Question about Tecumseh Enduro Horizontal Engine 5 HP 2532in x 2 2532in Tapered Sha
Tecumseh carb 631827. Took it apart, cleaned everything and re-assembled. The inlet needle will not let gas into the bowl. I took the needle out and the bowl filled up with gas. Why is the inlet needle not allowing gas into the bowl?
  • 3,740 Answers
Hi I am Kelly, I realize this post is nearly 10 months old. I am answering it now because it appeared after I made another post. Hopefully the repair information can be used by others.
Using this link:
http://www.partstree.com/parts/dispdiagimg.php?src=r&ilFN=D%3A%5CEMPARTweb_52%5CCatalog+Data%5CEMP_IMG%5CTEC%5Cimages%5Cimages%5CCA01%5C1.TIF&ilSC=10&ilIV=0&ilBR=0&ilIF=G&ilRE=8&ilSH=0&ilEG=0&ilRO=0&ilSC=34
Item 31 (spring Clip) is what is used to lift or lower the float needle. If the spring clip was bent or installed so that the spring was on top of the float needle head vs cliped to the recessed area of the float needle you will have the symtom you described. Usually you do NOT have to bend the spring clip to install it correctly. However, if it was bent during installation you will have to shorten the distance of of the spring clip horse shoe fold so that it lowers the float needle when the float is lowered.
See the picture on page 40 of this manual for the correct spring clip installation view: http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals/TECUMSEH_CARBURETOR_TROUBLESHOOTING_AND_IDENTIFICATION_GUIDE.pdf
One other thing to consider is that if the float needle seat is not pressed all the way into thebody you will have the symptom you described.... i.e no fuel flow with float in the lowered position.
Good luck,
Kelly
Posted on Sep 25, 2011
Mikuni carburetor overflow
Hi, Wes and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
8. Damaged petcock diaphragm allowing fuel to flow through the vacuum line into the combustion chamber.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
mikuni carb overflowing out of ideas
http://www.accessnorton.com/viewtopic.php?f=1&t=11291
Mikuni Carb gas overflow problem
Carburetor Carb Leaking Gas How to Fix Repair it Motorcycle Honda DIY...
Beta Rev3 Carb Problems can all be sorted by going through the info below
Apr 04, 2015 | Motorcycles
Huaya carb no gas in bowl
the needle has to fall down and follow the float movement
if it doesn't it is stuck on the seat and may need replacing as it has a small rubber section that may damage when pulled down
Apr 24, 2017 | Cub Cadet Electrical Supplies
13 hp tecumseh riding mower won't start unless gas is poured into carb. removed the bowl from carb has a wire snap holder float and needle and seat works OK and all passageways seem to be clean
hi
remove the bowl again and get the centre jet out and lok very closely use a jewlers eye piece you wll find a passage that is plugged on the side of the jet look around it you ll see some sign of a hole that is not clear through its pretty small use a welders torch cleanng tool with various size rods use very thin one dont make the hole bigger
Joe
Oct 01, 2012 | Tecumseh Garden
2003 Honda CRF 150 F gas leaking out the carburetor vent tube
needle not attached to float properly or a hair or the like not allowing the needle to close off properly
Nov 18, 2017 | 2003 Honda CRF 150 F
I have a Murray Riding Mower won't start. I took
clean fuel line and carburator out real well with a good quality carb cleaner this should do the trick,take the carb apart to do this check needle valve where gas comes in to the carb bowl it is alot of times plugged up
May 29, 2010 | Briggs & Stratton Garden
We have a 924056 ariens 10hp snowblower. It wasn't get gas to the spark plug and we took the carb apart and all is clean, clear and good. We are wondering if the governor is bad but cannot find any manuals...
Sounds like needle valve on carb. float sticking ,initial settings for tecumseh eng. is main jet , or the one on the bottom of bowl is 1 and 1/2 turns out after gently seating it . the low speed jet on the side is 1 turn out after gently seating it. may also want to check fuel filter and check vent on fuel cap. hope this helps
Jan 01, 2010 | Ariens 34 In. Zoom Series Riding Mower
I have an older mercury 4hp 2 cyl. Wont run. got lots of spark, gas was running out of carb, took it off, cleaned it out, but I might have the spring on the float in wrong. does anyone have a scematic?
Ok, if you have fuel coming out of the throat of the carb then you need to readjust the float level. On that engine the best way to set the float level is to remove the carb. Remove the fuel bowl. Turn the carb upside down so the float is on top of the carb. You want to bend the tang (the piece that seats the inlet needle) so that if you are looking at the float it sits perfectly level. Once you reinstall the bowl and carb be sure to adjust your idle mixture and try it again. If it still spews out of the carb throat then take it back apart and do it again. If the inlet needle point is worn at all then you need to replace it so that it seats good. But if you set the float it is level when the carb is upside down you should not have a problem. You can put your faith in the fact that every spring I rebuild about 5 outboard carbs a day from people letting fuel sit during the winter.
Jun 07, 2009 | Boating
Power Washer Will Start but not Run
Hello.....sounds like you might have debris in your fuel as well..... need to take off the carb and gas tank....let the fuel from the gas tank (fuel line still attached) run into a jar and check for debris and/or water in the gas....is you see that, get rid of the gas in your mower and your gas can, then buy new gas and a gas can (if metal...could be rusted)....second....take the fuel bowl off the bottom of the carb, careful to save the gas to check for debris / water (this also helps indicate the quality of your gas)....clean the bowl nut with fuel ports (3) and the injector port inside the center post which the bowl nuts threads into.....use carb cleaner to make sure all is clean....use a small wire to assist cleaning if necessary....also remove the float and needle valve....careful to note the assembly to reassemble....and clean with carb cleaner the valve area as well....this will insure all debris is clear.....reassemble the carb and gas tank....this should clear up the problem....
May 25, 2009 | Craftsman Garden
Powermate 5000 leaks gas from the air filter..not sure how it's getting into the air filter?
My Coleman Generator 5000w with a Tecumseh 10hp story. Mine engine finally did die before I pulled the carburator off.
On mine the float was defective. It was full of fuel! I repaired the hole in it. I removed the air filter and saw fuel pouring out the side so much that I had a jar to catch it. I removed the carburator and took the nut off the bowl to examine the float. Then I removed the pin holding the hinged end of the float. Carefully pulled it out with the needle valve attached. When I removed the needle valve (just slides on mine) it was free to test. I tested by shaking it near my ear and I could hear the fuel inside the float. Mine was brass or copper. I wiped mine off with a napkin and finally found the hole. I drained the fuel by polking a needle sized hole and removed the fuel. I then soldered the hole shut with using just electronic 60/40 resin solder and a small soldering iron. Mine works like a champ now.
Mar 08, 2009 | Coleman Powermate Powermate 5000W...
Snowblower wow's
tecumseh snow engines are natorious for not starting,first thing you need to do is take the old gas from the tank.gas only stays good for about 30 days.YEP .....that's all.there should be two screws that holds the cover over the carb.take the bowl off and there should be water and dirt in the bowl.clean that out,be careful not to drop the needle off the float.if you do it take a little patence to put it back on.now the nut you took off the bowl has three holes in the side of it.clean all the holes,one is really small and it's up twards the theads..replace the bowl gasket and reassemble the carb.now you should have fuel to the cylinder and it should start.if not let me know
Mar 02, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh Enduro Horizontal Engine  5 HP 2532in x 2 2532in Tapered Sha Logo
433 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
