Question about Philips Magnavox 20MT133S 20" TV
To many Channel not accsseble
I only receive a few channel even though I saved them all in the editing mode
There is av blue icon on the upper left screen i can't get rid of .
Please Advise
Thanks
Hans Joerg H Enderlin
  • tyronemccowi Dec 11, 2008
    i can't get all the channels
  • Philips Master
  • 5,568 Answers
Wow Hans, does that name look German?
Gruesse!
Go into your main menu and check to see if the 'source' is properly set for your situation.
The 'av' almost surely stands for 'audio-video' which implies it is set for an external device rather than a cable, satellite, or antenna input.
However, it is odd that if set to an external input that you are getting any channels at all.
You didn't mention it but it sounds like you have other devices connected such as VCR, DVD, a home theatre system, etc.
Some sets will switch to external signal inputs if it detects their presence; in other words, if a connected VCR is turned on, the set might be expecting an input from it.
Viel glueck!
Posted on Jul 08, 2008
The receiver will not turn on, there is a red led that continuously blinks on far left corner of display
The unit is in protect mode. Try holding the advanced surround and power buttons for around 5 seconds. the unit should turn back on. If it turns back off after a few seconds, then you most likely have a problem in the amplifier that will need to be repaired.
May 28, 2015 | Pioneer VSX-1123-K 7.2 Channel HD...
I have a HTR-3065 receiver and no sound in center speaker
Try changing surround modes - the center channel is not used in all modes. If that doesn;t work, check your speaker settingsw and make sure the center channel is not turned off
Feb 22, 2015 | Yamaha HTR-3065 5.1 Channel AV...
I don't know how to change my profile picture on YouTube
Change your channel name or icon
Once you've connected your YouTube channel with a Google+ page or profile:
  • The name on your connected Google+ page or profile becomes your YouTube channel name everywhere (on videos, comments, your channel title, etc).
  • Your Google+ page or profile photo becomes your YouTube channel icon.
If you want to change your channel name or icon, you can edit your connected Google+ profile or edit your connected Google+ page. Once you make changes in Google+, the changes will appear on YouTube.
Google+ supports changing your name up to three times in two years. Please keep this in mind if you decide to edit your name. Find out more about Google+ names.
Note that it may take some time for the changes to update throughout the site.
Jul 13, 2014 | Computers & Internet
Marantz NR1402 AV receiver Going to standby Mode
There could be a short in one (or more) of the speaker connections. Try disconnecting all speakers and turning on the receiver. If it still switches to standby, there may be an internal problem.
Mar 03, 2014 | Marantz Nr1402 Av Receiver
No remote need tv in av mode
While ur TV is connected to d AV device which must also be on, run a frequency scan and all available channels including ur AV channel will be detected and saved. After d scan, u can manually change channels to ur AV choice.
Jun 06, 2013 | Televison & Video
Lost the remote. How do I switch TV/AV to play video?
If there is a mode button, otherwise if there are not other buttons on the set itself, try tuning channels with autoprogram or channel add/edit and see if there is an INPUT or AV channel.
Otherwise you can get universal or origonal remote online.
Oct 27, 2009 | Orion STV2763 27" TV
I can not find all the tv shows what do i do
Channel Edit makes it easy for you to save or delete channels in the list of channels in the TV?s memory. 1. Using the Number buttons, select the channel you wish to save or delete. 2. Press MENU to see the menu. 3. Press upper or lower key to scroll through the menu until SETUP is highlighted. 4. Press right key to enter the SETUP menu. 5. Press upper or lower key to scroll through the SETUP menu until CHANNEL EDIT is highlighted. 6. Press right key to choose SAVED or DELETED. Choose SAVED to add the channel to the TV?s memory. It will be available using the CH +/? buttons. Choose DELETED to remove the present channel from the TV memory. To clear the menu press STATUS/EXIT. Or, wait a few seconds after you finish your adjustment; the menu will disappear automatically. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Jun 13, 2009 | Philips Magnavox 20MT133S 20" TV
HTR-6130
Read your instructions book again, when you press 7 that mean you are enter in select speakers you must use 7 then narrow UP DOWN and LEFT RIGHT when you finish you must save by press SET
The easy way to set it up is connect your receiver to TV then you can see the complete MENU on your TV screen
Or you initializer the unit to go back to the default mode, which will set to 5 speakers if you wish to do this look on same model I was post earlier how to initializer the receiver
Nov 28, 2008 | Yamaha HTR-6130 Receiver
How to access AV channel on Toshiba TV model 2125RA
some sets auto-go av when you plug a rca jackin the set, others have a switch in front or back , others you might set your channel to 00 or 99 or 100 forget and work different , I the owners manual of course would tell you. but I assume u dont have it . try hooking it and letting the dvd run now find it using the remote.
good luck.
Feb 23, 2008 | Televison & Video
Not Receiving Cable Signals
100% you have or a faulty tuner inside that has to be checked for dry joints or it has to changed completely. Patrick
Aug 26, 2007 | Spectra SS213 TV
Philips Magnavox 20MT133S 20" TV Logo
67 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
