Question about Panasonic KX-TG2431 Cordless Phone
Where or what is the OK button on a Panasonic KX-TG6521E
Cannot switch off "ring off" on Panasonic portable handset KX- TG2511
Which part of the manual is not clear?
You press the MENU/OK button, use up/down-arrow to select "Handset Setup" and press MENU/OK, use up/down-arrow to select "Ringer Setup" and press MENU/OK, use up/down-arrow to select "Ringer Volume" and press MENU/OK, use up/down-arrow to select the desired volume and press MENU/OK.
Nov 18, 2013 | Panasonic Lands Phones
Manual for Panasonic Handset KX-TGA560B
For the KX-TG5672, you should press and hold the Intercom button until the charge indicator flashes. Then press the button to assign the handset # 1, 2 or 3 (keypad 1, 2 or 3). Then press OK on the handset and wait for the handset to beep. These steps must be done within a minute from when the charge indicator flashes. It's best to have the base and the handset close together when you register the handset.
Panasonic has the manual for the TX-TGA560 available here: http://service.us.panasonic.com/OPERMANPDF/KXTGA560-MULTI.PDF . (This manual covers both the KX-TGA560B and KX-TGA560M.) The manual for the KX-TG5672 is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG5671S.pdf .
If you still have a problem, try removing the battery from the handset and disconnecting the power cord from the base (from the wall and the base itself). Wait a few minutes and then reconnect the power cord and the battery for the handset. (Make sure that the base has power and the adapter is warm.) Then try registering again.
I hope this helps.
Jan 03, 2012 | Computers & Internet
Need instruction manual please for a panasonic cordless telephone/answering machine TG6521E please
Google shows a PDF version of the manual to be avalable at : http://www.cordless-phones.uk.com
Size = 2.52MB.
Search terms: "manual TG6521E"
Apr 12, 2011 | Hardware & Accessories
I have a cordless panasonic kx-tg1031s ringer is off how do i get it on
To program the volume level of the handset, press the MENU button, then use the up or down arrow buttons to navigate to the HANDSET SETTING menu and press OK. Again using the up or down arrow buttons navigate to the RINGER SETTINGS submenu and press OK. Using the up or down arrow buttons navigate to the RINGER VOLUME submenu and press OK. Use the up or down arrow buttons to select the desired volume level and press OK. Press OFF to end. I have included a link where you can download the manual if you need it.
http://service.us.panasonic.com/OPERMANPDF/KXTG1031.PDF
Mar 25, 2011 | Panasonic KX-TG2740 Cordless Phone
I can't switch on it. Battery is ok. It's a Panasonic KX-TG2224 Cordless headset thx Istvan
I think from what I remember, you have to locate the power button and press and hold until it comes on. the same if you need to turn it off.
Jul 25, 2010 | Panasonic KX-TG2224 Cordless Phone
Need to clear out a used kx-tga270s handset
press function, initial setting, registration, deregistration, enter 335(deL) and then press Ok (right button on screen).
Once that is done press mute on the base unit and Ok on the hanset (right button on sreen)
Mar 28, 2009 | Panasonic KX TGA270S Cordless Expansion...
Model no kx-TG7120E is it possible to the rid the last dialing no
Press the redial button (the one you describe).
Press the OK button, it will display "Erase"
Press OK again, it will displa "Erase? Yes, No.
Scroll to Yes and press OK again.
Feb 17, 2009 | Panasonic KX-TG2431 Cordless Phone
Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Oct 18, 2007 | Panasonic KX-TG2740 Cordless Phone
Panasonic KX-TG2431 Cordless Phone Logo
216 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
