Question about PfaFF Creative 7570
I don't have the manual for my machine and am having trouble winding the thread onto the bobbin. Is there any visual help online for this?
  • 24 Answers
I don't know of any web video, but you may have simply forgotten a step. Guide the thread from the spool to the left and under the little tension disk, then to the right. The bobbin should not be turning freely, but have a little pin holding it, then push the bobbin to the right to disengage the motor function for the needle and disengage the flywheel. Hope that helps.
Posted on Jan 01, 2011
Having difficulty winding a bobbin, the thread goes across the "top" of the bobbin not inside....any help
Check that the bobbin is seated all the way down on the bobbin winder spool. However, the bobbin winder most likely needs a slight adjustment. I have several machines that tend to wind the thread either high or low on the bobbins so I just use a stiletto or pencil to raise and lower the thread as it winds. It helps to wind the bobbin at a slower speed--reduces stretch on the thread and allows you the ability to manually guide the thread onto the bobbin.
If you'd like to save wear & tear on your machine and be able to wind bobbins without unthreading the machine, look for a stand-alone bobbin winder (one brand is called "Sidewinder"). They cost around $30 and can be found online or at most fabric stores like JoAnn's. Just be sure to verify your bobbins will work on the winder--some Singer and other brand bobbins will not work.
Oct 19, 2016 | Sewing Machines
Winding bobbin on old elna lotus
I can help you with this, the Elna Lotus has a pretty simple bobbin winding system, the bobbin winder is top right of the machine, drop bobbin with holes to the top onto the spindle. Now Lotus have a dial on the right side which switches between bobbin winding, stitching and locked for transport, turn it to Bobbin symbol. Take the thread from the spool pin at the back across to the metal eyelet at top front (it sits inside the accessory tray when transporting so you may need to pop open the tray lid and flip this eyelet out)
24421001-h4211ohbpts0t3j0sbmab0vm-2-0.jpg Now take thread across and through a hole on top of the bobbin and holding the tail, put your foot onto the foot control to get a couple of winds onto the bobbin to hold the thread. Now place your finger or the handle of a pair of scissors onto the top of the thread spool to apply tension so that the thread winds evenly and slowly wind the bobbin until about 3/4 full, making sure it winds evenly. Tension onto the spool is the key here, Lotus doesn't have a tension device to control the thread tension as it winds so you need to do this, critical to getting a good stitch out of these lovely machines.
Hope this helps you out.
May 14, 2014 | Elna Sewing Machines
How to thread a bobbin
Which Singer machine do you have? I know how to wind and insert a full bobbin for some models.
Some wind the bobbin with it in the case. This is the case with my Touch & Sew. Inserting a full bobbin is simple. Open the slide plate and drop in the bobbin with the rings up. Make sure that to hold the bobbin thread so that it comes off at the left. Then close the slide plate and make sure that the end of the bobbin thread is coming through the notch. Hold onto the threads and turn the handwheel until the top and bottom thread come back up with a twist. To wind a bobbin for this machine, open the slide plate (some models have a little mark to line up the slide plate). Put in the empty bobbin and thread the top normally. Set the machine to straight stitch and push the bobbin wind button in. (This has a bulls-eye symbol on it.) Wrap the end of the top thread around the presser foot screw several times and hold onto the end. Step on the foot control to start winding. Keep winding until the bobbin is full. The thread wound onto the screw should break. Pull some extra thread and cut it to separate the top and bottom threads. Close the slide plate and set your desired stitch.
Other models are wound at the top of the machine. For some of with a drop-in bobbin, you need to bring the thread down to a catch and then off to the left to another catch. Some have a vertical bobbin. I don't remember if they all have a removable case. Those that do need the thread to come through a notch on the case that pulls the thread under a spring that keeps the bobbin tension. However you should check your manual. If you do not have a manual, check if one is available online. (http://www.singerco.com/accessories/instruction-manuals has many of the Singer manuals for sale or download.)
If you post a comment with the model of your machine, I'll give you a description of threading the bobbin or winding one.
