Question about Jenn-Air JMC8130DD Microwave Oven
Our jenn air microwave is 'locked'. Please let me know how to unlock this. I have two hot potatoes ready to go...
5 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Jenn-Air JMC7000 Microwave Stopped working
So it's dead? (No display, no inside lights, no beeps?)
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Posted on Nov 18, 2007
SOURCE: Setting clock on Jenn Air M166 built in microwave
sure..push clock pad twice..set time..push stop/start
Posted on Mar 23, 2008
  • 4088 Answers
SOURCE: HOW TO REPLACE BLOWN FUSE
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
Posted on Jul 12, 2009
SOURCE: The power went out on the microwave
There's a circuit breaker behind the microwave. Yup, that's where
they put it, believe it or not. The microwave and the oven are joined
together so you have to pull both of them out to get to the circuit
breaker. There are screws that hold the microwave and oven to the
cabinet it's mounted in. There should be 4 around the microwave
door and 6 around the oven door. The oven door needs to be
removed to get to the 2 bottom screws. The oven door has a metal
tab on it's 2 hinges that must be pushed down to unlatch the oven
door hinges from the 2 (per side) posts that the oven door pivots
on to open and close. After the door has been removed you can
take out the last 2 screws, you should also remove the vent at
the very bottom of the oven by removing it's 2 screws. Make sure
you have a least 2 strong people to pull the whole unit out, it's
also a good idea to have something sturdy that's the same height
as the bottom of the oven to rest it on after you pull it out. You
don't really have to pull the unit completely out, but it helps. You'll
see the small circuit breaker on top of the oven at the rear of the
microwave, just press it to reset it. Putting the unit back in the
cabinet is the reverse of the removal, but be sure you don't pinch
the armored conduit that contains the gas line for the oven. It'll
probably want to fall behind the oven as you push it back into
place like it did at my friends house. What we did was I pulled it
up and held it at the back of the microwave while 2 guy's pushed
the unit back in. Fortunately, it stayed in place after they pushed
it part way in and I had to pull my arm out of the way. It's a really
crappy place to put a circuit breaker for the microwave. I mean,
come on! You couldn't put it under the microwaves bottom cover
plate? There's room for it there! Anyway, that's how it went at my
friends house. I hope this helps you fix you're problem.
Posted on Nov 24, 2009
Microwave is locked
If this is a problem of the control panel being locked, the instructions are posted on page 9 of the owner's manual. Press STOP/CLEAR, followed by pressing and holding the ENTER/START button for 3 seconds. The lock should clear.
If you no longer have an owner's manual, here is a link to a FREE copy:
http://www.managemylife.com/mmh/owner_manuals/15069/JENN-AIR-Countertop-Microwave-L0606616?brand_name_search=JMC9158
If I'm wrong in my assessment, or if you need further guidance, please post back and let me know. I hope this helps you.
May 09, 2011 | Jenn-Air JMC9158AA Convection Microwave...
My Jenn-aire microwave says locked and has a picture of a padlock. I was microwaving bacon and had just put it some to cook ( my second batch per se) and everything was locked up. I tried pushing options...
Most likely you set a child lock (front panel lock) by holding a button too long (3 seconds). Without a model number, I can't be absolutely sure of the keypad lock for your Jenn-Aire microwave. Usually, the key will have a small padlock icon on it. Press and hold this key. On my microwave you press and hold Start to toggle the lock off.
On a Jenn-Aire JMW2430 and similar models, the Button Lock is activated by a several step process (More and Button Lock). However, pressing and holding the Start button will deactivate it.
I hope this helps.
Apr 19, 2011 | Jenn-Air Microwave Ovens
Says "locked' an unable to use, no buttons work
The child lock is on. Turn off the lock by pressing and holding 0 until the word Locked disappears.
To turn on the lock, press Stop/Clear and then press and hold 0 until the phrase appears.
The manual for the Jenn-Air JMC8130DD is available from http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JMC813&siteCd=JA_EN_US&userType=Consumer .
I hope this helps.
Feb 02, 2011 | Jenn-Air JMC8130DD Microwave Oven
How to unlook a jenn-air microwave JMC8130DDS
push and hold the lock/unlock button until unlock is displayed
Dec 02, 2010 | Jenn-Air JMC8130DD Microwave Oven
My JENN-AIR Microwave Oven stop working, no light is coming in front pennel, I checked power exist in wall outlet, I suspect some kind of fuse blown into microwave oven, my microwave oven make & model...
Hi, my name is Audrey and I am a Jenn-Air employee. I would appreciate the opportunity to assist you with your microwave. Please send me an email through our customer service address,
NAR_JennAir_CustomerExperience@JennAir.com
and type 'Attention: Audrey' in the subject line. Please include your full name, phone number, and model/serial number, and I will look into the issue for you.
Oct 26, 2010 | Jenn-Air JMV8208A Microwave Oven
Cuts off when gets too hot
inside your microwave is a heat censor, if it cuts the microwave off then its to hot for safty have a good look round the back of it to check that the air vents are all clear and that a good air supply can get all around it when its cooking food,,, iv seen so many microwaves tucked away into a small place, and they will all cut out when they get to hot,,,1100 watts gets very hot too!
Jun 06, 2010 | GE JES1142SJ Microwave Oven
Unlock
press step clear then hold 0
Sep 20, 2008 | Jenn-Air JMC8127DD Microwave Oven
Microwave totally shuts off by itself
My microwave is under warranty. I have this problem before and it was "fixed" one month ago by replacing a thermostat. This repaire is under warranty for 90 days.
I will have a service man to look into this problem.
Thanks MK
Jun 29, 2008 | Jenn-Air JMV8196 Microwave Oven
Jenn-Air JMC8130DD Microwave Oven Logo
118 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Dennis Boxerman
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
