Question about Motorola Mobility RAZR V3
Razor battrey I just charged the phone last night and the battery is all most dead. It will not hold a charge. What do I do?
  • 2,130 Answers
Did the phone show it was charging on the display? Was the charger firmly connected to the phone? The batteries will go bad after a period of time of recharge cycles. I have bought replacement batteries for my RAZR on eBay. Remove the battery and do a search on eBay for a NEW battery from a dealer using the battery P/N on the battery. I found a higher capacity battery for mine that lasts even longer on a charge than the original one that came with my RAZR. You can do a search on eBay for "RAZR battery". Look at the mAH rating on your battey, Try finding a replacement with the same or higher rating than your original. The higher the mAH rating, the longer it will last between recharge cycles.
- Jim
Posted on Jul 08, 2008
The battery seems to be dead and the unit is not recharging. Even when plugged in to the wall, the unit does not charge.
this is because the battrey of your phone become dead thatswhy it is not charging in any way... so only you have to boost the batrey if ther is anything in the battrey then it will work otherwise you have to change the battrey and to avoid this type of problem don't try to work in low battrey...by this your bttrey life is long...enjoy it and pls vote
Jun 23, 2015 | Televison & Video
Hi, I have a problem with my battrey phone, the battrey does not last takes about one day or two days. Sony Ericsson Experia X10 kind regards, Lungile Mbuyeleni
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 13, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Razor Phone wouldn't charge...battery dead, so I replace with new battery. It still will not indicate that battery is charging. I tried several outlets to plug in charger. Still no charging. Phone...
Sounds like you may have a connection problem where the charging cable plugs into the phone. Not much can be done except to get a new phone. Those micro USB/USB style connections last a long time, but once a pin is bent up it is game over. Sorry!
Mar 03, 2011 | Motorola Mobility RAZR V3
Have an e100 razor electric scooter. it has not been used for a couple of years. I got a new e100 charger and tried to charge but i noticed that the green light stays on and the red light charging does not...
The batteries are dead. The battery in these scooter need to be kept charged or if not in use for a long time charged every 3months. Otherwise, like what to you, they will go dead. The chemicals in the battery have deteriorated to the point where it won't hold a charge. Replacement batteies are available at:
razor.com
Jul 20, 2010 | Razor E100 Electric Scooter
Unable To Charge Message on Razor Cell Phone stops working off charger. Battrey shows full
My v3 has done the same sometimes I couldn`t charge then taking it off charge it used to die.
Try a new battery.
Nov 09, 2009 | Motorola Mobility RAZR V3
My phone is dead. I charged it last night and it
Could be a loose connection by the battery terminals give it a clean, if nothing works you should try and get a new charger or battery or both. Hopefully this helps.
Sep 15, 2009 | Samsung Cell Phones
Razor phone won't charge
Hi, I had the same problem with my Old Razor, I bought a new battery and that fixed the problem.
New Batteries for Razors are around £6 - £7 online. google it.
Apr 16, 2009 | Motorola Mobility RAZR V3
Charged my phone last night and will not turn on this morning
Thats what my phone does when the battery is dead. perhaps it did not charge last night. see if the phone will turn on while connected to the charger. if so, the battery is dead or defective.
Feb 27, 2009 | LG VX5200 Cellular Phone
Battery life is short
that means the battery chemical substance is benig dead this is normal cuz all battreis got a life time
just replace the battrey if the phone still not last with fresh battery that means the phone got a dechrge he is make batteries empty through a short circuit or smth like that.
best regards
plz do aret this post as good as u can
Oct 07, 2008 | Nokia 6630 Handheld
Charged cell phone
do not charge your mobile battery each night for best battery use, you need to charge the phone only when the battery is completely dead.
You should take the phone and have it fully check and service
Jun 28, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
140 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
