Question about Dell Inspiron 600M Notebook
Computer wont load past the windows logo
I recently replaced my hard drive in one laptop with another hard drive from my other laptop. I also exchanged the screens between the computers. I used the Windows XP operating disk to repair the oeprating system but that didn't solve the problem. I can access the drive in safe mode but I can't get to the internet. I lost the drivers for the wireness network adpater and you can't reinstall in safe mode.
HELP!
    Genius:
  • 2,028 Answers
Instead of doing a system repair, wipe the hard drive, reformat (NTFS), and reload the operating system. Then you will need to go to Dell's support site and download the drivers. You already know that you can't do installs from safe mode, only under normal operation, so, if the reload doesn't take, let me know the details as to why or what it's doing and I'll see if I can narrow the problem for you.
Posted on Jul 08, 2008
Laptop doesnt boot past logo
While the computer is powering on, tap the F8 key until you get a menu. Select Safe Mode w/networking and see if that allows you to log in. If yes then you will need to determine whether or not you updated a driver recently and roll it back. This is where I would start. If it doesn't boot into safe mode then you may be looking reinstalling Windows.
Jul 12, 2015 | Gateway Computers & Internet
Cant flash bios a1410n
Try simple first. When booting, AND BEFORE the XP logo, press f8 repeatedly until you see the boot options menu. If you miss it, you will see the xp loading logo, if so, restart and try again. From the boot menu, try the "boot with last known good configuration" option. If that doesn't fix it, re-boot, f8, and try the "safe mode" option. If it boots with any of these methods, do a full shut down and re-start again normally.
If that doesn't get it to boot normally, I would do the following. (I would, but you should only try this if you have a good understanding of windows and needed programs installing, ram replacement, hard drive repair/replacement and internal computer wiring)
Now, if your computer worked fine, then suddenly started this loop, I dont think it a bios problem. I expect you might have a hardware problem. Did you change any hardware very recently? Sometimes that stops windows from loading. Or, you could try changing the ram and retry, could be bad ram. But I think it is a hard drive issue. I think you will have to reload windows and/or replace the hard drive.
To safeguard your info, you should replace the main hard drive with another drive, load windows fully on it, then add the original drive back in as a slave/secondary drive, and retreive your personal info and files from it. Your needed programs will have to be re-installed on the newer windows drive. When you get all your files copied over (use copy and paste, not cut and paste), you can format the old drive and use it as storage, or just format and keep for the next time, or sell it. I would also run a "drive fitness program" to test it for bad sectors.
Or, if you dont need anything from your windows, you could format and install from the xp install cd. If it loads and runs, the drive is probably ok (I would still test it for bad sectors), or, if it cant load because of errors, the drive is probably bad. Retry with a new drive.
Jul 16, 2013 | HP Pavilion a1410n (ER890AA) PC Desktop
Mine wont go past the "start computer normally" or
It could be a failing hard drive. Typically, if it keeps happening that is where the issue may be. It could be a video driver, or another driver too or a recent windows update.
Oct 31, 2010 | Acer Aspire 7520-5757 Notebook
Compaq Presario C-500 powers up but can not get past the Compaq LOGO Screen. Tried removing battery, Control/Alt /Delete Suggestions?
This sounds like a hard drive issue. Let the computer run for about five minutes and touch the bottom to see if the laptop is getting hot. If it is extremely hot, then a fan will need to be replaced. Overheating of laptops is the number one cause for hard drive failure. If the fan is replaced, then the hard drive might still be good.
Also, you may have had a virus, which is what is keeping you from booting into the Windows environment. You will need to reformat the computer but will loose all information if you do this yourself. If you are running Windows XP, you will need to purchase a restore disk from the manufacturer. If you are running Windows Vista or 7, boot the computer on and immediately (before the Compaq logo comes on) tap F8. Choose advanced options and choose to factory restore the computer. As mentioned, this will completely erase the hard drive and everything in it.
Sep 17, 2010 | HP Compaq Presario C500t Notebook
Hi, I'm having Dell Inspiron 1525 laptop and using operating system is Windows XP. From past one week it is restarting itself. While loading windows blue screen is coming and in fraction of seconds it is...
Hi. All Dell Notebooks has this Image Restore in one of the partitions of the hard drive.
You may restore factory settings of your computer but your files will be lost.
Try to boot using safemode with networking first so you can save your files online.
Turn your computer on and on the Dell logo, press Ctrl+F11 if system came with pre-loaded XP then follow the intructions.
If system came with windows Vista, on Dell logo, press F8 and select Repair your computer and press Enter. Click Next and/or enter your password if asked. If not, follow the intructions until your system goes back to factory image.
Hope it helps!
^_^
Jun 07, 2010 | Computers & Internet
I have a compaq presario x1000 that wont let me get past the logo. It was working fine one day, but then I shut it down. The next morning I booted it up it the computer never went past the Compaq logo.
It is likely that the hard drive is bad or a memory issue. I would start by removing the hard drive and see if it goes past the compaq screen. If it does then you know what is wrong. If not message me and will walk you through the next step
Jun 30, 2009 | Compaq Presario X1000 Notebook
It will not go past the windows loading logo
There is nothing left to do for this one here. The best thing to do is to take your computer to the manufacturer for repairs. Other than that the best thing to do is to purchase an external optical drive / cdrom or dvd drive and purchase another windows xp disc and reinstall it. or if you have the windows cd for this computer that you could use that as well. Those are your best options.
May 23, 2009 | Acer Aspire One AOA150-1635 Notebook
Windows Failed to load because Kernel file is missing
try pressing f8 when you load vista and then select start normally
if that doest not work and gives you the same error then restart and press F12 as soon as you see the dell logo, put in the vista installation disk that you got with the laptop and select boot with disk option.
try and repair or the recovery option .
NOTE : IT IS RECOMMENDED TO TAKE BACK UP OF YOUR FILES BEFORE USING THE RECOVERY OPTION .
May 17, 2009 | Dell Inspiron 1521 Notebook
Toshiba L300D-18E... won't load up past splash screen
Less than four months old (still in warranty), just back from hard drive replacement (recent service issue). Take/send it back as this is a warranty issue.
Feb 05, 2009 | Toshiba Satellite A100-S8111TD Notebook
Dell Inspiron 600M Notebook Logo
119 people viewed this question
Alun Cox
