Question about Microwave Ovens
I just need a picture of top as the plate that tells what each button is for is missing> Don't know where that went!!!
    Brigadier General:
  • 8,909 Answers
If you download an instruction manual from the manufacturers web site, there may well be a good sized picture of the front panel to guide you.
Hope that helps.
Posted on Dec 31, 2010
I need a replacement turntable for my brevile combination microwave model brcm2516 where can I get one
First4Spares Glass Turntable Plate For Breville Microwave Ovens ...
https://www.amazon.com/First4Spares-Glass-Turntable-Breville-Microwave/.../B007B...
Shop First4spares at the Amazon Small Appliance Parts & Accessories store. Free Shipping on eligible ... BREVILLE MICROWAVE TURNTABLE Glass Plate 245mm 9.5". $29.99. Next ... Container for Microwave Oven · Add to Cart · Add to ...
Amazon.com: BREVILLE MICROWAVE TURNTABLE Glass Plate ...
https://www.amazon.com/BREVILLE-MICROWAVE-TURNTABLE-Glass.../B00COP... Quality replacement glass turntable for your Breville microwave. ... Small Appliance Parts & Accessories > Microwave Oven Parts & Accessories > Turntables
Breville Shop ' Partmaster
www.partmaster.co.uk/breville/microwave/catalogue.pl?shop=breville&path... Find your Breville products and repair your appliance yourself for less. ... Connects the microwave motor to the glass turntable Suitable for select microwave ...
Breville Canada
https://breville.ca/ Breville designs and engineers small kitchen countertop appliances to deliver commercial quality performance that look great and are easy to use.
Breville Microwave Parts & Accessories ' eBay
https://www.ebay.co.uk > ... > Breville Microwave Parts & Accessories BREVILLE Microwave Glass Turntable Plate Roller Ring Support Stand 3 Wheel ... Turntable Turn Table
Plate MOTOR for BREVILLE Microwave Oven ...
Breville Parts -Google Search
Jul 03, 2017 | Microwave Ovens
I have a toshiba microwave model ER-7700 & want to know what's the power(watt)?
It should tell you on the plate/sticker of the unit. If it only gives you voltage and amperage calculate it with this formula: Just substitute your values.
P (Watts) = A (current in amps) x V (voltage)
= 15 Amps x 120 Volts
= 1800 Watts
Mar 19, 2015 | Microwave Ovens
Need to know if I can convert it to outside vent
This unit has a three way exhaust capability on it. There is a plate on the back that you remove to set the blower housing to back, top or frontal exhaust. You take the plate off and then just lift the blower assy. up and then reset it back into position for the direction that you want. It may be missing the vent louver for outside exhaust if it wasn't left with the unit when it was installed.
Sep 17, 2013 | Sharp R-1850A Convection/Microwave Oven
The splatter plate piece is torn and i don't know if i can still use my microwave?
no you need to buy a new one. Go to www,repairclinic.com and get itGod bless you
Apr 02, 2013 | Microwave Ovens
I need to know the wattage of my Emerson MW8111SS Microwave Over
Maybe I am confused, or don't understand your question. But your model runs on 110 current and is >>>>>>>>>>>> 1,100 watts. Breaker in panel needs to be 20 amp to run best, and nice to have on separate circuit if able. Thanks mike
Jul 26, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
I bought a microwave at an aution. No owner manual Kenmore model #970-86116-001. It has an element in the top and has buttons that say microwave,convection, convection roast etc. There is no glass plate at...
If you press "convection" the oven works just like a regular oven except that the element is on top. In "microwave" it works like a microwave oven. All you have to do is decide which mode you want to use and then punch in the time and hit "start". The glass plate is not really a necessity as long as you make sure there is a load in the oven when you are "microwaving".
May 08, 2011 | Kenmore Microwave Ovens
I am trying to clean the inside of my microwave, ut I don't know how to remove to disc on the top, which is full of grease,how do I do it!!
Hi, If you look at the plate on the top it has what looks like a little button and printing that says "open" with an arrow pointing to the left and one pointing to the right that says "close".
The little button is actually a tab that you can carefully remove by using a butter knife and sticking it in above the tab where the plate meets the top. The tab is about 1/4 inch long. After you remove the tab carefully turn the plate to the left and slowly drop it down. There is a slotted disk on a square shaft above the plate that may (probably) drop down with the plate. The plate holds the disk in place and is actually the bearing for that disk so be sure to slide it back on the shaft as you put the plate back. turn the plate to the right and then push the tab back into the hole. Good Luck!
Jan 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need to find turntable mount for Emerson MW8117W Microwave
Go to repairclinic.com and type in your model number. I suspect you may be talking about item 1063610, Turntable Coupler. You may also try searspartsdirect.com. If this isn't the part you need, please post back and provide more information, so that I may assist you better. I hope this helps.
Jan 04, 2009 | Emerson Black Microwave Oven
MCO160UW goes dead after 3 minutes
I returned the item to Home Depot and they took it back no questions asked.
Nov 30, 2008 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
14 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
