Question about Kenmore Washing Machines
WASHING MACHINE CODE Sd ...WONT SPIN TO FULLY DRAIN CLOTHES???? DID A FULL RESET AND CHECKED THE PUMP INLET AND ALL CLEAR.....what next?? thanx
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
The problem is with the pressure switch. The pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit.
Posted on Dec 31, 2010
What does the code nd mean on an apartment size front loading stackable kenmore washing machine mean
ND, I would suggest means no drain. If the machine is full of water, it wont let you open the door. Put the drain hose into a bucket to drain the water out and turn off the machine, after a few minutes, the door should unlock. Check the pump or the pump inlet hose for blockages.
Dec 23, 2014 | Kenmore 3.4 cu. ft. Capacity Compact...
417 44152400 21 code reads e63 and machine not draining properly
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
Nov 01, 2013 | Kenmore Front Load Washer
I have been getting the Sd code and then F21 code during regular wash. I followed directions cleaning out white filter on bottom of machine and it did not help. So I followed directions for resetting the...
need to replace the part but dont try it if you dont have idea how to do.
call the technician for your safety and not to waste money.
Oct 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Eo5 beko wme8227b
Hi if your beko wme8227b washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Jul 04, 2012 | Whirlpool Washing Machines
BOSCH WASING MACHINE WONT SPIN OR FINISH CYCLE AND MAKES CLOTHES DIRTY
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jun 27, 2012 | Bosch Classixx WFL 2066 Front Load Washer
My beko wm5140w washing machine wont start cycle but lights are still on
Hi if your beko wm5140w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Dec 20, 2011 | Beko WM5140W
Zanussi 1140m stops half way through wash cycle then displays error code E21.....works ok on stright spin cycle....filters checked and found to be clear
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jul 19, 2011 | Washing Machines
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Hi there, i have a hoover elite 1220 i think 7.5kgs i brought it second hand of ebay and it has been a good machine but it has started to play up lately. It washes all on the normal cycles and stuff i...
Following will be the causes for water not draining properly
1.There is a motor/Pump which operates to to drain the water check whether that motor is working.
2.Check filter and clean it
3.Check the drain pipeline whether it clear
4.Check the inlet valve of the machine Sometimes the drain works properly but the inlet solenoid valve will not hold and the water keeps coming in and fills the drum
Thank You
Sep 02, 2010 | Hoover HTC243 Top Load Washer
Washing machine wont spin (beko 1512 s)
Hi if your beko 1512 s washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Mar 19, 2009 | Washing Machines
Washing Machines Logo
14 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
