Question about Whirlpool LGB6300 Gas Dryer
Dryer is on but drum doesnt turn - Whirlpool LGB6300 Gas Dryer
  • Whirlpool Master
  • 7,482 Answers
Most likey your problem is a broken belt that will need to be replaced
Posted on Dec 31, 2010
The power turns on but drum will not turn
sounds like ur belt dat gose around ur drum and d motor has snapped easy cheap fix open it up and get d number of d belt and ring d manufactor tell dem d number and order new 1
Jun 26, 2012 | Frigidaire Electric Dryer
When i try to start my dryer it clicks to turn on but doesnt fire the drum
Reach in and turn the drum by hand if you can do so with very little resistance then the belt may be broken or off the motor.
Oct 15, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Heating works but drum doesnt turn.
Try turning drum, or remove top from dryer to confirm if belt has gone. When turning drum there should be some resistance as the belt fits around the drum
Feb 18, 2010 | Whirlpool LER4634J Electric Dryer
How to use the dryer rack in dryer ??? how to set up so doesnt spin.
The dryer rack should hook to the bottom of the door opening(using the lip of the door). If the rack is properly placed the drum should be able to turn without touching the dryer rack. Some dryers have the option of turning off the drum. If your dryer does not have this button or a dryer rack position on the timer dial then you cannot turn off the drum.
Jan 22, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Husband just changed belt on dryer, and drum still doesnt turn
While you have the drum out check the motor to see if it runs. It could be you have a faulty motor.
If the motor is running then you may have a faulty timer or start switch
Good luck,
I hope this helps
Oct 28, 2009 | Maytag Dryers
Press the start button and drum doesnt start but the dryer makes a humming noise.
motor running but drum not turning, good chance drum drive belt is broken or has jumped off drive pully.
UNPLUG POWER CORD TO DRYER.
open dryer and look for broken belt, if belt is broken use modle number from dryer to purchas the correct belt for dryer install belt and reasmbele dryer. reconect power and test dryer.
Oct 23, 2009 | Dryers
When dryer is turned on , it hums but the drum doesnt turn. It smells like heating element is working, belt is on correctly but drum will not turn. Any suggestions? Thank uou
sounds like the bearing the drum rides on is bad. that will cause the breaker to trip as the motor strains to turn the drum on the bad bearing.
Sep 09, 2009 | Dryers
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Dryer motor just hums
Sounds like the belt has been stretched and is not letting the motor turn the drum. If the motor is not turning at all then your motor is burnt out and needs ot be replaced
May 22, 2009 | Dryers
Whirlpool LGB6300 Gas Dryer Logo
32 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