Jan 19, 2012 | Singer Sewing Machines
How to wind the bobin on a singer 7050
To get that same thread onto the bobbin, you'll need to windit. Here are the steps:1. Removethebobbin from the sewing machine. If your machine has a free arm, you'llhave to remove this first. Open the bobbin door to reveal the bobbin case, forvertical loading models. If your machine has a drop-in bobbin (horizontalloading) you may have to simply slide the metal plate open, which sitsunderneath the presser foot.2. Lift the latchand pull the bobbin case out of the machine (for vertical loaders). Butfor drop-in bobbins, simply lift the bobbin out of the housing.3. Tip the bobbincase over and let the bobbin fall into your hand. (Some bobbin caseshave a latch on the side, that when lifted releases the bobbin). If the bobbinhas another color thread on it, use a new bobbin. Or, if it's not too muchthread, roll it all off and reuse the bobbin. Just make sure the bobbin youwind begins empty. (But in a pinch, you can wind a new color thread over theold color. Just know that you may have to rewind the bobbin fairly soon, as thedesired color thread finishes faster.4. Place yourselected thread onto the spindle and insert a holder over it, if there is one(usually on horizontal spindles only). Many machines just use gravity toretain the thread, so if your spindle is vertical and you have no such part,don't worry about it. If thisis a brand new spool of thread, you may need to free the end. Look for a smallnotch on one end of the spool. You may have to peel back the label a bit to getat it. Then yank it free.5. Loop the free endof the thread over the bobbin tensioner and any hooks on it. Thelocation of this part varies, but it generally looks about like this. Thread the end of the thread through the pinhole in the top of the bobbin. 6. Press the bobbinall the way onto the bobbin winding spindle. Make sure any springs orclips engage. Put it on so that the end of the thread that you put through thepin hole sticks out towards you (or sticks up, depending on if your bobbinwinder is at the top of your machine). 7. Disengage theneedle mechanism. Many machines have this control in the handwheel. It may require a push, pull or twist of the middle of the hand wheel.Check your sewing machine manual to be sure. The sewing machine may run fasterwhen winding a bobbin than when sewing and you don't want the needle moving upand down wildly. Engage the bobbinwinding mechanism. On some machines, it's done by pushing the bobbinspindle over to one side. You may also need to move the stitch selector to abobbin winding position.8. Hold the free endof the thread and, keeping fingers clear of all moving parts, press the footpedal or knee lever. The bobbin spindle will turn. If you have thebobbin threaded correctly, the bobbin will wind smoothly, evenly, and snugly,with perhaps a slight bulge in the middle. You should cut off the end of thethread you were holding in your hand (very close to the bobbin) as soon asthere's enough thread on the bobbin to hold itself in place so it won't slipout. This will prevent this thread from tangling onto any moving parts.9. Fill the bobbincompletely. It may seem like a lot of thread, but you don't wantto run out too soon while you're sewing. Many machines have a built-in deviceto stop winding when the bobbin is full, often a small blade that automaticallycuts the thread when the wound bobbin is full. If your machine has such adevice, let it tell you how much to fill the bobbin. If not, fill the bobbin nofurther than its edges. Hold the bobbinand case so that they are oriented as shown. Check that thebobbin will unwind in the correct direction. If not, flip it.10. Insert thebobbin into the bobbin case. Pullthe thread under the bobbin tensioner (a thin metal latch). The threadshould advance with a little resistance when you pull at it. Allow this excessthread to just hang. Lift the latch onthe bobbin case and hold it as shown.11. Insert thebobbin case into its housing. Make sure it is all the way engaged (youshould hear it click into place) and that the direction is correct. The bobbincase shouldn't spin and shouldn't come loose when you release the tab. Itshould be locked in. And the loose end of the thread should hang free. Do notclose the bobbin door.12. Re-engage theneedle at the hand wheel, disengage the bobbin winder, and set the machine backtoa straight, forward stitch. Thread the machine with the top thread as usual. Once the threadis through the needle, you must raise the bobbin thread. Hold the end of thethread with your free hand. Turn thehand wheel towards yourself. The needle should go down and back up to itshighest position. One full rotation should do it. The top thread will passaround the bobbin.13. Watch as the topthread pulls the bobbin thread up through the hole in the plate under thepresser foot. Pull the looseends to extend them, and continue to hold them firmly so they don't get tangledas you begin to sew.Closethe bobbin door before sewing.Hope this will help you. Good Luck.
Oct 08, 2011 | Sewing Machines
Bobbin placement we cant get in correctly and it wont pick the bobbin thread up. when trying ti sw it bunches in knots and breaks sometimes
Sounds like the bobbin may not be the right one for your machine. YOu haven't said what make and model this is but you should check your manual or online to ensure you have the correct bobbin for it. I've seen Elna's with Singer bobbins in, they'll stitch okay but then tension problems occur, you need to have the right one for your machine. (if you aren't sure, try looking at www.sewusa.com or www.sewingpartsonline.com to find the bobbin described for your machine.)
Also metal bobbins can get squished if they've been stood on, so have a good look at it and make sure the bobbin is in good shape and looks okay.
Now take the thread off it and rewind a fresh bobbin making sure you've got tension on the thread the whole time and that the thread winds onto the bobbin very smoothly and evenly. This is something that is not emphasied in sewing machine manuals but makes a HUGE difference. Think of your garden hose coiled onto the hose reel. If you wind as the hose wants to go, it goes onto the reel all over the place, then jams up and you can't get it all on there. Look at how a thread spool is wound, the factories wind the thread in a very neat sequence and you want your bobbin to look the same. So always use the tensioner on top of the machine to take the thead around when winding the bobbin. If you don't have one, then put tension onto the thread spool the thread is coming off to ensure the thread runs off at a constant tension and speed.
Carefully watch the thread as it goes onto the bobbin and nudge it with your fingertip to get it to fill evenly top, bottom and middle of the bobbin. Stop when 3/4 full.
Now put bobbin to bobbin holder ensuring that it goes in the right way, always the thread should come off the bobbin and reverse direction in a V shape. Click the thread into the tension spring. Double check it is in there and then thread up the rest of the machine and test sew.
THere is some good trouble shooting tips at www.sewusa.com so this might help you also.
Sep 14, 2011 | Sewing Machines
The thread keeps coming off the needing when i sew
Hello
I would suggest that you revisit the threading up in your manual and double check that the top thread is under tension.
However, if the stitiching on top of the fabric is wonky, this is your bottom tension too loose, and if stitching on the the underside of the fabric is loose, its the top tension causing it.
Quite often bobbin winding can be the cause of bad stitching so pull out the manual and wind a bobbin carefully following the instructions, making sure that the thread is under gentle tension as it winds. What you don't want is for the thread spool to bounce around as it unwinds onto the bobbin as this gives uneven tension of the thread and when you then stitch a seam, the thread relaxes in different amounts causing puckering.
So wind at 3/4 speed, and gently guide the thread onto the bobbin so it fills evenly across the whole core. And ensure there is tension on via a tension guide if your machine has one. If not, then place the curved handle of your scissors onto the top of the thread spool and hold it there as you wind, which holds the spool down and keeps the thread coming off it smoothly.
Always raise the pressure foot when you thread the machine so the top thread goes into tension fully. And new needle for each new sewing job is really important, make sure it is the right size and type of needle for the fabric you are sewing.
Aug 02, 2011 | Brother LS-2125 Mechanical Sewing Machine
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Stiches are uneven & the thread bundles up on the back. I have lost my instruction book, so it is hard to slove the problem. If you could send me a new one, I will pay you for it! Linda P...
you can download a manual from here
http://www.ps2netdrivers.net/heirloom.edition/elna.6005/
If you are getting loops in the thread underneath check your top tension, thread is probably not into the tension discs fully or at all. If you can get at them, clean between the tension discs, turn tension knob to zero, then "floss" between with the selvage edge of a clean piece of cotton fabric to remove any dye buildup or lint. Cheaper threads will shed fibres as they go through tension so best to avoid those bargain bin threads, fine for hand sewing but not so great on the machine long term. If you can't get at the tension discs then consider having a clean and service at least bi-annually to keep them clean as well as the other internal moving parts.
Uneven stitches can be caused by a blunt needle - you should put in a new one for each new sewing project (4-6 hours sewing time) ensuring it is a sharp for wovens or ball point for knits. There is a great guide to needles at http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/
Also review how you wind the bobbin, there needs to be tension onto the thread as it goes onto the bobbin, there might be a silver tension disc on top the thread goes around. Wind slowly, and apply a little pressure onto the top of the thread spool you are winding off - your scissors handle is good. This stops the spool bouncing around causing uneven tension on the thread. If the thread is stretched, then relaxed as it winds onto the bobbin, then it will go back to its normal position in the seam causing puckers.
Here's how I wind - take the thread from the spool across to the tension disc, then back to the bobbin, put thread tail through the hole on the bobbin and hold the tail. Pop bobbin onto bobbin winder spindle and click across to engage. Hold the tail and start winding (might be a button on your machine, or just the foot control), wind just enough to go across the bobbin core and hold the starting point. Stop and snip off the thread tail with your scissors. Restart winding slowly while putting some pressure onto the thread spool with your scissors curved handle into the top (I usually use Guttermann thread and they are tall spools coming up past the top of the pin, this might not apply if using a shorter spool but put some pressure onto it). Watch the thread going onto the bobbin and give it a nudge with your finger tip to ensure the thread fills top, middle and bottom of the core evenly, you don't want it all on the bottom or all in the middle.
Wind until 3/4 full, then stop, cut and remove from the spindle and return machine to normal sewing mode. If you have a mushroom type cap put it onto the thread spool now so the thread winds off smoothly as you sew. Also put a felt circle under your thread spool to assist smooth thread flow.
Also, have you cleaned in the rotary hook? You should brush this out each time you use the machine and refering to the manual, remove the bobbin holder/case and clean under it. All machines will get lint/thread bit build up in the rotary hook and need regular cleaning out to prevent impaired operation. Your machine probably also has a oiling wick under the holder, in a little depression in the middle. Don't touch it but you can give it a drop of good quality clear sewing machine oil every few months. Manufacturers would like you to give the machine to them annually for cleaning/lube etc but you can certainly do some cleaning regularly yourself to prolong machine life and keep it running smoothly.
Also, keep machine covered when not in use, never in full sunlight (plastic will yellow) and not in a damp area.
I hope that these tips help you a little, certainly if you try all the above and the machine still isn't performing as it should, then take it back to your dealer and ask them to test sew and confirm if it needs a service. A good dealer would do this for you ( I usually ring first so I don't get them at a busy time though). I have my machines serviced every two years and clean/oil myself each month in between.
Happy sewing.
May 10, 2011 | Elna Heirloom Edition 6005
Brother CS 8060 bobbin wont wind...but motor runs
no idea... did you lock thread onto bobbin so it holds to wind?
Jul 17, 2009 | Brother CS-8060 Computerized Sewing...
Singer Futura 350
Dear Wendy,
The E4, error message means the safety device is activated. Machine is locked up due to thread entangled with the bobbin case. Remove the needle plate and bobbin case. Check for any thread around the hook area. Also check your handwheel. It should turn freely. Good Luck
Jan 11, 2009 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
141 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
