Question about Thermador C301U Electric Single Oven
Where can I purchase a new LED display for my thermadour built in oven?
  • Thermador Master
  • 2,605 Answers
Welcome to FixYa.
The issue with these displays is they can lose their intensity over time, but also it can be contributed to the main control...specifically the transformer on the "C" series ovens, hence the only remedy is to replace the control/display kit.
I'd first suggest checking the main control if you feel you are capable, this is how...
1) Turn the breaker or power supply to the oven off while servicing...saferty first ( though you will need power to check the transformer, this is where an experienced tech may be necessary, you'll need to decide )
2) locate the control board behind the display ( this will require either moving the front panel or the top panel behind the display...in the plenum )
i.e.
Then identify the PCB/control board...
The large arrow identifies the main control, the small arrow is the transformer location on the board
3) Remove the control or place it at a vantage point you can perform the following voltage checks, this is where some experience or electrical knowledge comes in handy...
i.e.
where can I purchase a new LED display for my - macmarkus_195.jpg /> macmarkus_195.jpg
If the values listed in the test chart all are o.k. then you need a display only...if not you'll need the control board. ( Before you ask, I don't know of any transformer supplier...but then you're gambling nothing else is defective on the control anyway, not worth it in my opinion, that's your call )
Now to answer your question about availability though, one can find these "display's" at "repairclinic.com" for around $225USD and includes what I've attacwhere can I purchase a new LED display for my - macmarkus_193.jpg>
The "PCB" or control as it is referred to as wewhere can I purchase a new LED display for my - macmarkus_196.jpgble at said location for around $175USD, it will include this...
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
Posted on Dec 31, 2010
I have a Bosch oven with the "key" sign constantly lit and the oven won't function at all. Re set it at wall etc.
the key sign shows that the child lock is engaged. to unlock, usually you push and hold the lock button for a few seconds. the correct button is usually a dual function and so marked. if you need more help, go to manualsonline.com and look up your model number for your manual. good luck
Dec 27, 2015 | Bosch Ovens
Good Evening, My mum purchased a kupperbusch built in oven over 15 years ago. The grill is no longer working and fan has gone. I will like to purchase a new one the same size. H 89cm W 556.5 would this...
Most ovens are based on a modular 600mm width cupboard dimension. Heights can vary but that not so much of a problem so you should be ok with most new ovens.
Check on suppliers websites for details.
Dec 09, 2010 | Kuppersbusch Ovens
The led display lights have dimmed so much I can't read the. THis is a built in double oven - Kenmore. not sure of the model #
you will need the model # to get the correct control panel for this range . the display has failed and ony repair is to replace it . part # may be on control . and inside the control area there should be a tec sheet with this info .. mm hope this helped ..
Jul 11, 2010 | Kenmore Ovens
The Oven LED display does not work even though all the functions of the oven work.
You simply need a new LED board and these parts are very easy to replace.
Oct 19, 2009 | Jenn-Air JMW9530C Electric Double Oven
Gaggenau EB290 built in oven - F10 code
If you really cannot find in manual, contact the manufacturer for guidance.
Aug 27, 2017 | Gaggenau EB290/291 Oven
Dislpay is blank but oven works
HI, you will need to replace this faulty ECC. the chip set that is soldered on this board is damaged as well as the led display. replacing the Electronic Clock Control will fix this issue.
the control board is fine and this explains why the oven is still functional. its the ECC that is faulty.
Click here to purchase your new ECC online.
May 25, 2009 | Whirlpool RBD305PD Electric Double Oven
Display on my Jenn-Air electric wall oven is very dim
douglas9101,
I had the same problem and found the solution on-line.
Replace the C3 capacitor on the dispaly module. (100 UF, 35 volt, high temperature)
The local Jenn Air dealer wanted $211 for a new display module.
I purchased a Cap from a local electronics supply store for 79cents.
The only problem is that you need to have a soldering pencil/iron, a solder ******/wick and a small amount of solder.
Steps I had to take on my oven:
- Flip the AC breaker supplying the oven to off to be save
- remove 3 screws on top and 4 on the bottom of the display panel
- gently pull out the display panel and unplug the 2 cables to the display
- unclip the ribbon cable to the display module
- unclip the module itself by pushing on the 2 black tabs
- locate C3
- unsolder C3 and replace with new Cap- keeping the polarity strip the same as theh old Cap
- reasemble in reverse order.
It took me all of 20 minutes. It may sound difficult but is very easy if you have the tools
Good Luck
K
May 11, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Dim LED on SC301 Thermador
local part whare house can sell you a "dim clock" kit for your machine i believe it contains a new display board as well new wire harness
Mar 14, 2009 | Thermador SC302T Electric Double Oven
Thermador C301U Electric Single Oven Logo
210 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Thermador Oven Expert? Answer questions, earn points and help others
