Question about Cannon EOS 50D Digital Camera
How to clean the focusing lens? - Cannon EOS 50D Digital Camera
  • 4 Answers
First question: where is the dust?
If the dust ist outside the cam: no problem. Try a soft brush and remove bigger particles, then take a thin microfibre cloth and clean the dust film on the lens. Be careful - every sand particle scratches the coating, so use the brush!
If the dust is internal it's more complicated.
May be the dust is on the focussing screen. If you dismout the lens, there is a litte lock on the top inside the cam. Do not open without having special tool. Each fingerprint on this little plastic plane is not removable. It's an extreme sensitive fresnell lens.
Don't try to clean that with cloth or brush. Only airflow is allowed.
If this dosn't help - use the Canon service or replace the focussing screen with a new one (as Example Canon EF-D).
Posted on Sep 12, 2014
The backup camera seems a bit hazy even after cleaning the lens anyone else find this
Some webcams have a 'focus ring' to adjust the focus. I do not know if auto backup cams have such a thing built right onto the camera lens. Adjust that focus until the pic is clear.
Feb 17, 2015 | 2015 Chevrolet Colorado
Auto focus does not work on canon eos 300d camera
It may be that the ribbon connector has broken in the lens.
Nov 26, 2013 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
My pl1 camera has blurred pictures but when lens taken out, its ok.
Are you using an auto-focus m4/3 lens? I have about 20 lenses for this camera and only 1 of them is an auto-focus m4/3 lens. I have an adapter so I can use my 4/3 lenses on it in auto-focus mode along with other various mounts (including cctv) that do not support auto-focus. So if you are using a non-auto-focus lens, you will need to manually focus the pictures.
If you are certain it is an auto-focus lens, are you sure you have it set to auto-focus?
What settings do you have your camera set to (aperature mostly is what I'd like to know)? Try adjusting your aperature to be small (to increase your DOF).
Also what lens are you using and what is your focal distance? It could be your lens has a larger or shallower focal distance than what you are trying to achieve (like a macro lens doesn't work that great for landscape photography or a telephoto lens doesn't work great for macro photography).
Last thought: is your lens or sensor dirty? A dirty lens can cause focusing issues if it is REALLY dirty and a dirty sensor can too (sensor is a bigger pain to clean. I strongly recommend taking it to the pros as they scratch really easily). Dirty lenses can be cleaned with a blower and a lint free cloth and rubbing alcohol if those 2 things don't clear it out.
Mar 03, 2013 | Olympus E-pl1 Pen Digital Slr Camera w/ M....
I have a canon rebel xsi that is not taking pictures on auto focus. It will take pictures on manual focus, but they're blurry. I changed my lens to a bigger one to see if it was the lens or camera, and...
Try cleaning the lens contacts on the camera body and on the lens.
This maybe the problem, it is not making contact with the lens zoom motor.
Dec 12, 2012 | Cameras
My camera will not auto focus properly...It will focus and refocus. I have to use the manual focus in order to use it.. I have already checked it was in AF setting both on the camera and the actual lens. I...
Try removing any filters, if you have any on the lens. Check the front and rear lens elements for dust/fingerprints and clean if necessary. Check the mirror (remove lens and take a look) and very carefully clean if dirty. Remove the lens and gently clean the gold contacts on the back of the lens and in the lens opening of the body with a pencil eraser. Don't let the bits fall inside the body. Try the focus outdoors in good light of a scene with lots of clutter in the frame to see if the problem only occurs in low light. Check the menus and make sure the focus assist lamp is in the on position. Let me know if these solve your problems.
Sep 26, 2009 | Nikon D80 Digital Camera
Camera won't take a picture when autofocus is on
It sounds like you have a problem with the auto focus on the lens. The 18-135 has a focusing motor inside the lens itself. If this motor is not working, then it won't focus. It could also be the contacts (small and silver on the lens look like ball bearings buried halfway into the top part of the lens where it connects inside the camera body) or the contacts inside the camera body. These can be CAREFULLY cleaned with alcohol and a QTip or a clean pencil eraser. Just make sure you don't get anything into the lens or camera.
If the camera is over a year old, it may just be time to take it to the camera shop for a cleaning.
Aug 26, 2009 | Nikon D80 Digital Camera with 18-135mm...
My Auto Focus lens doesn't auto focus.
try powering cam without lens then put on. try different lens. if not internal menu should have a lens cleaning option
Jun 03, 2009 | Nikon D80 Digital Camera with 18-135mm...
Will not auto focus with a smaller lens.
I had the same issue with my Nikon d60...my 18-55mm did auto focus but my 55-200mm only manual focused, i thought it might have been my camera as i heard that not all lenses are compatible with my d60 but it turned out to be the focussing motor or something that was damaged, it was making a very funny noise when it tried to auto focus with it,like a screeching sound..if this is the case you should get it repaired and looked at, also check on the lens if it says it is a AF lens,if so make sure th switch on the side of the lens is switched on AF not MF. hope it helps
cheers
May 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rbl XT out of focus in viewfndr when shutter half way down
It's possible that the reason the "pictures turn out fairly good" is that your f-stop is set high enough that even though the image isn't properly focused, you have enough depth-of-field to bring your subject into "near focus". Does your lens try to focus back and forth when you half-press the shutter? If not, double check that the lens is in autofocus and not manual focus. You can also try cleaning the contacts between the lens and camera. Take the lens off, and then one-at-a-time clean the contacts on both the lens and the camera, using a clean pencil eraser. Gently rub the contacts. Be sure to hold the item upside down so that the eraser debris falls on to the table, not into the camera body or lens!
If none of this helps the autofocus may have become damaged and you need to have the lens and camera looked at by Canon Repair.
Jan 10, 2009 | Canon Digital Rebel XT / EOS 350D Digital...
Blurry picture
1)Remove rear cover = clean RGB lens with soft cloth
2)Remove front speaker grill cover and access panel
Locate screen / focus block = adjust RGB focus controls
3)Last,if needed, unlock each focus lens cap = adjust then lock
................................................T.
Dec 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Cannon EOS 50D Digital Camera Logo
Top Cannon Cameras Experts
Pavel Pranovich
Pavel Pranovich
Computer Links
Are you a Cannon Camera Expert? Answer questions, earn points and help others
