Question about OfficeMax 0M96431 Shredder
Can the shredder overheat? and if yes, how long until it works again
My shredder just stopped working @ end of a sheet. How do I clear it?
It has probably cut out on overheat. Crazily, you are supposed to use them for 3 minutes and leave them for 30.
It should work again in about 15 minutes.
If it comes back with an error, put it in reverse.
Jan 30, 2016 | Shredder Office Equipment & Supplies
My child put a magazine through the shredder and it quite working when it got jammed. Is there a reset button?
First - exactly what manufacturer and model are you having problems with? More precise information helps to solve problems quicker.
Remove the magazine. Unplug the shredder and then plug in and try manual controls to see if it works. If not, check the manual if you have it, or wait until we can find an answer for you. You can try lifting up the lid to try and locate a reset button if your unit has one.
Feb 05, 2015 | Shredder Office Equipment & Supplies
How do I fix the rollers that won't turn when paper is inserted in shredder?
That shredder is as weak as they come - it is probably a broken plastic part inside the mechanism. Recommend you throw it away and get the Amazon Basics shredder, your experience will be much better. Sorry.
Jan 16, 2015 | Royal Office Equipment & Supplies
Compucessory CCS 60062 shredder overheated
These units take about 24 hours to recover... unplug unit and let it sit for 24 hours...the unit will reset once plugged back in after.
Dec 24, 2013 | Compucessory CCS 60062 Shredder
I have an Ativia 6000 shredder. The red light comes on and the shredder stops, after only shredding a few papers..why?
If place too many pages in the shredder the motor will be overworked and it will overheat and shut down until it has cooled down. Try shredding fewer pages at a time.
Jul 03, 2012 | Computers & Internet
Powered off during shred.
some shredders have overheat protection. see your manual or wait an hour and try again.
Jan 02, 2011 | Quartet gbc Shredmaster 4500S Shredder
I have a new Office One paper shredder VS502C and it has stopped working. Do you have any suggestions
these machines overheat when you shred paper constantly let it cool down for 20 mins,or the top part of the shredder might not be properly placed,lift it up and replace it again.
Feb 15, 2010 | Shredder Office Equipment & Supplies
The shredder overheats. The most we can shred are
Have you put any shredder oil or a shredder oil sheet through the machine.
Shredders need oiling to keep the cutters free
Free cutters mean clean cuts and less friction
Jan 14, 2010 | Intimus 502 Shredder
It stopped working after a big shred. I suspect an overheat. How do I reset it?
it's overheated, after you turn on the shredder, is it working?
if not, that means your shredder's motor is death.
need to buy a new shredder.
May 06, 2009 | Office Equipment & Supplies
Shredder stops after about 10 minutes
spray the sheddred wheels with wd40 or any lubricant
Jan 18, 2008 | Aurora Electronics AS1010TX Cross-cut...
OfficeMax 0M96431 Shredder Logo
89 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Randy Schumann
Randy Schumann
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
