My Hotpoint Aqualtis washing machine keeps getting stuck towards the end of its cycle. It shows a F-05 on the digital display. Previously I was able to get the washing machine to finish by putting it on a slow spin cycle but this time that hasn't worked and the washing is stuck in the machine with the door lock on. Any ideas on what F-05 means and how to get the washing out of the machine.
  • 1 more comment
  • Anonymous Nov 26, 2008
    the same...
  • Anonymous May 11, 2009
    yep me too, going to try and clean the pump tonight
  • Anonymous Mar 16, 2014
    washing machine spins occassionally and wont finish a wash f 08 keeps flashing on display
My Aqualtis just stopped mid program with F-05 on the display. This is apparently a failure to drain properly. I was luckily able to hold the power button to cancel the current program drain the water out (very slowly) and empty the machine.
THIS IS HOW I RESOLVED MY PROBLEM.
Disconnect the machine from the mains. Turn off the water supply to the machine. Disconnect the cold water pipe from the machine at the top corner.(Watch out for some water) Remove the drain hose from where you have it going to.  Pull the machine out and lay it gently down on the left side panel (use a towel to protect the side and absorb any water). Then, from the now exposed underside there is a black rubber pipe connected to the pump (black) coming from the main drum. Use some pliers to pinch the steel spring that clamps the hose in place and remove. Then using your fingers (there is nothing sharp in there) see if you can find any blockage.
I REMOVED: A pound coin, a dairylea slice wrapper and a piece of kinder bueno packet.
Carefully replace the black hose making sure it is fully on. Replace the drain hose, reconnect the water pipe and turn the water back on. (check to see it's dry with no leaks). Plug it in, turn on and that for me was it. Job Done.
Posted on Feb 01, 2009
  • sveslum
    sveslum Jan 31, 2013
    Very helpful. Found a sock i this rubber pipe, blocking water outlet. Thank you
Hotpoint aqualtis AQXXL 129PI
could be a bad timer? sticking at the wash cycle. it does agitate right? other wise bad water pressure switch
Aug 07, 2014 | Hotpoint Washing Machines
Aqualtis f18
I believe F18 means a communication error with motor circuit. Could be the motor drive circuit board or wiring.Please see here have Hotpoint aqualtis 7 5kg 1400 washing machine showing
May 13, 2014 | Washing Machines
No water check supply
keep on pressing the start button for 30 second it should reset
Feb 08, 2014 | Hotpoint Ultima WD72 Front Load...
My hotpoint aqualtis aqxxd 169pm displays a blockage, we have cleared filter and checked pump is working, yet it still displays same message, and now when the power is on the drum wont turn.
Did you check the filter the pepellor sometimes can get something stuck in it. In one case i came across there was a hair go-go stuck in the pepellor.And also check the pipes at the back the cold water mains pipe going to the washing machine and the discharge pipe are not twisted or kinked
Aug 06, 2011 | Washing Machines
I have a hotpoint aqualtis and i have a fault come up code fo5
F-05 is indeed the water outlet blocked. You need to clean it out, also possibly the pump, & Hoses.
http://www.howtomendit.com/answers.php?id=157950
See above.
http://appliancejunk.com/ge/washer/31-9135.pdf
Service manual above.
Aug 06, 2010 | Hotpoint Washing Machines
My hotpoint aqualtis washing machine doesn't finish a wash cycle it flashes up F-05
push the start button again and restart your pump has a slow clog.it may take a while to drain.after you have the clothes out run 2xclorox through it.
Jul 05, 2010 | Washing Machines
My Hotpoint Aqualtis AQXXD 169 PM is adding time to the was cycle, taking longer to wash through the cycle? ant ideas?
the time is a generic time and will adjust accordingly as goes through programe-for example it allows a certain time to heat in the winter your cold supply may be colder so the machine needs longer to heat water-load size-if its adding more than 30 mins then check filter
Nov 11, 2009 | Washing Machines
Open Questions:
Kenmore Elite HE4T Washing Machine Diagnostic Test Didn't complete and clothes aren't spun as dry as in the past I have a Kenmore Elite HE4T washing machine and I noticed that recently it isn't getting all of the clothes completely dry from the final spin cycle. Thus, the dryer has to run through two cycles to get the clothes dry. I did a bunch of research and made sure there weren't any kinks or blockages in the drain lines; and opened up the bottom of the washer and cleaned out the drain cleanout. I found a few pennies, but everything seemed to be working ok. I ran a load and had the bottom open so that I could make sure the motor, drain and belt were all working properly. The drain does get the water out of the washer, so the clothes aren't sitting in water, they just don't seem to be spun as fast or as long as they used to. I always put it on the "extra high" spin setting no matter which type of load I run. So, I found a way to run the diagnostic test on the washer and it went through C0-C5 (the agitation step) and all worked great, until it wouldn't come out of C5 after at least 10 minutes and go thru C6-C8. I had to cancel the diagnostic test and hit the "drain and spin" button to get all of the water back out of the washer. BTW, the "drain and spin" seems to get the clothes a bit drier than when I have it run through the "normal" cycle with the "extra high" spin. If anyone has any other thoughts, I would really appreciate it. This unit is in a small space with the dryer attached so to take it out and do repairs is a pretty big hassle. It has had a new control board and two new fill valves in the 10+ years that I have owned it. Questions I have: 1.should I remove the entire drain pump to make sure there isn't anything lodged in it? 2. could it be the belt slipping slightly and keeping the spin from reaching its 1200 RPMs? 3. Anything else I may be missing???
Jan 17, 2017 | Kenmore Washing Machines
Washing Machines Logo
2,219 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
