Question about Epson Stylus C46 InkJet Printer
Epson c46 hi ya seems all to work and do all the bussiness BUT no ink comes out used the ssc sverice for the count but no joy plz help
  • Gerry Millward
    Gerry Millward May 11, 2010
    Hi 1madman
    It's very difficult to help you if you don't respond to queries. Please post a new comment with the answers requested.
  • Gerry Millward
    Please provide more detail. Does this apply to all colours or just one? If no ink at all comes out (black, cyan, magenta, yellow), did they all stop at once, or was the deterioration gradual. Have you tried a head cleaning cycle and nozzle check print? If so what was the result? Have you tried changing the cartridges? A response to these question will permit me to give you much more specific help.
  • 353 Answers
I think we may post this one as "Solved by the Poster"
Posted on Mar 15, 2009
Hi sir my printer Epson R230 Not working that printer 2 red light blingking please help me
Hi!
your waste ink counter is already counting an overflow.
you may reset your epson printer by using the ssc service utility.
you may download it here: http://www.ssclg.com/epsone.shtml
Feb 22, 2011 | Epson STYLUS R230 InkJet Photo Printer
Green and red light flashing
SSC Service Utility allows you to do many things to your Epson printer, Work directly with CSIC in Epson Stylus printers cartridges, Freeze internal ink counters, Reset internal ink counters even with empty cartridges, Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode, Hot swapping of cartridges supported, Resetting of protection counter (even then it is already full), More then 60 different Epson printers supported This allows many people with high printing demands to save money (program works with both black and color cartridges).
May 12, 2009 | Epson Stylus C43SX InkJet Printer
Power button and tear drop button contstantlt flashing
This usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type, then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. Check the current count value - if it is greater than the limit shown it will confirm this is your problem. Then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is not too difficult once someone explains how to get the case apart!
Apr 18, 2009 | Epson Stylus C86 InkJet Printer
Part inside your printer are at the end of their service life.
This message usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. Check the current count value - if it is greater than the limit shown it will confirm this is your problem. Then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
If you decide to have a go at replacing the ink pads yourself, report back with a new comment to that effect, and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
If this solution helps you, please rate it; if it doesn't, please request further information by posting a new comment.
Apr 05, 2009 | Epson Stylus C46 InkJet Printer
2 red lites blinking no epson c88 printer
If both lights are flashing, it may mean the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can check this and restore your printer to a working condition immediately by using the SSC utility - download from:
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type, then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
If none of this stops the two red lights flashing, you will need to have a technician check your printer - it may well mean the main board has failed.
If this solution helps you, please rate it; if it doesn't, please provide further information by posting a new comment.
Mar 22, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson c62 printer say's parts need replacing, service required
These symptoms usually mean the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C62), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. Check the current count value - if it is greater than the limit shown it will confirm this is your problem. Then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
Feb 15, 2009 | Epson Stylus C62 InkJet Printer
Epson R220 not printing
Sounds like you knocked the vacuum pipe off at the pump cap when you had it apart. Take it apart again and check the vacuum pipe for connection, blockages and being trapped between cases when you reassembled it.
Nov 03, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus photo 810/ink jet printer
Hi Alan
I expect by now you've solved this problem - but just in case .....
The waste ink "protection" counter has exceeded its limit and needs resetting. You can do this easily by using the SSC utility - download from:
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (810), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
May 17, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson stylus photo 820
Hi Ikarp9090
If both lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (820), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
Apr 29, 2008 | Epson Stylus Photo 820 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
51 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
