Question about Quantum Audio QCA4000D Car Amp
No matter what i do the qca 4000d quantium audio amp still is getting hot what should i try
Open it up 1st see if the fan is in working condition if not replace it with a computer fan if not take the fan off and replace the thermopast with artic sliver u can buy it at radio shack for little over 12$ make sure u dont get the thermo past all over and wipe the old thermopast off before applieing the new stuff wait 24hrs for it to dry and harden then it will stop with over heating if thats ur problem u can also use it on your mosfets the pices on the side if i am wrong then correct me but good luck with that :-) hope it helps someone
Posted on Dec 18, 2012
2 Suggested Answers
SOURCE: QCA2000D Car Amp: Bought a Quantium audio QCA2000D cozmic with no in...
the two outside terminals. the farthest negative and the farthest positive
Posted on Aug 02, 2010
OH error QCA spa High jets work and heat
OH is the overheat code.
Your spa temperature is set above 108, or your thermostat is faulty & not reading correctly.
Jan 23, 2012 | Qca Spas Jewel Series Topaz Plus Hot Tub
Unlock control panel
Press & Hold the JET Button for 6 seconds (Most/Gecko & Hydro-Quip)
or
Hold temperature UP & DOWN together for 6 seconds.
or
Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
Apr 16, 2011 | Qca Spas Majestic Series Aruba Xl Hot Tub
I cannot get my brother 4000d threaded correctly
on the brother.com website,, they have downloadable manuals,,,on the home page go to product manuals
& then select home sewing & embroidery & then look for the model number of the machine
Dec 08, 2010 | Brother InnovIs 4000D Computerized Sewing...
May 18, 2010 | Quantum Audio QCA2000D Car Amp
What does FL mean on my hot tub?? water doesnt circulate but is still sort of warm...
FL could be a code for low flow. If you have no circulation this sounds like it. If your pump runs and you have no flow you could have a problem with your pump. Or if you have the tub drained then it could be an air lock, if you open the drain valve till you get water out that should fix that. Also check to be sure the isolation valves are open under the spa. I hope this helps.
Feb 07, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
Cut out
rewire the subs-each sub you want in series=8 ohms per sub-then at the amp wire the two 8 ohm subs in parallel which brings the ohms back down to 4 ohms which is optimal for the amp and it shouldnt shut down on you any more-try that-good luck
May 30, 2009 | Kicker ZX400.1 Car Audio Amplifier
Need to pick perfect amp
I suggest to use separate amps to your sub, get a 2 channel amp for your sub and 4 channel amps for your speakers.
Here are my Top 5
  • Lanzar -OPTI4000D
  • MA Audio- HK-4000D
  • JL Audio 1000/1V2
  • OPti 22.2 Power Amp
  • AudioBahn-A5100T
Apr 05, 2009 | Power Acoustik FUBAR-12W Car Subwoofer
Ma audio hk 4000d
you have definately blown a output channel, or power supply. Send it in for warranty.
Jan 09, 2009 | MA Audio HK4000D Car Audio Amplifier
Quantum Audio QCA4000D Car Amp Logo
142 people viewed this question
Top Quantum Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Quantum Audio Car Audio and Video Expert? Answer questions, earn points and help others
