Question about Norelco SmartTouch 9160XL Electric Shaver
The triangular tip at the end of one of the three rotating drive cylinders has snapped off. The part is a plastic cylinder approx. .33" diameter by .75" long with a triangular tip at one end. Where can I purchase this part?
  • bworthington Jan 02, 2011
    Your response was very disappointing and not helpful at all. I have already contacted Norelco service and been told that they do not sell this part. The things that would be helpful to me are:
    1. A Norelco phone number (or website location) that would get to someone who will accept an order for this part.
    2. The location of a dealer in shaver parts that might have this item.
    3. The location of a dealer in used or broken razors that might have an old broken razor that I could cannibilize for this part.
    I have disassembled the razor and removed the broken part. It would be a simple matter to install a good part if I could find one.
    Please try to help.
    Thanks
    President:
  • 1,139 Answers
Hi there, usually the best place to go for parts is straight to the manufacturer. This webpage links to the Philips/Norelco website with all available parts for the shaver. If none of the parts you describe are listed then it may mean it is a more specialised repair and may need to be sent away.
http://philipsparts.fox-international.com/PhilipsConsumerModelDetail.aspx?hlt=Link_Accessories_Norelco&scy=US&model=9160XL/43&slg=AEN&mid=Link_Accessories_Norelco&session=20101126223607_66.249.65.7&ctn=9160XL/43
I hope this helps and thank you for using FixYa
Posted on Jan 01, 2011
  • Kevin Penn Jan 02, 2011
    I am very sorry I was not able to answer your question to your satisfaction. I personally feel you will have quite a bit of trouble finding this part for your shaver, even if you could locate a "broken shaver" dealer. One thing I could suggest is to take a look on ebay for a used one. I see one that has sold on ebay for $45 recently and there are more for sale too, this may not be what you are expecting to pay to repair your shaver but it seems the easiest solution other than buying a new one.
Videos on replacing ignition cylinder in 1984 ford f-150
you don't need a video //// on the bottom of the plastic shroud that covers the steering column you will see a hole & inside is a shiny metal button if you don't have the keys you must drill out that button then you will be able to twist the lock cylinder forward to remove it make sure the battery has been disconnected before you rotate the cylinder because the truck will start////// to replace the cylinder you must put the key in the new one and rotate it so the tip fits into the shaped hole in the column also the steps on the outside of the cylinder must fit into place then you can turn it back and the cylinder will lock itself in when the shiny button has popped into place
the tip you see here above ^ and the steps on the side
now you should understand that's the button you drilled out on top that locks the cylinder in the bottom of the column have fun it won't take to long or be to hard to do but that button will not let go till it is drilled past the hole in the column o.k. so get a nice sharp and greased bit for cooling and rip it up
Mar 16, 2015 | 1984 Ford F 150
Craftsman Air Comp. 6 hp oil-less, 33 gal horz. tank - sounds really loud
Some of the craftsmen compressors have pistons that are coated on the top of the dome. Once the coating wears off, they have severe loud piston slap. If you continue to run it the way it is, it will snap the connecting rod in half or break the piston and possibly the cylinder.
Sep 21, 2017 | Craftsman 33 gal Air Compressor 6 hp...
To JTurcotte - Your discussion and directions on how to repair the 1990 Jeep Cherokee srteering column were very good. I have a similar but not exact problem. The key would not come out of the...
WHEN YOU INSTALL NEW LOCK CYLINDER, TURN THE KEY TO THE LOCK POSITION. INSERT THE LOCK CYLINDER INTO THE HOUSING FAR ENOUGH TO CONTACT THE DRIVE SHAFT FORCE IT INWARD AND MOVE THE IGNITION SWITCH ACTUATOR ROD UP AND DOWN TO ALIGN THE COMPONENTS. WHEN THE COMPONENTS ALIGN, THE CYLINDER WILL MOVE INWARD AND THE SPRING LOADED RETAINER WILL SNAP INTO PLACE LOCKING THE LOCK CYLINDER IN THE HOUSING.
