Question about Kenmore 74802 Top Freezer Refrigerator
The freezer is working but the refrigerator will not get cold
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 01, 2011
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
How do I keep my refrig/freezer from defrosting in the winter when store in the garage.
There is only one source of cold in many refrigerators. If yours is a top freezer, then most likely it is in the freezer.
But the thermostat that you set temperature with is in the refrigerator, not the freezer.
In the cold garages, what can happen is that the refrigerator stays cold enough that it does not call for cold. So the freezer does not get enough cold.
The freezer control works by diverting cold air into the freezer WHEN THE RERIGERATOR HAS TURNED ON THE COOLING. If it is not turned on, oh well.
The best you can do for this is to put both on max cold. Then the refrigerator will call for more cold at a lower temperature, and the freezer will get it more often and will divert more when it is cooling.
This can result in the refrigerator freezing things too. You can try raising the refrigerator setting JUST A LITTLE and see if both work, but keep freezer on max cool.
This works for my situation, but ambient temperature fluctuations in the garage make this dicey. We don't put things like lettuce in the refrigerator in the garage in the winter because freezing damages them.
Good Luck
Feb 05, 2015 | Refrigerators
Refrigerator section not cold, freezer cold and working
heatman101
Feb 19, 2011 | Maytag Ice2O 19.8 Cu. Ft. Side-by-Side...
My Roper refrigerator stopped getting cold, although the refrigerator lights and the fan in the freezer works. What is the problem?
If the freezers warm, possible defrost timer bad, if freezers cold, set to middle setttings on both dials, the 1-10 OFF dial operates the compressor, the COLDER/WARMER dial operates the flapper door that regulates freezer air into the reefer box, if set to max cold that makes cold freezer, not reefer.
Nov 01, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
If the coolant from the freezer compartment leaked, will the refrigerator still work (stay cold)? I know the freezer won't work. thanks.
There is only one coolant circuit for a refrigerator. There is a fan that circulates the cold air from the freezer side and pushes it through the refrigerator side and that's how that gets cold. So if all or some of your refrigerent leaked out then the refrigerator will have to be repaired by a qualified technician if you still want to use it.
Sep 17, 2010 | Haier HNSE05SS Stainless Steel
Freezer is working fine. The refrigerator is not
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
THE REFRIGERATOR IS BUT FREEZER IS
the damper vent door that lets cold air from the freezer into the refrigerator isn't opening to let cold air flow,check to see if its iced up,or the cold control that operates it is working
Apr 30, 2010 | Fisher and Paykel E522BRXFD Stainless...
Kenmore 73503 not cold enough
Is the fan in the freezer working?? Is there Ice on the rear panel in the freezer?
Dec 04, 2007 | Kenmore 73503 Stainless Steel Bottom...
Refrigerator
Sani, see if the evaporator fan is running. That would be the fan in the freezer compartment. It moves the cold air to the bottom. If that is ok, then you may have a defrost problem. Is the freezer panel in back all frosted over? If so, it's probabley a defrost issue. Check these things first and post back...Catriver.
Mar 12, 2007 | Whirlpool GAFZ21 Bottom Freezer...
Kenmore 74802 Top Freezer Refrigerator Logo
60 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
