Question about Samsung Yepp YH-J70 Digital Media Player
Hi My battery runs down after half an hour It seems it needs a new battery, are they easy to fit? or do I need to send to Samsung. Thanks P
  • 11,896 Answers
Yes sounds like you need a new battery. Some are soldered in, others have a wire clip that can easily be removed and replaced.
Posted on Dec 31, 2010
Pride jazzy 1120
Page 44 of the manual for your chair specifies size NF-22 batteries if the power seat option is installed, otherwise size Group 24 can be used. (See this battery size table.) You should use batteries with the highest amp-hour rating that will fit and you can afford; the amp-hour rating determines how long you can run on a full charge. Evidently the power seat mechanism takes up space needed for the Group 24 (79 Amp-hour), so you have to go to the somewhat smaller NF-22 (55 Amp-hour). Don't mess around with a 50 Amp-hour battery at a higher price when the 55 A-hr units will fit.
Dec 02, 2013 | Health & Beauty
New Samsung Galaxy Note 10.0 battery life and charging time
Sounds normal to me!!
The further away from wifi router you are the more power is needed by the wifi card.... etc etc so the 8 hours is in perfect conditions with the screen brightness at minimum and no apps running!! It's safe to say that, whatever battery life is quoted for any device you should only expect to acheive half that in the real world.
The screen is prob responsible for 80% of the battery's power drain. Turn the brightness down. Stay in same room as router. close down un-used apps that demand cpu and network (wifi card) time.
Shut it down completely when charging don't just let slip into standby. Also don't charge it on a cold or hot place such as a window sil. To high or low tempretures will increase charge time and will damage the battery lowering it's capacity.
May 30, 2013 | Samsung Galaxy Note 10.1
Hi there i just bought ASUS,X42 series laptop but it seems the battery can only last for an hour.please i want it to last longer,how many hours should charge cos it a new o laptop i just bought..thanks
The battery should be charged overnight ie for approx. 10 hours.
When the battery runs down then charge it up again until it is fully charged, you may need to do this several times until the battery reached it normal capacity.
Jul 23, 2011 | Computers & Internet
Hi my battery only lasts up to an hour, how do i
Well it should last between 3-4 hours if new. <br /><br />Batteries need conditioned . You fully charge them and then run them fully down. 1 hour seems pretty short. As a rule, don't run them on battery while plugged into power.<br /><br />I have no better solution than this.<br /> <!-- from fixya rte -->
Aug 17, 2010 | HP Pavilion zd8000 Notebook
Battery does not seem to hold charge on Advent 9115 laptop. 18 months old. Charged overnight. Switches off within half hour of switching on.
Sounds like your battery is dying.
Laptops should not be run on mains power all the time, it kills the battery. Should be run on battery until battery warning occurs, then plug in to recharge.
You'll need a new battery at this stage.
Apr 04, 2010 | Computers & Internet
3 month old new phone. samsung tocco lite. battery problem
1) faulty battery - you'd need to get a replacement from the manufacturer (should be free if still under warranty)
2) when you initially charged the battery after purchasing, if you used it at all before it was completely charged it won't hold a charge.
3) if you live or travel in mountain area, phones lose battery power quicker due to an increase in elevation and distance from nearest tower.
4) if phone has been exposed to moisture or direct sunlight for an extended amount of time, it can damage the phone's ability to hold a charge.
honestly, your best bet is to replace the battery & allow it to charge for 24 hours in "off mode". if the problem persists, then send it in to be repaired.
Mar 19, 2010 | Lands Phones
Zen Vision M battery not charging
The problem was partially solved in that I put my old battery back in and at least it charged properly. I did receive a new battery from BatteryMill and I fitted it and left it charging for 5 hours. However, when I unplugged it to see if it had charged at all it did the low battery thing and then when I tried to recharge it the battery fully charged symbol ame up. I suspect that had I left the new battery charging for say 24 hours it might have charged fully. However, I have decided to send my batteries back and get a refund. The problem must be something to do with a battery memory problem.
Jul 31, 2008 | Creative Labs ZEN Vision:M Digital Media...
Hi. My samsung G600 is playing up. In the past half an hour it keeps turning itself on and off. The battery is fully charged and I have turned it on and off myself a few times but still the same outcome....
The problem you have is software related and you will need to send it back to samsung who will sort it out, or if you give samsung a call they will tell you where the nearest samsung repairer is , my local one is in the carphone wharehouse, they told me it would take about an hour and a half , or i could leave it there and borrow a temp phone and pick up at my conveniance.
May 28, 2008 | Cell Phones
Samsung G600 - delivery reports
hi,
you need to go to messages > settings > text messages > sending options and then check the "request delivery receipt" box. however, it seems there may be a problem as many people have requested delivery reports and yet do not seem to recieve them.
hope that helps!
Dec 16, 2007 | Samsung SGH-e315
Samsung Yepp YH-J70 Digital Media Player Logo
81 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
