I have a v-1012-b velodyne sub woofer from 1991 that the baffle fell out of the bottom and i am looking for rebuild parts thanks Joel
  • jedmach1 Oct 23, 2008
    I have the same problem. Have posted on a couple of boards trying to find a solution. Glue around the edge will not hold it. The radiator replacement part is no longer manufactured by Velodyne.
  • 124 Answers
SOURCE: Velodyne sub noise
Sounds like a bad amplifier.
One of the input caps on the power side is my guess
best bet is to contact Velodyne for a repair or replacment
Posted on Jan 04, 2009
  • 124 Answers
SOURCE: No sound for Velodyne ct-100 sub woofer
Sounds like a dead amp. You could check the xformer output and the amp IC's with a VOM.
These amps do not cost a lot, about $40.00. and are easy to replace.
Contact Velodyne
Posted on Mar 26, 2009
  • 124 Answers
SOURCE: Velodyne sub woofer: Series S Model: VA08BVX10
The volume control pot can be replaced.
Any good quality audio shop or electronics repair shop should be able to fix this.
Posted on Nov 21, 2009
  • 124 Answers
SOURCE: lost manuel
The Q55 is not a velodyne product
Posted on Dec 20, 2009
  • 435 Answers
SOURCE: possible lightning strike to powered sub woofer
NO. Nothing is fixable after a lightning strike.
Posted on Jan 02, 2010
What can cause a sub woofer and room speaker woofer to stop
Check wiring for loose connection...may have to open speaker enclosure.
Jan 04, 2016 | Velodyne CHT-8 Subwoofer
My Velodyne DPS-10 subwoofer hums when you plug in the RCA cable. The hum increases in volume when you touch the rear metal panel.
hi,
You have to check the RCA cable to the sub woofer. The RCA cabe have two connections inside it, one is for gain and the other is for ground sheild. If the ground sheild is broken then there will be hum from the sub woofer and it will increase if you touch the ground (rear metal pannel is connected to the ground). Replace the cable and check it again.
ok
Jul 17, 2011 | Velodyne DPS-10 Subwoofer
My velodyne sub rattles when volume turn up
How high? There IS a limit to any speaker's volume and cone travel of the driver. The woofer could be bottoming out. Driving any speaker with excessively or with anm UNDER powered amp can send speaker-killing square-waves to it.
Feb 27, 2010 | Audio Players & Recorders
Nov 17, 2009 | Velodyne SPL-1000 Subwoofer
I hear some noise coming out from the woofer of CHT-12R
It very well could be the spaker leads hitting the speaker cone.
You could check this by removing the amp section from the back.
Remove the screws at the very edge of the amp panel.
Jul 04, 2009 | Velodyne CHT-12 Subwoofer
Speaker would push out and stay out with a hum when turned on.
Sounds like the "servo" on this unit has gone bad.
You will need to contact Velodyne for service on this.
It is the only place to get parts and service for this unit.
Apr 01, 2009 | Velodyne SPL-1000 Subwoofer
Contact Velodyne
Feb 25, 2009 | Velodyne CT-100 Speaker
No Sound for Velodyne VLF-1012
Sounds like your amp is damaged.
Jan 29, 2009 | Velodyne VLF-1012 Subwoofer
Lost manuel
Nov 17, 2008 | Velodyne CT-80 Subwoofer
Hi I own a Technics Hi-Fi system (Model SC-EH780) and would like to attach a subwoofer to it. I cannot find the subwoofer unit that is supposed to go with this system. Can you help?
Any powered sub-woofer will work with it. Check the back of the Technics, make sure there is an RCA output labeled "Sub-woofer" or "Woofer" or "Sub". If so, you can get any brand of powered sub woofer and it will work. A powered sub-woofer is one with an amplifier for the sub built into the box and you will need to plug it into an A/C outlet as well. The only exceptions to what will work with this unit is to make sure you are not buying a sub-woofer that is made to only work with the companion unit it is originally sold with. Many Panasonic and JVC sub woofers are like this. Just look for a sub-woofer that is not part of any system. Velodyne makes some really great sub-woofers that would work nice with yours, but they can be a little expensive, but they are very good.
If your Technics has no RCA output for the sub-woofer, you will need to make sure that whatever powered sub-woofer you buy has a speaker level input for it. Most powered sub-woofers have this feature, so that you may just run the front speaker outputs of the receiver into the subwoofer and then the sub-woofer will have a set of speaker outputs right below the speaker inputs so you can still have your front speakers connected to that and not loose anything from your system.
I hope I have explained this in a manner you will understand easy, if not just post whatever questions you may have right on this thread and I will get back to you as soon as possible.
It would also be appreciated if you could rate this solution if you no longer need any help from me. If you do require more help, please wait to rate this until we are finished. That way I do not get an undeserved bad rating when we have not even finished our communications.
By the way, A "Thanks for trying" and "Helpful" rating are really not good, they always end up lowering my overall score.
Dave
Nov 09, 2008 | Audio Players & Recorders
573 people viewed this question
 Grubhead
Grubhead
