Question about Vacuums
I can not figure how to remove the microwave from the outer bracket. We are trying to replace with new GE microwave but can't remove the old one from over the stove.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
you did not list your model, so
Turn off power to unit
1 way. you will have 2 to 3 screws ontop of the unit, open the cupboard door above unit, and look for them. remove all the screws, KEEP UNIT PUSHED AGAINST THE WALL, it will not drop down.
once all 2 or 3 screws are gone tilt unit down a little and lift up and away from wall (TWO PEOPLE)
2nd way if you dont see any screws on top, is look at the upper panel, remove if you can, or look for silver type round screw heads... if you see them..loosen them..unit will become loose from the wall. one on each side.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 31, 2010
How do I replace the power cord on an electrolux 8502A vacuum cleaner?
1 Unplug the vacuum and remove all accessories such as extensions and brushes. Open the vacuum's outer casing to get at the end of the power cord. Exactly how you will do this depends on the model of vacuum. Generally it simply involves the removal of two to three Phillips-head screws.
2 Follow the power cord to the two connections at the vacuum's motor. Unfasten any clips or holding bracket and disconnect the cord from the motor. Sometimes this can be accomplished by unscrewing two connection screws, other times the cord is soldered directly to the motor. If this is the case use wire cutters and cut the cord about 4 inches from the motor to give room for splicing on a new cord.
3 Insert the new power cord into the vacuum. Follow the exact same path as the old one. If there were any brackets or clips that held the old cord in place inside the vacuum or out use them on the new cord.
4 Tie a knot in the cord on the inside of the vacuum casing so that it will not accidentally be pulled out of the motor once it is in use.
5 Connect the new cord to the motor in the same fashion as the old one. With wire strippers take off about 1 inch of insulation from the new cord to expose the two wires. Either wrap them around the connection posts and re-screw, or twist the new cord wires around the 4-inch remnants of the old cord and seal all exposed wire and connections with electrical tape.
6 Replace the vacuum's casing in reverse order from how you removed it. Plug in the vacuum to test.
Sep 11, 2011 | Vacuums
GE Space saver microwave has no power
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jul 18, 2011 | Vacuums
Microwave, just stopped working, no lights , nothing. 4-5 years old GE Profile Eterna
heatman101
Apr 24, 2011 | Vacuums
Have a Kirby Heritage II vacuum. Need to replace a split fill tube. How do I remove the outer cloth bag from the mini-emptor, and then how do I take off the old/attach a new fill tube?
There is no need to remove the outer bag. The fill tube can be removed by cutting it off near the bottom and pulling on the support wire to unwind it from the neck on the mini-emptor. I usually hose down the bag and slosh it around in my laundry sink to clean it. After it dries, the new fill tube can be screwed onto the mini-emptor. You can wet the bottom of the tube with plain water to make it go on more easily. If you screw it on firmly, there is no need for cable ties at the bottom. Re-attach the top adaptor ( bag holder ), and secure it with cable ties.
Apr 16, 2011 | Kirby Heritage II Vacuum
Clock and time work press start just clicks and nothing runs ge jet 342g microwave
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 16, 2011 | GE Vacuums
The hose on my spot bot has torn
yes you can replace the hose for $25
If your unit is less than a year old it will be under warranty and replaced at no charge to you
Dec 15, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
I am trying to open the outer casing of the vacuum
There is a push in type flat plastic switch trim cover over the metal housing surrounding the switch.. You must unplug the cord, gently pry around the trim cover and you will find a screw, an irregular one underneath holding the switch in place. DO NOT OVERTIGHTEN when reinstalling this one or you will crack the switch.
Once removed the rear housing will come off. Then you will see several new philips round head screws holding the front housing onto the vac.With all screws removed the housing should open easily but there may be dirty film inside holding the halves together. The fan shaft will unscrew revealing the fan, a spacer behind and perhaps two different spacer washers. Install the new fan hand tight, washers and spacers in same order...
Good effort figuring this one out. Please post back with results.
Oct 29, 2009 | Vacuums
How to change Mini Em-Tor Fill Tube Assembly on Kirby G4
You will have to remove bag strap. You can try to save old strap (see instruction here) or you can cut it. Install the bag on the new mini-emptor just like it was on old one (strap goes over both layers of vinyl). Use a long cable tie instead of the strap if you have damages it or your old bag strap. If you are using old strap you may have to use pliers to get it in all the way.
Oct 27, 2008 | Kirby G4 Bagged Upright Vacuum
I need to replace the cord. There is a short near the housing.
hi may i suggest ? if you wish to renew the complete cord/wire? why not fit a longer length to facilitate more reach thro different rooms from the preferred wall socket ? the problem of short /breakage of wires within outer sleeve near casing is common on lots of vacs it is not a difficult job to replace if you are competant with wire and colour codes remove the access cover where wire enters vac then observe the attachment of each wire ? then disconnect faulty cable transfer the rubber tube that is normally fitted at entry point to vac at this point to new cable remove outer sleeve of new cable same length as old cable to reveal the inner wires then connect to vac sockets resecure cable to vac as previous dont forget the rubber tube? refit entry cover and fit a new 3 pin plug bs kite marked ? then away to vac the rooms? hope this helps
Oct 20, 2008 | Hoover Vacuums
Electrolux Renaissance Hose Replacement
Notice how the hose has a groove just around the outer edge of the gray plastic near the white plastic insert. The hose is held into the handle buy two "tongues" inserted into this groove. One of these tongues is on the end of the top plastic piece of the handle. The second is on the piece of plastic that is slid into the little hole at the base of the handle and it is visible in the picture.
To remove the first, you'll have to remove the two screws in the top of the handle that hold the top plastic piece. This can be a challenge unless you have the right tool. It's essentially a hex-star allen wrench tool that is required, I'm guessing about 1/16 inch. I had one in my tool box that fit. Remove the screws and pop the top plate off. This frees the first tongue from the groove. Now, just get a screw driver (or use your finger) to press the plastic piece inserted in the hole at the bottom of the handle. Press from the "t" side and this should slide right out. Now your hose will slide right out of the handle and you can replace the old with new. Re-insert the small plastic insert, and refasten the top plastic piece of the handle and you're good to go.
-DB
Dec 04, 2007 | Vacuums
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
