Question about Whirlpool Washing Machines
My kitchen aid washer leaks from bottom - Whirlpool Washing Machines
  • 1,028 Answers
Top load? lean back remove bottom cover if any ckd pump most likely suspect
Posted on Jul 09, 2008
Rinse aid appears to be leaking
Now, not knowing about the model you mention, I am going to tell you about the same problem I encountered with my dishwasher. We, too, started seeing water on our floor when we were running our "built-in" dishwasher. I checked the water level in the washer and it was not overflowing from being too full. So, I removed the panel at the front bottom of the washer so I could see the workings. First thing I did was to feel around for moisture on connections and other parts. When I got to the bottom of the pump, I did feel moisture. This told me that the pump was leaking. Unfortunately, most manufacturers nowadays use non-metallic metallic components and with mine it was made of plastic. When I removed the pump, I saw a crack in it along a seam (where it is molded together after the internal workings of the pump are in place). The pump turned out to be almost as expensive as a new machine but I was blessed. A friend of my son was remodeling his kitchen and that included a new dishwasher. He gave me his original one (which turned out to be a recently built one by the same manufacturer) and I installed it and haven't had a leak since.
Now, I hope that this does help but as I said, I am not familiar with your free-standing model.
Aug 10, 2014 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
My Kitchen Aid clothes washer is leaking water from the bottom.
HI couple things to check, water hoses coming into washer, tip the washer back and look underneath and see if you can see where its coming from, most common leak on this one is the drain pump which is located right on the front of the motor, if you tip the washer back its a plastic pump with 2 big hoses going into it, they usually crack and leak water from there. They are only about $30.00 to buy.
Mar 29, 2011 | KitchenAid KAWS850L Top Load Washer
Our Kitchen Aid KDI -16 has been working great for years. Today, my mother noticed a small puddle that was on the floor in front of the dishwasher. We took of the bottom front panal to discover that when...
Sorry to read about your problem, I hope this helps you out.
yes it is, and yes it is... sounds like the water pump is leaking
I suggest you call a service company
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | Dishwashers
Kitchen aid whisper quiet, model KUDI02CRBL1, leaking water from under the door. Changed the tube door seal, the bottom strip of plastic running across the door on the bottom and today a new soap disp....
Suspect the door latch has loosened enough to allow water spray to get into the latch cavity. Look for worn parts or loose adjustable components in the latch area (both door and case sides). Hope this helps!
Sep 18, 2010 | KitchenAid KHWS01PWH Global Horizontal...
Kitchen aid washing machine model #5850gq1,water leak
Well it depends on where the leak is coming from. If it's at the bottom its probably the pump. If its at the top it'll probably be the valve.. although this is much less likely.
Nov 08, 2009 | KitchenAid KAWS850L Top Load Washer
Agitator will not work
kitchen aid is hte same as the whirlpool so if you have directions for that one it will work on your current one,, part number 80040
Oct 23, 2008 | KitchenAid Superba Architect KSCS25INSS...
Washing Machines Logo
55 people viewed this question
Dan Webster
Dan Webster
Sal De
