Question about HP Deskjet 3845 InkJet Printer
When I try to print I get message that says problem with black ink cartridge remove and reinsert if that doesn't work use the cartidge cleaning cycle. Neither of these solves the problem. The green light on the printer constantly flashes. When I use the clean the cartridges feature I still get the error message. HP Deskjet 3845
  • 45 Answers
Clean the cartriage terminal with cloth the problem is cartriage can't communicte with printer properly
Posted on Jan 01, 2011
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Epson printer will not print any copies. I get the message "change cartridges 98/99." I did change both cartidges and can't clear the message and print copies.
i assume that everytime you try to print you get the same message. i sometimes get cartridge unrecognised on my epsom. I have to remove the cartridge, wipe the chip on the cartridge and reinsert.
If this doesnt work please specify printer model and if using original epsom cartridges.
Nov 15, 2011 | Office Equipment & Supplies
Unable to align cartridges on Canon Pixma MP600 all-in-one printer. When trying to print many black streaks obscure printed area.
This sounds like a printhead problem.
The first thing I would try is to clean the printhead. Remove the cartridges and store them (stretch a piece of plastic electrical tape over the ink cartridge hole to keep the ink from drying out).
Remove the printhead and set it in warm distilled water and let the printhead sit overnight.
Remove the printhead from the water and blot the water with a clean lint free dry cloth (do not rub the printhead and contacts, or damage could occur. Set the printhead aside to air dry.
Once the printhead is dry, reinsert the printhead, remove the tape from the ink cartridges, reinsert the ink cartridges. Test print. This should clear the problem.
We can try a more aggressive cleaning solution of the distilled water doesn't clear the problem.
Let me know if you have any more questions. Thanks.
May 18, 2011 | Office Equipment & Supplies
"wrong cartridge"- Printer is giving us a "wrong
Hi Sherri
I am having the same problem with my MP780 mine started doing the same thingafter deciding to use Calidad inks the large black ink leaked into the yellowink (stick to canon inks).
What I have done so far with no success -
Replaced the ink cartridges with new ones supplied by Calidad, still the sameproblem.
Removed and cleaned the print heads manually and to my surprize after soakingin warm water and multiple cleanings for over 1hr black ink is still coming outof the yellow ink head.
I still get the same message after all I have tried...
One thing I did manage to do is prime the yellow ink and got it flowing throughthe head again but it's still mixed with black... I wonder if you may have runout of magenta and dried the head...
Try priming the magenta ink by removing the head (don't touch or wet the metalcontacts at the rear, the ink heads are on the bottom) place on a clean lintfree cloth (or I just used damp tissues then dry tissues) you should get onelong black strip and two cyan, two magenta and two yellow strips on the tissue,if you do not then try priming by replacing the magenta cartridge and gentlypumping the cartridge up and down repeat until you get the ink flowing.
Replace the head and cartridges, press ok, turn the printer off then reset.
Let me know if it works or if you come up with another solution that works as Iam still trying to figure out how to fix mine.
Good luck
Dec 21, 2010 | Canon PIXMA MP780 All-In-One InkJet...
HP Deskjet 5740 I have not used my printer in some time and both cartridges are half full. It printed with the black but came out with gaps in the printing so i took the cartridge out and put it back...
it is better to change the black cartige becaue there is the jam of the ink in black cartidge. or pick out the black cartidge and clean with soft paper in the place from where color is pour. then reinstall the cartidge. i hope it will ok. otherwise, change the cartidge.
byee
May 09, 2009 | Office Equipment & Supplies
Compatibility of Ink cartidge.
The MP600 does not use the 40 or 41 cartridges, it uses individual color (and black) ink tanks. But other models (MP190, MP460, MP470, etc) do use these cartridges. The error message you are receiving indicates that the printer does not recognize the cartridge you installed as a valid black ink cartridge. This can mean that either the cartridge is faulty, or that the printer has a problem.
I would suggest trying another new cartridge, and if you still get the same error, to contact Canon for support options if the unit is still in warranty.
Oct 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Bought today a hP7200 All-inOne Series. Set up and received the following: Error message "Incorrect Ink Cartridge: The following ink cartridges cannot be used after device initializaed and must be...
hi friend
try remove your printer cardige & rinstall it if u have not remove your printer cardige nosel raper so remove tape of the nosel try to install & print
Apr 13, 2008 | Office Equipment & Supplies
Printer is not printing black
Remove cartridge and remove the mains from the wall.
Try cleaning the contacts with a cloth dampened WITH WATER, wipe it up with another cloth and let dry.
If your old cartridge is not working again, try with a new one, generally is the cartridge which may become damaged, not the printer... hope !
Dec 31, 2007 | Lexmark X1150 All-In-One InkJet Printer
My Hp PSC 1350v
Hi, I really appericate all your efforts to fix the issue the issue usually occures if any one of the cartridge is defective or low in ink or both the cartridge are defective. We can isolate the issue only by removing the both the cartridges out of the printer and check for the expiry dates printed on the cartridges as if the cartridges are expired also leads to this message. If the cartridge are not expired and have minumial ink in it you can try the below procedure to isolate the defective cartridge Once the both the cartridges are out of the printer insert only the black cartridge in the printer and check for the message if the message is install color cartridge the black cartridge and printer is detecting fine. If the message is check right cartridge this shows that the black cartridge is defective. If the message is insert left cartridge or color cartridge remove the black cartridge out and insert only the color cartridge and check with the message if the message is insert the black cartridge the color cartridge is working fine. And when the color cartridge is in the printer and if the message prompts to check left or color cartridge the color cartridge seems to be defective so replace the defective one will fix the issue So in isolation we can find the defective cartridge and fix the issue by replacing the defective one.. Hope this will help you to fix the issue.. Wish you success. Regards, Barret.
Sep 12, 2007 | HP PSC 1350 All-In-One Thermal Printer
Canon MP780 didn't report out of ink and now will not pring blanck
Have you tried cleaning or aligning the heads? Were the first cartridges refills? when an ink cartridge is refilled (depending on the model) the printer needs to be tricked into thinking a "new" cartidge is being installed. You may need to check the owners manual to see if the is the case. I have had to use tape to block off certain contacts, then remove the cartidge and block off another section of contacts, then remove tape all together and re-insert the cartridge.
Jan 27, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP Deskjet 3845 InkJet Printer Logo
139 people viewed this question
Seeker5211
Seeker5211
