Question about BenQ T221W Monitor
No screen display power light blinking - BenQ T221W Monitor
  • 2 more comments
  • rouxwl Dec 31, 2010
    Do i need a special tool to open the monitor?
  • rouxwl Jan 01, 2011
    Thx 4 your quick and well detailed reply.
    Yes i proved that the monitor is faulty by using a second pc and cable's
    I struggled a bit to get the cover open but did mange to not damage it to much ;-)
    I've found a cap(buldging) that could be the cause and will post images when i get the time
  • rouxwl Jan 02, 2011
    Found the boardhttp://i219.photobucket.com/albums/cc58/... with the same layout, only components missing is the ones in the yellow sqaure (Think it could be for the sound)
    The buldging cap (1000?F 10V) is the big one in the front of the red sqaure
  • 11,361 Answers
It does the same with another PC?
More likely to have components failure inside such as caps, transistors, cold solder joints.
BenQ makes monitor for DELL so it may have the same board inside as shown in my DELL albums.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Jan 01, 2011
Testimonial: "Thank you for your EXPERT reply and i'm sure with your assistance i would be able to get this monitor DIY'ed ;-)"
  • 5 more comments
  • Bud Martin
    Bud Martin Jan 01, 2011
    Please make sure to replace them in a set, post pictures of the board so I can tell you which one. Do not use RADIO SHACK caps, they are not low ESR type.
  • Bud Martin
    Bud Martin Jan 05, 2011
    Replace all 4 electrolytic caps on the left side of the board at the same time., make sure to use good caps with low ESR and 105C rating.
  • rouxwl Jan 07, 2011
    Replaced buldging radial electrolitic capacitor (1000 Mikro Farad 10 Volt).....0.163748 USD
    Monitor working like a charm!!!!!!
    Thank you again for your help
    "http://i219.photobucket.com/albums/cc58/rouxwl/79090140.jpg" The cap which the arrow is pointing at
  • Bud Martin
    Bud Martin Jan 07, 2011
    That 10vdc cap is for the 5vdc logic power supply, I would change the other one also, the circuits is like this: the rectifier diode will feed the first cap and then throunh an inductor (the inductor helps filtering out the swithcing frequency) there will be anoher cap, it is Phi filter setup, same for the power supply section for the backlight inverter circuits, that is why it is important not to replace just one bad cap, it will have at least two caps in each power supply.
    Cheers,
I HAVE A SONY-KV-ES34M61TV,PICTURE GOOD,SOUND GOOD BUT LIGHT BLINKIG FIVE TIMESWHEN NOT PICTURE ON TV SCREEN FLESHING LIGHT IS STOP, PICTURE GOOD,SOUND GOOD BUT IN SELF DIAGNOSTIC SCREEN DISPLAY 005:255,IT...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Feb 11, 2015 | Sony Televison & Video
Blinking heart beat led blinking
When the following situations, you need to replace the LCD screen:
No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
http://www.lcdinverter.info/compaq-presario-cq40533tx-lcd-inverter-p-2632.html
May 24, 2013 | HEWLETT-PACKARD Hewlett Packard HP...
Dell backlight indicators
A computer monitor has a front-mounted LED that displays its current status and flashes in the event of an error. When an error occurs, the flashing may be accompanied by an error message on the screen. If the screen does not display an error message, the problem most likely falls into one of four common categories.
Unsupported Display Mode A video card has the ability to send output to the monitor at many display resolutions and refresh rates. However, no single monitor is capable of supporting every possible display mode. When the video card sends an unsupported display mode to the monitor, the monitor shuts off to prevent damage and blinks, or displays an error message. Standby Mode b> When a monitor detects no video signal from the computer, it assumes that you have turned the computer off and enters standby mode to reduce power consumption. Dell and HP monitors display an amber light when in standby mode. The status light on an Apple monitor blinks slowly. Incorrect Power Supply Some monitors such as certain Apple Cinema and Studio displays use external power adapters. Because different power adapters may have similar connectors, these monitors are designed to detect when an incorrect power supply is connected and blink the status LED rather than attempting to turn on. In the case of an Apple display, the LED blinks in an alternating short and long pattern. b> Backlight Failure b> A flat panel LCD display has an LED or fluorescent backlight that illuminates the pixels and makes it possible to see the contents of the screen. If the backlight fails and requires replacement, the monitor is unable to display any information. In some cases, you may be able to resolve this issue by turning the monitor and computer off, disconnecting and reseating all cables. If the monitor still has a backlight issue, it requires professional service.
Jan 14, 2013 | Computers & Internet
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Apple Cinema HD Display 30'' black screen, power light blinking
I don't know what might have happened, but a number of years ago I had an apple monitor and the power light on it started blinking, so I got in touch with apple and they told me that it's flashing an error code, so they told me what the blinking indicated and fixed it.
So I think the blinking of the power light on your monitor could be indicating an error code so I suggest you call apple and they will identify what the error is indicating.
Feb 11, 2010 | Apple Cinema HD 30" LCD Monitor
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Monitor : no display and blue led light is blinking
The power supply is the first thing that the 110v electric line goes into. The invertor is the next item past the power supply, or sometimes contained within it. I do not thing monitors are a DIY repair.      First substitute a different monitor to confirm that it is, in deed , the monitor and not the video card.
Jan 14, 2009 | Advueu Technology ADV178T 17" Flat Panel...
BenQ T221W Monitor Logo
420 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
