Question about LG 32LG30 32 in. LCD HDTV
I have two problems: 1. several chanels will not come in very well - the have lines, distortion, picture is in "squares", no sound. Sometimes it is an acceptable picture but is is on for 1-2 secs, then blank for 5 secs, very little sound. 2. Finding the channels-the auto setup catagorized the channels into four groups, when in one group, it is very difficult to switch to another - it must be easier than this, but the manual doesnt address this. Help please?????
    Brigadier General:
  • 8,909 Answers
The description of "picture is in squares" is typical of poor signal conditions. It is called "blocking". The screen is made up of blocks of bits of the picture and is reassembled by the uProcessing inside the digital set. Clever really!
If you get your signal sorted out you will find that the processor will have more time to do as you request with menus and channel sorting.
Hope that helps.
Posted on Dec 31, 2010
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Have sound on westinghouse 42 in tv but no picture..just vertical thin lines..thia happened suddenly have hd box rebooted cable. tv will not turn off or on but has power
check it against another computer if the same result then its faulty
is your graphics card a standalone if so that could be the problem
but i am assuming it built in then option 1
Sep 18, 2014 | Westinghouse Tx-42f430s 42" LCD HDTV...
When i'm on "clean" my
Volume is a relative thing and our ear's perception can be quite different than what we expect. With distortion the spectral energy is spread out from the spectrum on the clean setting. The ONLY way you can check the output is with an oscilloscope looking at the output waveforms. The RMS output under distortion will "appear" louder as the waveforms are squared up and nearer flat-topping a lot compared to the output when clean. The amps have several gain stages and the numbers on control settings have very LITTLE meaning regarding whether the amp is near max. Only checking the output waveform with a scope will give a true picture.
You should procure a sound meter also to help in measuring sound pressure levels. There are OSHA limits for hearing protection now to pay attention to.
Feb 12, 2011 | Peavey Vypyr Tube 120H Amp Head
Funny colours on screen?
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 01, 2010 | Televison & Video
Hi my problem is I have red lines across the screen with double picture
These sets have several common problems listed below.
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
You can see some examples and find a fix here...
Mar 19, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Problem with Sony KP46WT500: Each line on the
Symptoms:
  • Colors wont align
Mar 16, 2010 | Sony KP-46WT500 46" Rear Projection...
Seems like a line across the screen picture looks like it is smashed and sound is fine
Symptoms:
  • Colors wont align
Feb 08, 2010 | Philips 51PW9363 51" Rear Projection...
Samsung HDTV 1080I-Model#HCP4363W-Convergence Problem
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
  • Screen Looks 3-D
  • Colors wont align
Problem #2
You can see some more examples and find a fix here
Jan 21, 2009 | Samsung HC-P4752W 47" Rear Projection...
Problems with TV
Our 37 inch Sanyo LCD HDTV has a problem with the picture distorted by being too wide. This has beenia problem for the duration since we bought the TV about three months ago. The PIX Shape button on he remote does not adjust this problem. We need help in solving the problem. Thank you.
fred_story@cpmcast.net
Oct 24, 2007 | LG LRSC26980 25.2 cu.ft. TV Refrigerator...
LG 32LG30 32 in. LCD HDTV Logo
196 people viewed this question
Computer Repairing
Computer Repairing
