Question about Sony WEGA KDE-50XBR950 50 in. Plasma HDTV
My Sony WEGA KDE50XBR950 began to display the following error message: Fan Problem - Shutting Down, and then automatically shut down after a minute or 2. Is this a standard message when the fan stops working or might there be other issues? The manual for the TV did not provide any information on this topic. Thank you.
  • Bill Sep 26, 2012
    I have the same model color is starting to go, no idea what it is ? TV is 10 yrs old willing to sell for parts
    Problem Solver:
  • 4 Answers
I had this same problem last wk. It is either the heat sensor or the fan problem. My was the heat sensor and I took it to a local TV shop and they replace it for $250. For such a good TV, it is worth the $250 to fix vs. trying to buy a new one of such quality for $1000, that may not even have such as good pictures.
I bought a new 60LG 1 month ago for $2200 and it is no where as goo as this old 720P Sony in picture quality.
One question, do you still have the original TV stand that come with this TV? If you are not using it, I would like to buy it from you. I mounted the TV originally, but now want to take it off the wall and use a TV stand in another room. Please email me at ib1kid@yahoo.com
Posted on Jan 29, 2011
Powerlite 77c keeps shutting down
Hi Dave,
have you inspected the led indicators after shutting down .
it must flashing and indicating pattern.normally epson have 3 LED indicators.
please come with blinking pattern or google it.
i think it is bulb problem,
regards,
nuwan
Jan 13, 2014 | Epson PowerLite 77c Projector
At power on, displays F61 code and switches off
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C. from overheating.
If confirmed that the fan is working then I've suspect that your output I.C./pre-amplifier circuit is faulty.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
Jan 21, 2011 | Panasonic SC-HT75 System
I HAVE A PANASONIC CD STEREO SYSTEM AND THE DISPLAY SHOW: F61; WHATS THE MEANING???
If confirmed that the fan is working then I've suspect that your output I.C. is shorted.
Pls rate my help.
Jan 17, 2011 | Audio Players & Recorders
Pavilion dv7 keeps shutting down
  • This may not fix your issue but its worth a try ...let me know how it goes
  • If the computer appears to shutdown and then attempt to restart without displaying an error message, do the following to disable the automatic restart on error setting.
    1. Click Start , right-click Computer , and then select Properties .
    2. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
    3. Click Settings in the Startup and Recovery section of the Advanced tab.
    4. Deselect the Automatically restart checkbox under System failure .
    5. Click OK to close the Startup and Recovery window, click OK again to close the System Properties window, and then close the Control Panel window.
    6. Restart the PC.
    Disabling the automatic restart setting allows time to view the error message that displays on the screen. Contact the manufacturer of the program or device that is causing the error for specific information about the error message.
  • Jan 21, 2010 | HP Pavilion DV7-1232nr Notebook
    PC keeps shutting down and then re-boots automatically about every 20 minutes .
    Shut it down.
    Remove the power-cord.
    Buy a can of compressed air ($3 to $5).
    Remove the side panel(s).
    Hold the can of air vertically (do not tilt it),
    and blow away the dust from everywhere: inside the power-supply,
    between the "blades" on the heat-sink & fan on top of the CPU.
    Replace the side panels.
    Reconnect the power.
    Start it up.
    Click Start
    Right-mouse click on My Computer
    Choose Properties
    Choose Advanced.
    Under "Startup and Recovery", click "Settings".
    Click to disable "Reboot Automatically".
    The next time that it crashes, what error-messages _stay_ on the screen?
    Oct 10, 2009 | Microsoft Windows XP Professional for PC
    Same problem - tv shuts down
    Sounds like you've got a problem alright, It's definitely heat related. I would suggest unplugging it and having it looked at by a professional.
    I am an electronics tech and can tell you that you should not try to fix it yourself. There are voltages inside that tv that can literally throw you across a room and kill you instantly,
    Also, I advise leaving it unplugged until it is looked at, A short can cause a fire.
    Sep 30, 2009 | Sony KV-36XBR400 36" TV
    55" TV keeps shutting off automatically
    Green light flashes 5 and then red light flashes 6
    Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
    Boot Error Shutting Down Sony NWD-B103
    down load teh latest firmware from following link & update your player...............cheers....!!!!!!!!!!!!!!
    http://www.sony-asia.com/support/download/product/nwd-b103f/modelfirst
    Sameera
    Apr 23, 2009 | Sony Audio Players & Recorders
    My Sony flat screen when first turned on will run just fine for about 30 minutes. Then it will start turning off and on about a dozen times, be ok for about 20 minutes and do it again. I finally just turn...
    You might be able to see what is shutting the set off. Sony models employ a memory for failures. When the set is off push: Display, 5, Volume down, Power. Make sure your push all within 1 second. The set should come on with a display of the errors. A list of items followed by 0 ro 1. anything with a 1 has shut the set off. With that info at least you will know going to a Sony repair center what you can expect to pay or at least have a better idea.
    Mar 25, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
    TV shuts down and blinks red 6 times
    Lamp or Fan is going bad.Take lamp out see if it looks good if so listen/watch to see if Fan keeps runningwhen turned on if Fan stops running ,Lamp and power will not come on.!
    Nov 13, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
    Sony WEGA KDE-50XBR950 50 in. Plasma HDTV Logo
    247 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
