Question about Frigidaire Affinity 5.8 Cu. Ft. Super Capacity Electric Dryer
I am trying to use the dryer and an error code of LOC comes on and it won't run
    President:
  • 1,554 Answers
The control is locked. Press and hold the OPTIONS and SELECT button at the same time for 10 seconds or until "LOC" turns off. To lock the control, press and hold OPTIONS and SELECT until "LOC" is displayed. Unplug the machine for at least 30 minutes if pressing and holding the said buttons does not unlock the control to eliminate the possibility of an electronic glitch. The control may need to be replaced if unplugging the dryer still doesn't solve the problem.
Posted on Jan 01, 2011
2 Suggested Answers
SOURCE: Error code LOC on frigidaire front load dryer
This worked for me. The LOC indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
Posted on Feb 17, 2009
Dryer will not start. Has LOC error code.
Hello Luz - This is AP and I'm happy to assist you!
It appears your Frigidaire dryer console Control Lock has been activated. Without knowing your specific model number I can suggest to simply press and hold the Options and Select buttons at the same time until LOC is no longer displayed to deactivate the lock. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully.
Mar 03, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
Error code loc
please read this over your error codes are invalid.
Jan 23, 2014 | Frigidaire Affinity FAQE7011KW Electric...
Error code loc
Hi Amanda, thank you for your inquiry!
An error code E61 generally means that a heater relay failure has occurred. A qualified technician would pinpoint the problem by checking the wiring for both open and short circuit across heater relay(s). If the wiring isn't the issue, he/she would need to determine whether the problem rest with the main control board. It really could be a hit or miss calculation in parts so I would personally reach out to an experienced tech that will be able to identify the precise reason.
Dec 01, 2013 | Frigidaire Electric Dryer
Dryer code says "loc" and
Hi, "LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
Jul 20, 2011 | Frigidaire Electric Dryer
My fridgidaire affinity dryer has loc error and will not let me start it
The control is locked to avoid having someone accidentally start or stop the dryer. Press and hold the Options and Select buttons for 10 seconds or until the "LOC" on the display is cleared. Locking the control is done the same way it is unlocked.
Mar 04, 2011 | Dryers
hold down "OPTION and "SELECT" button at simaltaniously until screen resets. This should work for you.
Jan 01, 2009 | Dryers
LOC Error
Your child LOCk feature has been activated and will not let you do any further actions until you unLOCk it. Look in your users guide for unLOCking instructions.
Feb 10, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
Jan 24, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Error code "loc" on GLTF2940ES0 washer
turn the selector knob so the machine comes on then press the "options" and "select" bottons at the same time for 3 seconds.
Oct 10, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Affinity 5.8 Cu. Ft. Super Capacity Electric Dryer Logo
404 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
