Question about Smeg A1A.1 Gas Kitchen Range
Oven enblems, i have a smeg gas range but no instructions, i would like to know what the visual oven signs mean next to the temp gauge can you help me, kind regardsĀ  colin gotts email. colongotts@mac.com
  • 409 Answers
SOURCE: SMEG A 2.5 Range Oven
sound like the TOD to me. have a technician replace it.
Posted on Sep 13, 2008
  • 417 Answers
SOURCE: my smeg oven,(bottom fan oven)
The thermostat is obviously not working and you will need to replace it.
The thermostat is located behind the temperature selector switch on the control panel. The oven thermostat usually has a capilliary tube attached which goes in to the oven internally and is fixed on to the oven wall you will need to disconnect this also and remove it with the thermostat. Fitting the stat is the reverse of removal.
Make sure the electrical supply to the oven is switched off before starting work Hope this will FixYa.
Please remember to rate this solution.
Posted on Dec 12, 2008
  • 112 Answers
SOURCE: Smeg A2A all the Gas burners turn off intermittently
I think it`s got a regulator at the back where it connects to the gas.
Get it checked for the correct pressure.
Posted on Feb 02, 2009
comike187
  • 17 Answers
SOURCE: i have a smeg range, gas burners electric ovens.
it sounds like the main oven is in timer mode on the timer please read instructions
to rectify
Posted on Jun 15, 2009
SOURCE: I am a quailified Gas Safe regirtered engineer who
HI ,I have just managed to remove hinges from a smeg a1.1 range. to get hinge out you have tohook up a small holding catch on the bottom bar and thenforce open the hinge, the topbar thencatches on the small catch which then holds the complete hinge open .The whole assembly can then be pulled out. The holding catch is only about 1" long but is easily flicked up with a screw driver Paul 07776 438 408
Posted on Feb 24, 2010
Err 5 on Smeg Electric built in oven. SCP112SG8 . Oven will not switch on but has power to the clock and light inside. Seems to be no easy Help from Smeg to retrieve these error codes. Please could...
1.a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Mar 16, 2015 | Smeg Ovens
I want to set the time on my smeg oven but do not know how to
with model is your oven?
In the link bellow you can find the user manuals for varius models Smeg has to offer.
http://www.smegappliances.com.au/ProductManuals.aspx
Mar 01, 2011 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Erratic oven temperatures adjusted the thermoatat as per instructions in manual no change
if adjustment of the screw behind the oven knob did not help:
replace the oven thermostat the part can be found at: searspartsdirect.com
Sep 05, 2009 | Kenmore Kitchen Ranges
Smeg A1 cooker built in. Wish to remove top to access thermocouple. Cannot see the fixings for the top. Any pointers please?
my smeg oven has always never worked properly, the temperature is faulty etc i now want to remove this oven and have bought a new electrical oven but cannot seem to get the smeg oven out. How do i remove this smeg oven?
Mar 20, 2009 | Smeg A1A.1 Gas Kitchen Range
Smeg Oven blowing
do you mean it's popping the breaker? sounds like you need to check the electrical circuit for a TOD. it needs to be replaced.
Dec 22, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Main oven failure
Shut off power at the mains breakers and restart. This may reset the unit.
Dec 10, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
I need users guide
I need to replace oven light bulb for  Smeg gas oven range cook unable to take cover off to get at bulb any ideas how this is done?
Oct 28, 2007 | Smeg SUK61MFX Gas Kitchen Range
Smeg SA995XR Oven
Hello, I know this was a while ago when it was posted. But do you still need a manual? I can email you one if so!
Sep 08, 2007 | Smeg S1100MFX5 Electric Single Oven
Smeg A1A.1 Gas Kitchen Range Logo
37 people viewed this question
Top Smeg Kitchen Ranges Experts
ashburton
Mike Carew
Joseph Mueller
Joseph Mueller
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