Sep 11, 2011 | Jeep Cherokee Cars & Trucks
I cant see anything. I don't see a hole for a battery am I missing something? I have a telescope with three cylinders attached and all three have eyepieces that I could look through. One of the...
Take the scope oput during the day tiome. DO NOT opoint it at the sun. Point it at a distant object like a telephone polem or a building.
Look through the eyepiece with the largest NUMBER written on it-- and or the largest glass surface.
Turn the knob until the object comes into focus.
Read my tips on my profile page.
May 19, 2011 | Edu-Science (10166) Telescope
I HAVE A IR UP6-30 SCREW COMPRESSOR. AS LONG AS THE AIR IS BEING USED IT CYCLES FINE. IF THE AIR VALVE IS CLOSED, WHEN IT GETS TO 120 PSI THE BELT STARTS SQUELLING DO TO THE SCREW LOOKING UP. OPEN THE...
Replace and tighten the drive belt first. This will require replacement of the small cylinder at the top of the air end near the inlet valve. This cylinder has approx 600 psi on it. Where it attaches at the air end take a 1/2 inch drive rachet and put the end in the square on the tensioner bracket and rotate the bracket toward the front of the compressor.(turn counterclockwise) This will let the cylinder extend and remove the tension on the belt. Remove the cylinder by inserting a small screwdriver under the retaining clip and release it. The end can then be easily removed from the ball. Do the same for the back clip. If you will pull these clips out before installing a new cylinder it will made installation easier. Before installing the new cylinder remove the side panel by removing the screw plastic covers. Then remove all the screws except the top two. Loosen the top two screws. Lift the side cover off the two screws and remove. The screw heads are 10 mm and they will fall down in the panel if up don't have a magnetic insert or bit. This info is for a up6-30 horse power unit.
Mar 07, 2011 | Ingersoll Rand Stationary Air Cooled...
I'm trying to figure out how to release the tumbler to get the igintion out???
YOU HAVE TO PLACE THE KEY IN THE LOCK AND ROTATE CLOCKWISE TO THE RUN POSITION.INSERT A STRAIGHTENED END OF A LARGE PAPER CLIP INTO THE HOLE IN THE CYLINDER AND PULL THE KEY AND LOCK CYLINDER FROM THE HOUSING.WHEN INSTALLING THE CYLINDER ALIGN THE CYLINDER AS IT WAS STILL IN RUN POSITION WITH THE KEY IN.THEN PUSH THE CYLINDER IN UNTIL IT SNAPS IN POSITION TURN THE KEY TO THE LOCK POSITION.AND REMOVE THE KEY.
Mar 29, 2010 | 1997 Volkswagen Jetta
I snapped key in bad weather have daewoo lanos
snapped key into what lock cylinder or ignition switch or do you have both ends of the key itself or not ?
if you have one end stuck in either lock / ignition cylinder you can try using a welders torch cleaning tip kit it contains many various sized brushes and files etc which will allow you to get in beside the broken end of the key and wiggle it out .,,,any parts store should have them ...
Feb 10, 2010 | 1999 Daewoo Lanos
How do you replace the ignition switch on a 1994 Lincoln Town Car?
Here is how to remove ignition lock:
   Rotate ignition lock cylinder to RUN position. Using a 1/8-inch drift, depress lock cylinder retaining pin through access hole and remove lock cylinder.
Carefully NOTE: the position of the bearing retainer prior to removal.
   Remove blue plastic bearing retainer by inserting a screwdriver or similar tool, with a 90 degree bend on the tip, between bearing retainer and bearing and by prying upward.
   Insert tip of a screwdriver into Double-D slot of bearing, then rotate 90 degrees. Remove bearing.
   Remove lock drive gear. Carefully note relationship of lock drive gear to position of rack teeth.
Here is the installation:
   Position lock drive gear in base of lock cylinder housing in the same position as that noted during removal procedure. The position of lock drive gear is correct if last tooth on drive gear is meshed with last tooth on rack.
