Question about Timex (T307S) Clock Radio
Set nature sound alarm clock - Timex (T307S) Clock Radio
  • cc39 Jul 10, 2008
    how to set nature sound alarm clock or obtain instructions for same? Caroline3
Hold 2 clock button til it blinks. then set time u want with arrows
Posted on Apr 08, 2009
Download the alarm clock
Posted on Apr 05, 2009
Instructions
From the manual:
Setting the Clock
1. Press and hold the Time Set Button until the display begins flashing
2. Press the Reverse or Forward Button to set the time. Holding a button for a few seconds will advance or reverse the time rapidly. Set the correct AM/PM time, shown by the PM Indicator on the display
3. After setting the time, press the Enter Button or wait about ten seconds for the unit to beep twice and the display to return to the normal mode
Setting the Calendar (It is important to set the correct date in order to use the 7-5-2 Alarm settings)
1. Press and hold the Date Set/7-5-2 Button until the display flashes and the year replaces the month/day at the bottom of the display
2. Press the Reverse or Forward Button to set the correct year, and then press the Enter Button. The unit will beep and the display will show the month and day. Again, press the Reverse or Forward
Button to set the current date
3. After setting the date, press the Enter Button or wait ten seconds to return to the normal display mode
Setting the AM/FM Radio Alarm
1. Press and hold the Radio Alarm Button until the settings and radio frequency appear on the display.
2. Press the Reverse or Forward Button to set the alarm time.
3. Use the AM/FM Band Button or the Memory Set 1-6 Buttons to select a radio station to wake up to. Adjust the alarm volume using the Volume Thumbwheel
4. After setting the wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, Monday through Friday, or the weekend. Before setting the alarm, be sure that you have set the date, as shown in the Setting the Clock and Calendar section. While the display is still flashing, press the Date Set/7-5-2 Button until the desired setting is shown at the top of the display.
5. After you have programmed the radio alarm, press the Enter Button or wait ten seconds to return to the clock display. The Radio Alarm Indicator will appear on the display, showing that the alarm is set.
Setting the Nature Sounds Alarm
1. Press and hold the Sounds Alarm Button until the settings and Nature Sounds Indicator appear
3. Use the Nature Sounds Button to select a nature sound to wake to. There is a choice of four sounds:
Sound #1: Ocean Surf
Sound #2: Forest Spring
Sound #3: Rushing Brook
Sound #4: Summer Wind
5. After you have programmed the nature sounds alarm, press the Enter Button or wait ten seconds to return to the clock display. The Nature Sounds Alarm Indicator will appear on the display.
Setting the Buzzer Alarm
1. Press and hold theBuzzer Alarm Buttonuntil the alarm setting appears on the display.
3. After setting the wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, Monday through Friday, or the weekend. Before setting the alarm, be sure that you have set the date, as shown in the Setting the Clock and Calendar section. While the display is still flashing, press the Date Set/7-5-2 Button until the desired setting is shown at the top of the display.
4. After you have programmed the buzzer alarm, press the Enter Button or wait ten seconds to return to the clock display. The Buzzer Alarm Indicator will appear on the display, showing that the alarm is set.
Dec 06, 2013 | Timex T309TT Clock Radio
How to set alarm on timex t425s alarm clock radio with nature sounds?
T-425s or t425-a-a-(s) by Timex: rotate the clock so the snooze button is on top. The display will show the sun go down and turn on the alarm.
Jan 03, 2012 | Audio Players & Recorders
How do I keep the alarm from flashing? I just want to turn off both alarms. Timex nature sounds with cd T621T, Thank you
Hello, To turn off the alarms follow these steps -
  1. After the alarm sounds, press the "F" alarm off/reset button to shut the alarm off but retain the 7-5-2 alarm settings.
  2. If you want to turn the alarms completely off and cancel the 7-5-2 settings, press the "alarm" button so that the "alarm" indicator is no longer visible. As long as you can see the word "alarm" on the display the alarms will continue to go off according to your 7-5-2 alarm settings.
