Question about Generac 5606 XP Series XP8000E 12,000 Watt 410cc OHV Portable Gas Powered G
DOES THE GENERAC XP8000E GENERATOR HAVE BRUSSHES OR IS IT BRUSHLESS ?
2 Suggested Answers
  • 111 Answers
SOURCE: Where can i get a new battery for my generac
Well, check your farm supply/hardware stores... some larger hardware chains may carry this battery and even the auto parts stores, some will carry these smaller batteries. Take down the make and model of the generator, or even better, take the battery along and they can fit you up with an alternative brand that will fit the space and provide the proper voltage to crank the generator.
:o)
Posted on Jan 04, 2011
Generac XP8000E how do you replace the battery charger fuse 1.5 all I can find out is you have to remove the control panel. No manual and can't find any info
Roger,
1st check the voltage going into the Battery Charging Rectifier from the alternator. You should get between 12 Volts DC to 16 Volt DC with the engine running.
If you get these results next check the battery. You should get max 13v dc going to the battery. If your battery is not charging on this unit or gets under 12x dc, you need to replace the battery charging rectifier.
http://www.generatorguru.com/battery-charging-rectifier-99302775/
If you need other parts you can find them on this page.
http://www.generatorguru.com/xp8000e/
Hope this is of assistance to you!
Dec 19, 2016 | Generac Electrical Supplies
This generator will not start been sitting in shed since daughter last barrel race she has a rodeo tomorrow and I can not get it started
The throttle is controlled by the a load sensor. Find the throttle and hold it up open while you try to start it.
Oct 04, 2014 | Generac 5606R XP8000E XP Series 8000 Watt...
Reset change oil message on generac xp8000e
There is no way to reset it manually. It resets automatically after you run it a few hours.
Nov 03, 2012 | Generac 5606 XP Series XP8000E 12,000 Watt...
Can a remote start switch be installed on an XP8000E portable generator? If so, is there one on the commercial market, or does one have to be built or assembled from scratch? Would be nice not to have to...
If you do not email support@fixya.com and get them to remove this, you will keep getting people trying to answer something that is impossible to do economically....
Please email support@fixya.com and get this removed from the list..
Thanks!!
heatman101
Aug 16, 2011 | Generac 5606 XP Series XP8000E 12,000 Watt...
Xp8000e wont start. sound like a dead battery, nor will pull start turn engine over.
have you tried removing the spark plug and see if possibly there's a hydro lock from gas or oil in the piston area of the machine,this will remove any pressure off the starter and also pull rope mechanism,then you can visually look into the cylinder and see whats going on,then if this doesn't help then you may have a locked up engine from lack of oil lubrication and the rod bearings in the sump may be bad resulting in the need for a complete rebuild of the engine,if the engine checks out o.k. then you may have a locked up generator head,you may need to split the two components to find out which is locked up
Feb 03, 2011 | Generac 5606 XP Series XP8000E 12,000 Watt...
The battery won't start the generator. It has to be hand pulled to start. how do I recharge the battery?
Sometimes it is more expensive to fix the problem with the generator charging system than purchase a small 12v battery charger. I would purchase a 12v small battery charger (5A) that you can keep plugged into your house hold power. This will maintain the battery at full charge so it is ready to start when you need it.
Jan 29, 2011 | Generac 5606 XP Series XP8000E 12,000 Watt...
Where can i get a new battery for my generac xp8000e?
:o)
Jan 04, 2011 | Generac 5606 XP Series XP8000E 12,000 Watt...
Have XP 8000e Generac -5 months old, Tires are supposed to be solid but have gone about completly flat on bottom, don.t seem solid like ones in store but no place to air up ...cb
These tires are made of a hard plastic with thick sidewalls to hold the generator up. They are not repairable once the sidewalls break down and collapse. The only option is to replace them. If you're still under warranty you can get them replaced under that. Only problem is you'll get the same kind of tires, unless Generac has updated them, and have the same problem in another five to six months. Your best bet is to do some research and find some truly pneumatic or solid/foam filled tires for your generator.
Dec 23, 2010 | Generac 5606 XP Series XP8000E 12,000 Watt...
Generac model pp5000t 5KW generator, new, runs perfect but no output. tried flashing the field but still no output.
There is a technique for energizing the field, as just flashing a brushless will not work.
It involves two series 150 watt lamps between the utility power and the running generator. You can find it with Google.
Mar 22, 2010 | Electrical Supplies
Generac 5606 XP Series XP8000E 12,000 Watt 410cc OHV Portable Gas Powered G Logo
102 people viewed this question
Top Generac Measuring Tools & Sensors Experts
deton8 von Splosion
David Ellis Rhea
Lucy Angela
Lucy Angela
Are you a Generac Measuring Tool and Sensor Expert? Answer questions, earn points and help others
