Question about Soyo SY-P4I 845PE ISA (SY-845PEISA) Motherboard
Can I use a p4 3.2 processor with 800mhz fsb?
    Genius:
  • 1,288 Answers
If the 3.2 is a prescott, I would doubt it. This was a board ahead of its time in 2002, and i seem to recall, took the (then) latest P4 3.06 chip. You MIGHT be lucky and the worse that could happen is the board Bios would not recognise the chip, or run it at a lower clock speed
Posted on Dec 31, 2010
What are the different cpu's that ux915g motherboard will accept? Can it take a pentium D processor?
This would be the Aopen motherboard from the cube...
They take the following CPU's
Processor Number
Processor Frequency
FSB
Ratio
Cache
5 Series
560
3.60GHz
800MHz
18x
1MB L2
550
3.40GHz
800MHz
17x
1MB L2
540
3.20GHz
800MHz
16x
1MB L2
530
3.00GHz
800MHz
15x
1MB L2
520
2.80GHz
800MHz
14x
1MB L2
3 Series
350
3.20GHz
533MHz
24x
256K L2
345
3.06GHz
533MHz
23x
256K L2
340
2.93GHz
533MHz
22x
256K L2
335
2.80GHz
533MHz
21x
256K L2
Note: With CPU changing rapidly, there might be fastest CPU on the market by the you received this installation guide. This table is kindly for your references only.
May 13, 2014 | Computers & Internet
System reguirements to inrease ram memory
Ram Memory typically operates at half of the frequency rate, ('Speed'), that the Processor's -> FSB does.
Your motherboard supports Processors that have either a 400MegaHertz Front Side Bus, (400MHz FSB), or 533MHz FSB, or 800MHz FSB.
(Northwood Core for 400MHz FSB. The rest is in the other solution I provided)
Processor has a 400MHz FSB?
You can use DDR Sdram ram memory that is 266MHz.
(PC2100)
Processor has a 533MHz FSB?
You can use DDR Sdram ram memory that is either 266MHz, Or 333MHz.
(PC2100 and PC2700 respectively)
Processor has an 800MHz FSB?
You can use DDR Sdram that is either 266MHz, or 333Mhz, or 400Mhz.
(PC2100, PC2700, and PC3200, respectively)
NOTE*
When using a processor that has an 800MHz FSB, and using PC2700, (DDR at 333MHz), the PC2700 ram memory will run at ->
320MHz.
JEDEC has set the voltage requirements for DDR Sdram at 2.5 Volts.
'Performance' ram memory that is DDR Sdram may use higher voltages.
Not recommended unless you know how to overclock.
Although the motherboard, and the ram memory module may have SPD, it doesn't always work,
http://en.wikipedia.org/wiki/Serial_presence_detect
A lot of times you are faced with going into BIOS Setup, and changing the ram memory voltage, IF BIOS Setup has this feature.
This is why I say overclocking experience helps tremendously.
You want Low Density, Unbuffered, Non-ECC, and a CL of 2.5 for PC2700, and a CL of 3.0, (3) for PC3200.
[Why would anyone want to run PC2100> Lol! ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 11, 2012 | Computers & Internet
Does the MB support an Intel Prescott 3,06 ghz fsb 800mhz processor?
that is a socket 478 board. it supports northwood and early prescotts. prescotts at 3.06 with the 800mhz fsb were made in both socket 478 and lga 775 forms, so you have to make sure that your processor is indeed a socket 478 model.
Nov 06, 2010 | Abit IC7-G I875P;SOCKET 478;800MHz...
I have an Ms-7037 motherboard. I want to change
You cannot change the FSB to 800 , the board is made to take certain FSB's and processors are made with certain fsb speeds (Mainly 533mhz , 800mhz , 1066mhz etc)
These speeds cannot be changed . You have to buy a new processor and a new board to get the faster speed FSB !
If you found this solution useful , please rate below
Kind Regards
1234s282
Jul 02, 2009 | Intel Motherboard
2.4GHz 533MHz FSB to 2.4Ghz 800MHz FSB
Yes, you can put any Pentium 4 or Celeronsocket 478 processor in there, including those with an 800MHz FSB onthe processor. Don't waste your time with only a faster FSB unless youjust happen to have one laying around, the performance won't improvethat much. This one is $50 from Newegg.
Upgrading the components is not overclocking. Overclocking is when youforce the components to run faster than they are rated for. Yourmotherboard is set up to allow this, through the BIOS. Severaloverclocking features areintegrated into the BIOS, including the ability to adjust the FSBfrequency, and the Vcore, DDR, and AGP voltages.
If you choose to overclock, be prepared to make frequent changes toachieve best performance vs. stability. I would suggest upgrading yourcooling to the best you can afford as well. Your PC may lock up orrefuse to boot for no apparent reason if you overclock. Be preparedfor that and know what to do about it before you start youroverclocking career.
Mar 17, 2009 | ASUS Computers & Internet
Processor
This motherboard supports the latest Pentium 4 CPU from Intel in LGA775 package. With 800MHz FSB, 1 MB L2 cache, Hyper-Threading Technology and core-speeds up to 3.6GHz and beyond, Intel's LGA775 Pentium 4 is one of the fastest desktop processors to date.
make sure your cpu has a 800mhz fsb
Dec 22, 2008 | ASUS P5P800-MX Motherboard
Cpu upgrade
Your computer has one of these options:
spacer.gif level2_arrow.gif Intel® Celeron® Processor 560
(1MB L2 cache, 2.13GHz, 533MHz FSB)
or
Intel® Celeron® Processor 550
(1MB L2 cache, 2.0GHz, 533MHz FSB)
or
Intel® Celeron® Processor 540
(1MB L2 cache, 1.86GHz, 533MHz FS
or
Intel® Celeron® Dual-Core Processor E1400
(512KB shared L2 Cache, 2.0GHz, 800MHz FSB)
or
Intel® Celeron® Dual-Core Processor T1400
Check the features with Acer first and see if your motherboard model support that speed processor.
Contact tech support directly to the manufacturer right here:
http://acer.custhelp.com/cgi-bin/acer.cfg/php/enduser/ask.php?p_sid=8P57rbgj
Oct 13, 2008 | Acer Aspire 5315 Notebook
Processor FSB
no, the proc will lose speed. the FSB is a part of the equation that determines the processors speed. A lower FSB speed will mean reduced performance.
Jan 11, 2008 | Asrock GE PRO-M2 Motherboard
Processor compatibility- ASUS P5S800-VM
Asus P5S800-VM do NOT support Core 2 Duo: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5S800-VM
Oct 03, 2007 | ASUS P5S800-VM Motherboard
Soyo SY-P4I 845PE ISA (SY-845PEISA) Motherboard Logo
57 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
