Question about Bosch Dishwashers
When I use those gel pacs they never completely dissolve. The water is hot enough and I've had a repairman in to see if there was any problem and he didn't find anything wrong. I've even tried liquid detergent and sometimes that doesn't even completely come out of the cup. I make sure the cup isn't blocked so water can get to it. What's the problem? Help! I hate my dishwasher and am sick of having to put my dishes through 2 cycles!
  • Bosch Master
  • 43,501 Answers
The problem could be that the soap cup is not opening properly or on time when it should...
Yes... it is opening... but maybe with not enough time to disolve or do it's job...
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Posted on Dec 31, 2010
Kenmore Elite dishwasher will not dissolve soap or wash well.
Temperature should be 140F. and the units heater should energize during fill to achieve this.
May 19, 2010 | Kenmore 24 in. 15173 Stainless Steel...
Gel paks don't dissolve
Before you start the machine make sure the water is hot enough going into the dishwasher. Sounds like the water temp is not hot enough to melt paks or dispenser is not opening.
Feb 24, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Detergent does not dissolve
According to the "manual" the most likely problem is your water is not hot enough. Water temp should be between 120 and 140 degrees.
Also, I would NOT use gel detergents since they have a reputations for not dissolving and can leave some real tasty residue all over the bottom of the machine, especially the heating unit.
Jan 17, 2010 | Maytag MDB7100AWB Dishwasher
Detergent packs will not dissolve
check the water temperature, run hot water at the adjacent sink before pushing start on the dishwaher, or switch to powder, is your detergent door opening ? do not block the detergent door with long objects like spatulas etc.
Aug 27, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
DISHWASHER WILL NOT DRAIN EVEN AFTER WE PUSH THE CANCEL/DRAIN BUTTON. I DON'T KNOW WHETHER TO CALL A PLUMBER OR WHIRLPOOL REPAIR.
First of all, if you have been using the gel pacs...stop! They don't dissolve completely and cause a buildup. This happened to me and we replaced the hose and solved the problem (about $25). I also had to take apart some of the assembly and scrap off the powdered substance that solidified around the drainage holes. Good luck!
Aug 10, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
My dishwasher won't drain, and leaked out onto my hardwood floor!
I ordered a new hose and the problem is fixed! I probably could have just simply taken the old hose off and flushed it out; but the powdered solution, that is supposed to dissolve, had solidified and clogged the hose in several places. Strangely, it had also made like a filmy flap at both openings. Gross!
Jun 23, 2009 | Kenmore Dishwashers
Detergent falls out and doesn't melt
check water temperture its not hot enough..onthejob
Feb 05, 2009 | Dishwashers
Soap hardens in the dispenser and dishes don't come clean
Either your dishwasher is not getting the water hot enough to dissolve the powder, or you need to switch brands. Try a liquid/gel type of dishwasher detergent.
Try stopping the washer a few minutes after you start a wash cycle. Open the door -- if there is a lot of steam coming out at you, it's not the water temperature. If there is no steam, your dishwasher is not getting hot water and/or the heating coil is not working.
Dec 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE Monogram ZBD0700K - gel pak detergent not dissolving
Low inlet water Make sure inlet water temperature is at least
120°F (49°C)
Run water at the nearest faucet prior to
starting the dishwasher to insure optimal water
temperature.
Water pressure is low Turn on a faucet. Is water coming out
more slowly than usual? If so, wait until
pressure is normal before using your
dishwasher.
Air gap is clogged • Clean air gap.
Improper rack loading Make sure large dishware does not block the
detergent dispenser or the wash arms.
Jun 20, 2008 | GE Monogram® ZBD6880NSS Stainless Steel...
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