Regards, Tony
Mar 24, 2011 | Timex Nature Sounds LED Clock Radio
How do I set the date? Can I change the nature sounds? If so, how?
http://www.timexaudio.com/pdf/T307_IB56281_07.pdf
http://docs.google.com/viewer?a=v&q=cache:b3JlsvNt-jIJ:www.timexaudio.com/pdf/T307_IB56281_07.pdf+Timex+%28T307S%29+Clock+Radio+manual&hl=en&gl=us&pid=bl&srcid=ADGEESjCJY6I7b2_7dqw17lMLwt7MQ5ssTxTvFwZBJAhOnAB--2T_4o8GkvD_5JkLhMvCKz6vzCiBCEGD1JRbOVLqw10IQjoVLqbJ9AU3gFE_IHQD_PfOaL75eEO69gUwnaDxgHY8pTo&sig=AHIEtbQpJelj9gHaRYQER4ZbJnXi7PALgw
Using the above linked manual. (if the first link doesn't work, try the second)
Instructions for setting the date are on page 7 and a reference diagram with labeled buttons is on page 5.
On page 8 of the linked manual, there will be instructions for setting nature sounds. A diagram with labeled buttons can be found on page 5.
Here are the directions for setting the nature sounds:
1. Press and hold down the 'alarm 2' button until the 'alarm 2' display comes up
2. Press the reverse or forward buttons to set the alarm time.
3. Use the Mode/DST button to choose sounds. There are five to choose from:
  1. Ocean Surf
  2. Birds
  3. Brook
  4. Wind Chimes
  5. Buzzer
4. Press the enter button or wait 10 seconds to confirm.
Mar 07, 2011 | Timex (T307S) Clock Radio
How do i set the time on my timex clock? its the nature sounds alarm clock pleas help
press the time button and hold until the time starts to blink then use the < > to change the time then press Enter to set the time.
Nov 13, 2009 | Timex Nature Sounds LED Clock Radio
ALARM CLOCK SETTING
I've manage to set it... press time/awake and the 1 flashes... use arrows to set the time... then press time/awake again for alarm 2.
But how do you know when it is actually set?? it did not go off this morning and i was late for work!
Mar 14, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Instructions; TIMEX Alarm Clock Radio w/CD Player & Nature Sounds
Go to timexaudio.com, select SUPPORT, then select PRODUCT MANUALS.
Jan 25, 2009 | Audio Players & Recorders
Lost manual for a timex t307s
Setting the Alarm 1 for AM/FM Radio
1. Press and hold the 2 Radio Alarm 1 Button. The display will flash and the Radio Alarm Indicator will appear. If
you do not begin setting the time within ten seconds of pressing the button, the display will stop flashing and you will
need to press the 2 Radio Alarm 1 Button again.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the wake time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, while the display is still flashing you will need to select the station. First, press the
L Mode/DST Button to select a radio frequency. Next, select a station using the M Memory Set 1-6 Buttons. For
more information on programming radio stations into memory, see the Programming Radio Station Settings section of
this manual. Rotate the O Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you
set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date
is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual. While the display is still
flashing, press the 9 Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the 4 Enter Button. The Radio Alarm
Indicator
will appear on the display, showing that the radio alarm has been set.
Setting Alarm 2 for Nature Sounds/Buzzer
1. Press and hold the 7 Nature Sounds/Buzzer Alarm 2 Button until the Alarm 2 settings and Sounds Alarm
Indicator appear on the display.
2. Press the 1 Reverse or 6 Forward Button to set the Alarm 2 time.
3. Use the L Mode/DST Button to select a nature sound or the buzzer to wake to. There is a choice of five sounds:
Sound #2: Birds
Sound #3: Brook
Sound #4: Wind Chimes
buz: Buzzer
4. See Note #4 in the Setting Alarm 1 section for instructions on setting the 7-5-2 alarm setting for Alarm 2.
5. After you have programmed the Alarm 2 settings, press the 4 Enter Button or wait ten seconds to return to the clock
display. The Sounds Alarm Indicator will appear on the display, showing that the alarm is set.
Nov 18, 2008 | Timex (T307S) Clock Radio
Setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
Feb 25, 2008 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Set Clock
This clock has 2 alarms to set Alarm 1, switch alarm 1 to the "set" position and make sure alarm 2 is pushed to the "off" "radio" or "cathedral" position, press and hold the "alarm" button on top while pressing the "f.fwd" or "rev" button to set the alarm....to set Alarm 2, do the opposite of the set buttons and repeat...to set the time just hold the time button down while pressing "f.fwd" or "rev"...hope that wasn't too confusing.
Jan 01, 2008 | Timex Nature Sounds LED Clock Radio
Timex (T307S) Clock Radio Logo
268 people viewed this question
Top Timex Audio Players & Recorders Experts
Greg Cann
Greg Cann
Gyula Lacz
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
