Question about Horizon Exercise & Fitness
My tredmill starts but than stops.sometimes it will keep running.
  • 1 more comment
  • mcclellanlb Jan 03, 2011
    thank-you.I will find model number and send it to you
    hi. again. found a model -ct5.0 and serial number tm602bj436087719 thank-you
  • mcclellanlb Jan 04, 2011
    I do not know yet. will let you know. thank-you.
  • 43,501 Answers
Usually whne you get intermittent problems like that the brain or control board is going bad....
The first thing that I would do is to get the control board replaced, that will fix you up...
If you include a model number then we can look for parts for you...
heatman101
Posted on Dec 31, 2010
My trojan tredmill it just stop whyl iam runing
Check the circuit breaker on the treadmill. Sometimes it will trip to off if there is any over load. If you wish to get some more details about treadmill repair then check the following link
http://electro-medical.blogspot.com/
Aug 22, 2016 | Exercise & Fitness
Get on tredmill it stops
Having the same problem, was wondering if you found an answer. I also noticed that my belt, track, whatever is out of alignment. I am wondering if it is some sort of safety thing if the track is off line.
Feb 28, 2014 | HEALTHRIDER R60 SoftStrider Treadmill
Proform tredmill starts runs 10 sec and beeps twice and stops
I would suggest unplugging the unit from the wall and waiting 30 second and plugging it back in. Then go to where the AC cord enters the machine and look for a reset button or switch. Put it in the reset position and see if this solves the problem. Depending on model the reset may be on the bottom of console.
Dec 15, 2013 | Proform 520 Trainer Folding Treadmill...
I have a proform tredmill it will start and run for about 10 sec, beep twice and stop, you can start it again and it will do the same, i have replaced the reed switch already
hi there,
I do suggest ringing Icon Fitness and organizing a tech to come out and fix. The reed switch is rarely the problem with any treadmill.
While running on tempo tredmill it speeds up by itself then speed comes back down. This keeps happening. it goes faster than someone can run butthe speedo never changes
Please Run the software calibration for easy diagnostic and fix it.
go under the HOOD covert Motor, and follow the steps
God bless you
Oct 07, 2013 | Exercise & Fitness
When i get on the treadmill the belt stops all of a sudden
Try to tension the tredmill's belt. For that you need an allen wench. Watch the following video to adjust the running belt. All the treadmills uses the same way to adjust the belt.
Oct 10, 2011 | Reebok Vista Treadmill - RBTL13305
I have a pro form xp weight loss 620 tredmill and when I turn it on and press start the belt runs for about 1 sec. On the main board in the bottom of the tredmill there is a LED and sometimes it turns off...
Since the motor shroud is off I would like you to manually move the running belt by foot and see if that LED flickers if is does then your speed sensor is working properly. If not then the speed sensor needs to be replaced. The next thing I would be checking is the drive motor, using a fully charge drill battery, lantern battery or even a 9V battery by connecting the two leads coming off the drive motor it should move the motor at approx. 1 mph if it is moving the motor is good. then I suspect the lower board will have to be replaced.
May 17, 2010 | Exercise & Fitness
Tredmill not moving
That's an embarrasing admission. A treadmill works like a conveyor belt or a car's fan belt. If it is too loose it will slip under load. There will be an ajuster on your treadmill. All you have to do is tighten the belt. Do not overtighten it though. an
Feb 17, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Hi my tredmill will turn on but moter wont
If elevation will work it's more than likely your motor controller. I would need to know which treadmill you have to help any futher.
Nov 15, 2009 | Exercise & Fitness
After 10minutes the tredmill stops
Either you are forcing it to go faster than the set speed or not keeping up and it is trying to compensate. Eric
Aug 03, 2009 | Exercise & Fitness
Exercise & Fitness Logo
912 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
