Question about Samsung P2270HD 22" LCD Monitor
Linux Drivers to monitor samsung Syncmaster 2270HN. My Linux é Utimate Edition 2.8 from Ubuntu 10.10 Merkat
bluegreenash
  • 661 Answers
SOURCE: Cannot find VESA holes...Samsung Syncmaster 970p
I have looked at the specification for this, and although it does show as being VESA compatible (This is a display standard) There is no mention of any "wall mounting" capabilities at all, which would lead me to believe that this is not designed to be put on a mount. also the "Magic Rotation" Technology which is part of this device may rely on it using the proprietory stand, it may well be possible to remove the stand however, but it would require some significant dissasembly as the power connector is on the signal box, and this would need to be seperated from the stand itself. The mounting bolts look to be hidden behind the round pivot cover on the back, and it may be possible to see if mounting is possible simply by removing this, however I would seek information from the manufacturer about this as removing any of the covers would most likely invalidate your warranty, it is possible that this was missold to you and you should be able to take it back as not being fit for purpose.
Posted on Sep 15, 2007
  • 7 Answers
SOURCE: samsung monitor and mac os
go to menubar and adjust colour temperature in green,blue,red
Posted on Feb 16, 2008
SOURCE: Samsung SyncMaster [Monitor] (22.0 - I need best settings
hi , any has got the drivers for this monitor , kindly let me know to download it . regrads
Posted on Nov 10, 2008
Benimur
  • 6966 Answers
SOURCE: schema diagram samsung syncmaster 551v
Hi and welcome to FixYa,
Initially, pls try here.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 10, 2008
Download drivers under Ubuntu for HP ENV 4500 e-All-in-One Series?
Hi Frank,
HP is one of the most supported printers for Linux. I run Mint (based on Ubuntu) & have had support for even older models for years now. Have you tried installing it w/o bothering w/drivers at all? Basically, you turn on the printer, open the printers dialog>add new>then click network printer (assuming you're using the wi-fi on the printer). In Mint, I usually wait 1-2 mins. & it comes up with the printer listed by IP automatically. Now, I'm speaking of Mint- not 100% sure on Ubuntu but it ought to be very similar...
If that somehow doesn't work, then go here & follow the excellent walkthrough:
http://hplipopensource.com/hplip-web/install/install/index.html
Please report back if it solves it for you.
Cheers from Australia!
Feb 09, 2015 | HP Envy 4500 e-All-In-One Printer, Copier,...
Driver for Linux
Normally Linux doesn't need drivers because are already present on kernel. I doubt you will find one from a Samsung product.
What's exactly your problem with this monitor?
Sep 04, 2012 | Samsung SyncMaster B2230HD - LCD monitor -...
MY MONITOR VIDEO RESULT IS VERY BAD. WHAI IS BEST SETTING FOR NVIDIA GFORCE6150LE
I have no problem with 1440x 900. I can watch HD video. This video adapter I used with linux Ubuntu - up to 10/10, than MInt - up to 13. But under linux I could not watch the HD video(only under W XP). I am not expert on linux so maybe someone other who is expert has set up the linux better :)
I could play operation flashpoint, mafia, Empire earth on lower details.
Sep 09, 2011 | Nvidia GeForce 6150 LE
My monitor (Samsung, SyncMaster 540n) is not getting "ON" normal. it takes almost 15 mints and some times more.
meu monitor quando desligo ele passa +ou- 20 a 30 minutos piscando pra poder ligar op q tenho que fazer será que é um defeito ou pode ser alguma configuração por favor manda resposta pra meu e-mail eu232011@hotmail.com
fico muito grato por colaborar abraço atodos uma otima semana,
agradeço a direção...
Jan 09, 2011 | Samsung SyncMaster 540N 15" LCD Monitor
I have an ASUS netbook that runs linux. I don't know linux, but was told to upgrade to ubuntu. I don't know how. Anyone know how?
1. I would suggest finding out which model Eee PC you are using and the hard drive size & type (4GB SSD, 160GB SATA, etc...). If you have less than 4GB, I would probably recommend using another Linux distro, as the Netbook Edition of Ubuntu is pretty heavy.
2. Next, I would probably suggest plugging in the Eee PC (Software/OS installation is very power intensive).
3. Download your distribution (Ubuntu Netbook Edition or Desktop, etc).
4. Download a copy of unetbootin for your PC (unetbootin.sourceforge.net -- There are Linux & Windows versions available.)
5. Using a USB thumb drive (USB Memory stick), you will want to wipe the drive (format using FAT/FAT32 filesystem).
6. Run Unetbootin, selecting the proper USB thumb drive & ISO image from the Ubuntu website.
7. After Unetbootin is finished, close it and safely disconnect the USB drive.
8. Next, plug the USB thumb drive into the Eee PC.
9. Turn on power to the Eee PC & after seeing the initial BIOS splash, hit the ESC key on the keyboard. This should bring up a boot selection screen. Using the arrow keys, select the appropriate USB drive and hit Enter (Return).
10. If all goes well, you should be running Ubuntu Desktop/Ubuntu Netbook Edition as a live desktop. (The installer is a link on the desktop.)
11. There are several step-by-step guides out there, so check them out, if needed. The installer should be very simple on this type of hardware, etc.
Good Luck!
--TaoBeastie
Jul 07, 2010 | Canonical Ltd. Ubuntu
Blurred image in Samsung Syncmaster732nw monitor
For best pictures, you need to set your PC video resolution to the native resolution of this monitor, which is 1280x1024 @60Hz. Try that first before opening up the monitor to look for bad components.
Post back, see what usually goes wrong with SAMSUNG monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
I am using Ubuntu 9.10 in a dual-boot config with XP. I have a Samsung Synchmaster 931B monitor in analog mode. Works fine and drivers installed under XP, but will not support extended effects under...
it's your graphics card not the monitor that often has proprietary drivers to drive compiz and other effects.
If this is not a laptop, then it is easy to interchange.
Nvidia is one such vendor that supplies special drivers for Ubuntu
Jan 29, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Screen size
I think you will get an answer hre
http://ubuntuforums.org/
Oct 03, 2009 | Philips 150S (White) 15" LCD Monitor
Samsung P2270HD 22" LCD Monitor Logo
240 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
