Question about Whirlpool 24 in. GU1500XT - Multiple Color Built-in Dishwasher
The dishwasher won't fill up with water - Whirlpool 24 in. GU1500XT - Multiple Color Built-in Dishwasher
  • 11,896 Answers
This can be caused by a couple different things. Either the water valves are not getting power or are faulty not allowing water to enter. Or if water begins to enter but quits, then the water level sensor could be bad. Lastly the timer on the control board could be faulty but can be tested with a meter.
Posted on Dec 31, 2010
My dishwasher won't fill with water. and keeps running even when the door is open.
A defective switch may interfere with your dishwasher's filling ability. Yourdishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem.
Dishwasher Repair Guide - Dishwasher won't fill with water..
or try this link..
dishwasher won fill with water Google Search
Oct 27, 2017 | Dishwashers
Bosch dishwasher SHE46C06UC won't fill with water
Check water inlet. Check for kinks in hose. Check the inline strainer in the fill solenoid. You say it makes an attempt to fill, is this because you can hear water trickling? If so I would suggest get to g the fill solenoid replaced as it may be blocked or not opening fully
What is the float switch
I have no real experience with float switches on dishwashers, but have with some in humidifiers. It's a piece of styrofoam on a narrow metal stick that lifts when the appliance fills with water & lowers when the water empties. If this gets stuck on something, like a dishwasher rack, the unit won't fill or empty the water & the cycles won't work properly. Take a look & see if there is such a thing hung up somewhere in the dishwasher. If you can loosen it, your dishwasher should work again.
Feb 21, 2012 | Beko 24 in. D3421F Free-standing...
Boscsh shu3322uc dishwasher won't fill. If I put
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 09, 2011 | Bosch SHU3306UC Built-in Dishwasher
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Kenmore Dishwashers
Bosch SHX46AO60C/30 won't fill with water. Have check water under sink - it is on. Motor will run, but no water. Have tried all cycles.
Hi
Daniel
Aug 29, 2011 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher comes on but it won't fill.
Hi
Daniel
Aug 21, 2011 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Hello my tricity bendix dishwasher won't take in water, it will pump it out and when I turned water off at the mains and disconnected the water pipe and put it in a bucket turned mains back on the...
Hi
Daniel
Aug 11, 2011 | Tricity Bendix 24 in. DH102 Free-standing...
Unit won't fill with water
Hi
Daniel
Aug 01, 2011 | Bosch 24 in. SGS43C12 Classixx...
Whirlpool 24 in. GU1500XT - Multiple Color Built-in Dishwasher Logo
119 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
