Question about Ricoh Office Equipment & Supplies
Copier needs to be fixed
Good Morning,
My name is Liza, and I am in need of a repair man for the RICOH (Aficio) 650. I've tried everything as far as trying to get any paper jams out/cutting off and on the machine.
Can you please find me a repair man to come and fix the problem.
Thanks.
  • 42 Answers
On Fixya home page there is a box with repairman.type in your zip for a local repairman.
Posted on Jul 08, 2008
Ricoh Aficio 2232C Error Message SC393-02
I had the same problem after transit of copier. Try removing the yellow developer unit and give it a good shake. You may need to do it with the other units too.
Apr 16, 2013 | Ricoh Aficio 2232C Color Copier
Ricoh Aficio 3025 Copier LCD Touch Screen gets hang after calibration
You need to replace the screen to fix your problem. But if this machine is the model I think it is you need a whole new machine.
Jul 23, 2017 | Ricoh Office Equipment & Supplies
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
My copier is ricoh aficio 650 during it self test and worming time the message appear sc101 - 00
That message is related to the scanner.
Probably the scanner lamp is dirty and the white bar under the glass.
You have to remove the glass and clean it with a dry cloth.
See you
May 13, 2011 | Ricoh Aficio 450 Copier
Ricoh Aficio 3025 Copier LCD Touch Screen out of Allignment
It's not in service mode, but rather in the 'self diagnostic menu'. Access it as follows:
Press "clear modes", 1 9 9 3, "clear/stop" (5 times).
** Do not try any other adjustments in this mode...only touch screen
please rate me :)
Apr 10, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio 350e copier Multifuntion machine
This blinking wrench red light means that your copier needs to be serviced. How old is your copier or how many copy have you done with it ?
Otherwise, you may need to call a service man for it.
Sep 08, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Ricoh service code 502 - 520 - 496
You need to reset the bottle code. Clear/modes, 1,0,7, press and hold clear button. enter copy sp. select drum(#2) scroll to 2972, enter 0 and press # key. Do the same for 2973. exit all the way out, and recycle power.
Feb 19, 2008 | Ricoh Aficio 1085 Laser Printer
Error SC940
SC940 - Main Switch Abnormal (U.S.A. version only)
Definition: [level: A]
The Main switch does not turn off after sending the reset signal two times
in a row.
Possible causes:
· Main switch
· Main PCB
You must enter em SP mode and then turn off the main switch and on again.
Entering in SP mode:
Enter SP mode as follows:
1) Press the clear modes key.
2) Enter "107".
3) Press the clear/stop key for more than 3 seconds
Then turn of the machine, don't play around in the SP mode u can damage the Ricoh
Nov 05, 2007 | Ricoh Aficio 450 Copier
61 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
