (No brand name on clock.) I am living in outside US time zones and can't manually reset my clock to the correct time. (I lost the instructions.)...
Mar 26, 2011 | Audio Players & Recorders
My speco dvr says no disk, how did this happen. Did someone remove the disk?
Sounds like you have a bad harddrive which is what DVR's usually record their data to. You need to take it in to get it fixed or if you can do it yourself, find out what kind of drive it has, e.g. the size of it, the interface (IDE or SATA) and then purchase one close to the same size and replace it.
Jul 02, 2010 | CSi Speco DVR-PC8 Video Recorder
I start using fifox as my default browser but speco remote security cameras is no opening
Firefox does not support the necessary dual streaming that is necessary for speco remote to work. I use Firefox for all my web surfing, but I have to keep IE on the puter to remote access any Speco DVRs that I am servicing. If you really don't like IE, then you will need to use the CMS software that comes with the DVR system on a seperate disc or download it from Specotech.com.
Nov 27, 2009 | CSi Speco DVR-PC8 Video Recorder
I can't reset my Atomic Traveling Alarm Clock C17DD2090(WIC#6930
First, make sure you have new batteries in it. Then you have two choices:
Hold down the 3rd button -- the antenna button -- until the little antenna sign displayed on the right starts blinking and "broadcasting"...and then wait for the clock to set itself.
When that doesn't work (LOL), try this:
Hold down the "Set" button until each of the various fields start blinking. Then press the up button (3rd one) or the down button (4th one) to adjust each field to the desired number, etc. At least, that's what my office technician did to set mine. Good luck.
Mar 25, 2009 | Honeywell RC182WR Atomic Alarm Clock - Red
Activex blocking usage of speco remote
Open the "internet options" menu through tools. Click on "security" tab. Then select the "internet" and click on custom level. Here, navigate to the "Activex controls and plug-ins" section. Change "Download Unsigned ActiveX Controls" to "prompt" and do the same for the setting directly below that. This should clear up your problem
Nov 03, 2008 | CSi Speco DVR-PC8 Video Recorder
CSi Speco Speco Technologies Dvr-pc8 8 Channel Pc Based Triplex Digital Video Record With 160gb Hard Drive Logo
255 people viewed this question
Top CSi Speco Televison & Video Experts
 Russ Hill
Russ Hill
Are you a CSi Speco Televison and Video Expert? Answer questions, earn points and help others
