Question about Ultra LCD30-500 Television
No picture or sound
Turn on tv. Screen flashes and can see menu script, but then no picture and no sound. Blue light is on noting the power is on. What is the problem????
  • 3 Answers
I HAVE THE SAME THING ON MY THIS IS THE THIRD TIME THAT I FIXED LOOKS LIKE THE SCREEN ITS BURN.
BUT IT ISNT. I PRESS THE ON/OFF UNTIL THIS WORKS. I DID LIKE 3 TO 4 MIN.
IPREFER RESET THE CABLE BOX IN MY CASE. AND CLEAN THE BLCK BOX FOR THE DUST.
Posted on Oct 04, 2008
Lg 42" tv not displaying screen image
The t-con board controls the picture. To test it shine a flash light on the screen abd see if you can see an image when the TV is on. If you do then the T-con board is OK. Look at the back light ballast board (sometimes is part of the power supply board) If you see no movement or a dim picture with the flash light, then the T-con board is gone. You can get parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 11, 2016 | LG Televison & Video
Picture problem
Have you try to unplug the unit for a couple of hour, then plug it again.. thhis is to reset the unit itself..
thank you
May 29, 2008 | Hitachi 55HDT79 55 in. Plasma HDTV
My Samsung TV won't turn on
Please describe the problem more accurately. Flashing red usually means 'stand-by' state, flashing blue/green - starting up. When (during that) do you have a sound? Are there any 'high voltage' sounds like soft screeching from the screen? Is it LCD or LED?
Mar 02, 2015 | Samsung Televison & Video
Philips 42 inch flat screen TV, making a 'tweeting' sound and no picture
Power supply has failed. The blue LED merely confirms that power is getting to the TV.
Oct 03, 2012 | Philips 42pf9966 42-inch Hd-ready Flat...
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
When i turn on the tv there is no sound only clicking sound and no picture. then it atomaticly turns off. also the lamp light flashing red? not sure what is wrong.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 13, 2010 | Panasonic PT-52LCX65 44" HDTV
No Picture, No Sound While Watching
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | RCA L37WD250 37 in. LCD HDTV
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Blue screen with Green Star-burst image in center?
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 19, 2008 | Mitsubishi WD-52725 52". Rear Projection...
No picture or sound
hi guys! i have a tn61x81 and the probleme with this tv is when i plug the tv the tv try to open but shut down y try to push the power botom it's make no difference the light near the power botom is flashing no power no image no sound noting. i think it's the power suply but i'm not realy shure. if aneyone can help me it will be realy apreciate.
Oct 29, 2007 | Toshiba TN61X81 61" Rear Projection...
Televison & Video Logo
125 people viewed this question
Top Ultra Televison & Video Experts
Jaime Hernandez
Vernon Taylor
Are you an Ultra Televison and Video Expert? Answer questions, earn points and help others
