Get the directions from NetGear, for free, and use their install wizard. Wireless Router It is usually easiest to run the install wizard, but be sure to be ready to set the items listed below. Things to set: Note: Routers are intended to be set by geeks. You have to SAVE EVERY page, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes. 1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is not the security issue. 2. Set a recognizable system ID. 3. Invoke wireless security of at least WEP. a. Assign your own access code, 10 digit home or cell #. Consider taping to bottom of the router. Physical access is not the security issue. 4. Check that your router is set to broadcast its' presence.
Here are the (generic) highlights of what needs to be set:
