Question about Dell IN1910N 19" Monitor
What would cause the monitor not to come on? - Dell IN1910N 19" Monitor
    Genius:
  • 1,288 Answers
Blown power capacitors possibly
Posted on Dec 31, 2010
Monitor says no signal
if no signal the cause is either the source not connected like the pc the vga cord not hooked up or a monitor failure. to isolate weather it was monitor problem, if you have other monitor you can hooked up just to ensure if the cause is with in the monitor. by the way you must also considered the vga cord which need replacement.
Nov 10, 2012 | Computers & Internet
My monitor dell 1909w get frozen sometimes, i installed the drive and is not fix.
problems may not be with the monitor. hard disk failure is the most common cause. Overheating inside the computer can also cause your program to hang (may need additional fan or blower to cool it down). video card that cannot support high graphics requirement can also cause it (avoid playing or loading programs which require high graphics and memory requirements)
Feb 11, 2011 | Dell UltraSharp 1909W Monitor
Monitor flikkering .i will check the VGA cable and power cable both are properly connected but the monitor is flikkering .what i do
Answer Sometimes if the refresh rate isnt set high enough you will see a noticeable flicker on the screen .. to change the monitor refresh rate .. you can right click on the desktop and then left click on properties .. click on the setting tab then click on the advanced tab then click on the monitor tab ..look in the drop down menu where it says 60 hertz and see if the refresh rate can be changed .. if it cant .. uncheck hide modes the monitor cant see and then click on the drop down menu .. pick a refresh rate .. 75 hertz is what i use and it should stop the flicker
Answer
keep electronics away from your computer. Mobie phones etc. can distort the image shown on the screen for periods of time, usually when a text or call is coming through.
Answer
A nearby device can cause stray magnetic fields that will cause the display to be affected.
A problem inside the monitor will cause the display to have problems.
If somebody turns on their monitor nearby, the monitor's degaussing when it starts up will cause your monitor to dance wildly for a moment or two.
Answer well one major cause can be the weakness of the electron gun that fire electrons on the silicon plate (pixels) that produces image on the screen so there must be some problem in electron gun in my view
Dec 14, 2010 | Acer AL1511 15" LCD Monitor
Monitor no signal
Sounds like the Monitor cable has come out either at the back of the computer or at the back of the monitor. try fiddling with them as this is generally the only cause of this message. The only other cause is if you computer is in fact not turned on :)
______________________________________________
BlueTiger Business Web Hosting
Jun 22, 2010 | Acer AL1916W 19" LCD Monitor
Monitor shuts down and restarts repetitively if the room temperature is in anyway high
brian30, Hope you have warranty!!! If not, you or qualified electronics technician will need to investigate unit for possible cause of problem. And I mean the ROOT CAUSE!! Read my and other fixya tech's profiles for top two causes of typical problem such as your monitor's symptom. Could be cheap fix if monitor out of warranty. Read, I'm sure you will find out "what and how"!!! 12fixlouie
Mar 03, 2010 | Acer AL2416WBSD 24" Monitor
W2753v screen flicker - refresh
Hi
What causes monitor screen to flicker?
Answer
Answer
Jan 29, 2010 | Computers & Internet
Can anyone Tell me what is causing my monitor to do this?
2 things cause that. 1 bad screen. 2 bad video driver. either way you need to replace parts.
Dec 30, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
How do i get my acer 5715z laptop to work with external monitor , the monitor goes into power save mode as goes to log on page . My laptop monitor has a large cracked mark on it thats why i need an...
Cause If you connected the monitor power already is on, you may not get signal. Power plug off the monitor first, Then connected to laptop. Then power the laptop and power the monitor. FN key press hold with your Monitor swicthing key which symbol of two monitor shows on key probably number 5 or 6 maybe 7 check user guide if you have it.
another cause is your monitor may need driver install in your laptop, Some system required that. Check monitor system requirements.
JMC
Aug 15, 2009 | Acer Computers & Internet
Hello sir, only horizental single line show in my display, what is this problem?
That is caused by absence of the vertical signal, more likely to be a problem with a semiconductor (specially a transistor) broken inside the display. Also, it may be caused by a "cold joint" or a problem with the solder. Heat caused by the "excessive" use of this monitor causes the joint to fail.
May 13, 2009 | Samsung SyncMaster 550S Monitor
My Envision 7100 Stop Working
These are all some component failure problem in the monitor circuits. This may have been caused by faulty components or overheating of the components causing intermittent or permanent failure of some components in the circuits.This causes the feedback circuits to sense incorrect voltages or currents in the circuits and turn on the protection circuit. It may also cause total failure of the power supply circuit and a loss of power to the monitor. These units should be returned to dealers for servicing. Hope this helps you .
Jan 09, 2009 | Envision EN-7100e 17" Flat Panel LCD...
Dell IN1910N 19" Monitor Logo
49 people viewed this question
Alun Cox
