Question about DeLonghi EC155 Espresso Machine
The heating element seems to be broken. It does not heat water even after 30 mins of turning it on. The rest seems to work fine.
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: The heating elements on the bottom of the oven
Yes, they can be replaced quite easyly, you need to locate a service agent, or a local repairer.
There should be no problem.
Goid luck.
Posted on Dec 10, 2009
MY HEATER WORKS OK BUT WATER RUNS COLD AFTER TWO MINUTES OR SO TURN OFF AND ON AGAIN FINE FOR ANOTHER TWO MINS OR SO
One of your heating elements are probably broken. You have one on top and one on the bottom. You need both to heat the whole tank.
Jan 28, 2016 | Water Water Heaters
I have a problem with a fisher and paykel MW512AU washing machine. I turned the machine on as normal, start the load, and everything was fine. After roughly 10 minutes the machine stops doing...
the heating element has an issue
if you say after 10 mins it fails and stops
this indicates two things
the door lock is aok
and the machine fills
next comes heating up the water
some 10 mins into a warm wash
so perhaps the heating element has an issue
or the hardware cant detect it correctly
modern machine detect as they go
however usually but not always a bad element
causes your home electrics tip out...
but as the motor seems to run slow
it could be a sensor or the motor has bad brushes...
Feb 08, 2015 | Fisher and Paykel Washing Machines
Water only stays hot for about 5 min or
Gas or electric?
Electric water heater ... then test for crossover, check for water leak, replace thermostats, test elements
Gas water heater ... test for crossover, check for water leak
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
water leak: turn off all taps and put ear against pipe and listen for water leak... check if water meter advances when all water taps are off.
Gene
Oct 09, 2014 | Water Heaters
LG LDS581 dishwasher HE error mid cycle
HEATING (ELEMENT) ERROR // Water heating error
The manufacturer has assigned this error or fault code to indicate a problem with the water heating circuit. Turn off the circuit breaker to the dishwasher for 30 minutes, allowing time for the appliance to cool; then restart the cycle. If error returns, check the heating element for continuity and check the wiring harness for any obvious signs of damage. If the heating element shows infinite resistance after testing with an Ohm meter, replace it.
Oct 01, 2017 | LG 24 in. LDS 5811 Built-in Dishwasher
Got 5 minutes of hot water then cold. replaced both elements and thermos. still 5 minutes of hot water. power bill increased nearly 400% in 30 days. HELP!!! please.
When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced. You replaced both elements however check that the lower element is coming on after ther upper one cuts out and is acutally working.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, maybe defective. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
If the dip tube is broken, the incoming cold liquid can mix with the out going hot liquid and cause it to seem as though you are running out.
Nov 04, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F-08 error message on Hotpoint Washing machine WT761? The original fault on the machine was that it was tripping out and taking out a resetable fuse in my fuse box a few seconds after turning the machine...
If it works fine with the heater off then i would say that fault appears to be element..the readings you get seem okay, put you meter onto megs and check, with wires off if you get electrical leakage between live and earth...Body....of element, it could be element is heating with no water in machine causing it to burn out..this is a problem with this machine...Wish you well
Oct 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Wf 865 water does not seem to be heating up
The cycle does not advance because the temp sensor does not detect enough temperature.
The heating element must be tested using a multimeter , and eventually replaced.
Usually the element is the problem, if element is fine, the temp sensor and the timer control must be checked.
Apr 16, 2009 | Hotpoint Ultima WF865 Front Load Washer
Kenmore 110 gas clothes dryer heats for 20 min then needs to rest for 20 mins before heating again
Cause 1Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer's heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
Parts Cause 2Gas Valve Solenoid
Gas dryers have two or more gas valve solenoid coils. The gas valve solenoids open the gas valve ports to allow gas to flow into the burner assembly. If a gas valve solenoid fails, the dryer won't heat. To determine if one or more of the gas valve solenoids has failed, check the igniter. If the igniter glows and goes out but does not ignite the gas, the gas valve solenoid is defective. If one or more of the gas valve coils are defective, we recommend that you replace them as a set.
Parts Cause 3Igniter
The igniter uses heat to ignite the gas in the burner assembly. If the igniter is not working, the gas will not ignite, preventing the dryer from heating. To determine if the igniter has burned out, use a multimeter to test the igniter for continuity. If the igniter does not have continuity, replace it.
Feb 16, 2018 | Dryers
DeLonghi EC155 Espresso Machine Logo
55 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
