Question about Sony Grand WEGA KDF55E2000 55" Projection HDTV
Sony Grand WEGA KDF55E2000 cant hook up PS3 thru either HDMI input 6 or 7. when i hook it up and turn on the TV, (even after unplugging the TV from the wall) i get a screen with green lines everywhere saying unsupported signal, check your device output" i have tried 2 different HDMI cables. when i take it to my samsung LCD tv i can just plug it in and it comes in fine. so it is something with this TV.
3 Suggested Answers
osummer
  • 3 Answers
SOURCE: cant find HDMI input on tv, trying to hook up ps3
hdmi output is" INPUT 1" on the menu ALSO hold down on the ps3 power button for 6 seconds and it should come on. the ps 3 has a thing were you have to set it to send out in hdmi or comp.
Posted on Mar 19, 2009
AJIN G
  • 6694 Answers
SOURCE: trying to use ps3, even
hi
There maybe some problem with your TVs resolution. ps3 outputs full hd high resolution video(1080p) through its HDMI. May be your TV is not supporting that resolution. Connect ps3's component video out to your TV's component video input and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution your TV will not support. Your tv is hd ready one, not full hd. ps3 's HDMI out is full hd (1080p).
or try this
Connect your ps3 to any full hd tv and then goto video setup of ps3. change resolution to 1080i (down scaling ). then connect to your TV via HDMI. surly u will get the video.
ok
Posted on Jun 09, 2011
How do I fix an HDMI input that has stopped working
This sometimes happens on my Samsung tv. With the tv switched on try unplugging the tv from the mains supply and leave for 3 minutes then plug back in and try. I hope this helps.
Nov 16, 2013 | Sony Grand WEGA KDF-55XS955 55" Rear...
I own a Sony kdf-55e2000 , when I try to hook up a ps3 through the hdmi imputs i get a message reading "unsupported signal please check device output" i can here the sound but no picture.Is there any
try only having the hdmi cable hooked up to ps3 and tv, turn off ps3 and hold power button for 5 or 10 seconds and you should hear 3 beeps, this should reset the ps3 and detect the settings, if this doesnt work you mmay have to manually change audio and video settings in the ps3 settings menu to hdmi output and auto detect which settings work.
Jan 05, 2013 | Sony Grand WEGA KDF55E2000 55" Projection...
Trying to use ps3, even after using hdmi cable on input 6 or 7, it says check your device output and i see green lines on my screen?
hi
or try this
ok
Jun 09, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
I plugged my external hard drive into my sony wega kdf55E200 using the usb port I have power to the external hard drive the light is on. But I cannot get a picture on my tv what can I do
Your TV is very unlikely to be able to read the external drive. The USB connection on most TVs are meant to view pictures and lack the ability to navigate file systems and read most file formats. Your best bet is hook the hard drive up to a computer or a video game system (PS3 and Xbox360 do this) and then hook that computer or game system to the TV.
Mar 12, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
The HDMI doesn't work properly
HI
The resolution is only set by the sending unit, in your case the cable box. You need to change this to at least 720P something the your TV can handle.
Now once you have down this, to try and solve your HDMI problem I suggest you do the following.
Switch-off your cable box and the TV set, unhook the HDMI cable.
Now reinsert it carefully to make sure it connects properly on both sides.
Now first switch on your TV and set the input to Video 6 ( your HDMI channel )
Now wait for 30 secs. Switching on your cable box.
Do not press anything and check if your picture now stays on without shut-down.
if the menu and other startup screens on the cable box is not flickering, but the normal picture you might have a HDMI conflict with your TV set.
O, you cannot change the input types.
Hope this helps!
Dec 28, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
How do i turn on the hdmi setting to make a ps3 work
Turn off TV, unplug it from AC socket, plug PS3 in HDMI input, turn On PS3 and then turn On TV so TV will recognize PS3 through HDMI
Oct 10, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
No sound when hooking up DVi to HDMI...
This is normal, when you go from HDMI to DVI, the sound does not get transmitted. You need a separate cable to go from audio output on the computer to Audio input to the TV. There are speaker (headphone on laptop) jack to RCA audio cables, you could also go with digital audio or even optical out if your computer and TV both have the input and outputs.
Oct 05, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
PS 3 Hookup to Sony Grand Wega
this is a very simple fix leave cords in your sony with ps3 on standby hold the power button on ps3 itself down for 10sec your ps3 will switch back to av cables
Jan 05, 2009 | Sony Playstation 3 (PS3) Console
Ps3 sony grand wega (4 yrs old)
Press the input button on the tv itself to select the proper input you desire.
Dec 27, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Help
HDMI function works with all those components who have HDMI port in it. I dont know I made my point clear or not.
May 27, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF55E2000 55" Projection HDTV Logo
240 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