   Position bearing retainer in lock cylinder housing. Insert tip of a screwdriver into Double-D slot of bearing, then rotate 90 degrees.
   Press blue plastic bearing retainer into lock cylinder housing. Ensure retainer is in its original position.
   Line up flats of drive gear with flats of washer by pulling down on the column lock actuator.
   Install lock cylinder assembly.
   Check for proper start in PARK and NEUTRAL. Also, check to ensure start circuit cannot be actuated in DRIVE or REVERSE positions and the column is locked in LOCK position.
May 04, 2009 | 1994 Lincoln Town Car
Put together
1 Chrome Rail (for attachment to Worktop)
4 Self-Tapping Screws (to attach chrome rail)
1 CO2 Cylinder Support Stand
1 CO2 Cylinder (empty)
1 CO2 Regulator (high/low pressure gauges)
1 CO2 Air Line Hose (red)
2 CO2 Air Line Hose Connectors (black)
1 Beer Keg Coupler
1 Beer Tower Unit (complete with faucet, hose and wing nut)
1 Rubber Washer (to be installed inside wing nut)
1 Beer Tower (Quick Connect) Bayonet Attachment (beer tower installation)
4 Machine Screws (to attach bayonet to beer tower)
1 Gasket (beer tower base)
1 Pull Handle (beer tower faucet)
1 Beer Keg Stand (required for 30 liter keg installations only)
1 Protective Plate (refrigerator cabinet floor)
2 Cantilever Wire Shelves (conversion to all refrigerator application)
1 Chill 'n Tap Exterior Cabinet Plug (located on worktop)
1 CO2 Air Line Hose Plug (located exterior rear cabinet)
1 Plastic Drip Tray (2 piece)
1. Remove Worktop: Using a Phillips Screwdriver, remove the
three screws located on the front underside edge of the
worktop and the three screws located at the rear (back)
side of the worktop.
See Fig's. 1 & 2
Remove the worktop from the cabinet and position the
worktop on top of the cabinet so that the front corners
are staggered across the front corners of the cabinet.
2. Installation of Top Rail: Attach the chrome rail to the work
top using four self-tapping screws from the underside of the
worktop through the pre-drilled holes. (attach the front ends
of the rail first)
3. Re-Install Wo r k t o p : Install the front of the worktop onto the
cabinet, then lower the rear side of the worktop over the
backside of the cabinet. Secure using the same screws
removed earlier. (the smaller screws at the front the larger
screws at the rear)
4. Installation of CO2 Cylinder Support: Install the cylinder
support onto the four studs located on the exterior back
wall of the cabinet. (no tools required) Align the holes in
the cylinder support with the studs and push down firmly.
See Fig. 3
5.
Installation of CO2 Cylinder: Install your " fully charged"
CO2 cylinder into the support stand. IMPORTANT NOTICE:
ALWAYS EXERCISE EXTREME CAUTION WHEN
HANDLING PRESSURIZED C02 CYLINDERS:
6. Installation of C02 Regulator:
Attach the CO2 Regulator to
the C02 cylinder by screwing the regulator nut onto cylinder
valve and tighten (snug) using an adjustable wrench.
7. Installation of C02 Air Line Hose to Regulator: Attach one
end of the (red) air line hose to the hose barb connection
on the CO2 regulator. Secure hose by using one of the two
(self locking) black plastic snap on clamps provided.
(use pliers to snap the clamp tight to assure that there are
no leaks)
See Fig. 5
Fig. 1
Fig. 2
Fig. 3
Fig. 4
Fig. 5
CHI
See Fig's. 1 & 2
of the rail first)
screws at the rear)
See Fig. 3
5. Installation of CO2 Cylinder: Install your " fully charged"
6. Installation of C02 Regulator: Attach the CO2 Regulator to
no leaks)
See Fig. 5
Fig. 1
Fig. 2
Fig. 3
Fig. 4
Fig. 5
LL'N TAP ACCESSORIES (included with this unit)
Jan 07, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Norelco SmartTouch 9160XL Electric Shaver Logo
108 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
