Question about GE 23.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black
What part would be causing the water dispenser to keep dripping after dispensing water ? it drips 50 to 70 times after using it model TPX24PBBGBB
  • 4 more comments
  • crdbgorr Dec 31, 2010
    Ge refridg mdeol TPX24PBBGBB
    10 years old
    the water dispenser has started to drip 50 times or so after you dispense some water.
    what would be causing this ?
    hello,
    on the GE site they show three different valves
    do you know which one is the fill valve ?
    WATER VALVE ASM 799 WR57X10024
    BRACKET WATER VALVE ASM 799 WR57X10022
    WATER VALVE ASM 795 WR57X1023
    thanks,
    Brad
  • crdbgorr Jan 01, 2011
    I ordered the valve
    hopefully that takes care of the problem
    your help was quick and to the point
    Thank you, Rick
    Brad
  • crdbgorr Jan 02, 2011
    I would Rick, but I can't find them.
    where should they be shown at ?
  • crdbgorr Jan 06, 2011
    there most be something wrong Rick,
    no matter what page I go to , I can not find any thumbs to chose from
    I would like to rate it for you, but I don't know what else to do
    Brad
  • crdbgorr Jan 07, 2011
    yes, solution was helpful
    4 thumbs up
  • 1,998 Answers
Hello
Poor or low water pressure can allow the fill valve to stay open and bleed a little water through all the time, bad fill valve, water tank/resevoir breathing( flexing ) and some water is being pushed out are -some- common trouble makers.
The fill valve has one entrance and 2 exits, disconnect the chilled water exit ( 5/16 tubing ) to see if water is dribbling past the fill valve all the time, causing that drip. Low water pressure to the fill or a bad fill valve can do this.
If that checks ok....
No pic Water tank-reservour
....the chilled water tank is likely flexing and pushing out the water drip = new tank time,the tank is behind the lower crispers in the FF section.
One problem that is becoming more prevalent is this sort of issue. More and more people are installing under-the-sink "reverse osmosis" water filtration units. These do not provide sufficient pressure to keep the water valves closed (Jeff touched on this earlier) - a typical refrigerator water valve needs about 30 psi for proper closure. Your refrigerator needs to be connected to mains water.
I have also been on the ge site and they are also suggesting to replace the water valve first before doing anything else if you are looking for the part goto www.marcone.com go under contact us there is a 1800 number this is the cheapest appliance parts place that i have found if you have any further questions please message me back and please remember when our chat is concluded to rank how this opinion has helped Thanks again
Rick
Posted on Dec 31, 2010
  • 4 more comments
  • Rick Ead
    Rick Ead Dec 31, 2010
    there sears site has it listed as the 795 http://www.searspartsdirect.com/partsdir...
    if you have any further questions message me back Happy New Year
    Rick
  • Rick Ead
    Rick Ead Jan 01, 2011
    Please remember to rank how this opinion has helped Thanks again Rick
  • Rick Ead
    hello brad by rank could you please check preferbly the four thumbs up box thanks bud happy new year to you and your family Rick
  • Rick Ead
    Rick Ead Jan 02, 2011
    where i posted there are thumbs in the first post i made Thanks again Rick
  • Rick Ead
    Rick Ead Jan 06, 2011
    Right underneath where it says posted 5 days ago on my very first solution that i wrote for your situation Thanks again Rick
  • Rick Ead
    Rick Ead Jan 07, 2011
    When closing a chat the User needs to click on the "End Session" button. A pop up appears asking the User if the solution helped him solve his problem, the User needs to click on the Accept solution button.sorry bud staff just told your not able to see the four thumbs but this is what you do to rank Thanks again Rick
    President:
  • 2,501 Answers
You don't say how long you have had the fridge but i would guess that you have had it some time and this problem has emerged recently.
If this is the case,then the tap may have something stuck in the seal..
I don't know your machine but other similar problems have been resolved by removing the tap and cleaning. (If there is anything in the outlet, then this could be the cause of your problem).
Water dispenser drips sometimes after filling a cup with water. Does not happen every time. If not addressed, the drip continues indefinitely. To stop the drip, I use my index finger to give a good poke...
When water leaks from the dispenser like this it will be caused by a defective water control valve that will not shut properly when off. The leaking water is the same as a leaking faucet. The KSCS25IN uses a=> W10247725-Water Control Valve or HERE
Sea Breeze
Sep 24, 2013 | KitchenAid KSCS25IN Side by Side...
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Problem: Water continually drips from water dispenser spout
Should be the water valve in the back. Over time the seals break down our debre in water will cause to leak. Sometimes new water filters will also cause small issues but shouldn't last long.
Aug 18, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
The water keeps dripping from the water dispenser how do I get it to stop
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jan 23, 2011 | Refrigerators
Water dispenser leaks on model number KSRS25FGSS13. I HAVE FLUSH THE AIR OUT AND IT STILL HAS A VERY SMALL DRIP
Probably replace the water inlet valve on the back where the water supply comes in. Disconnect the water line to the dispenser there and see if it keeps dripping when you try the dispenser.
May 10, 2010 | KitchenAid Architect 25.3 Cu. Ft....
Very slow drip from water dispenser. How do I fix
Good day,
A slow continues drip, but still dispenses O.K. is caused by the dual water valve on the bottom rear of the machine not closing completely.
Only fix is replacing the water valve assembly.
Mar 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dripping out of water dispenser tube
SOUND LIKE YOU HAVE A BAD INTAKE VALVE. IF THE WATER DRIPS ALL THE TIME.
Jan 12, 2010 | Kenmore Refrigerators
Kitchenaid model ksrs25ilss02 water filter
Are you saying water is dripping out the ice dispenser or the water dispenser, a water filter would have nothing to do with this, it only filters water, it does not pump water nor does it shut it off. If water
is dripping from the ice dispenser, it is because the rubber gasket
is bad on the flap that seals after ice is dispensed. If water is dripping
from the water dispenser, it is the shut off for the water, you can put a glass under it and push for water a few times,on and off and see if this makes it stop, if not you would need to have this replaced. Any questions please post back.
Mar 27, 2009 | LG LRSC26940ST 36" Side-by-Side...
Water dripps
I realize this is an old answer, but I'm experiencing the same problem and found what I hope is a much simpler fix:
https://youtu.be/hAEdjhaZoaQ
This is a Youtube video which explains how air trapped in the water line can cause a drip from the dispenser. Apparently, allowing a gallon of water to flow continuously through the dispenser should...uh...dispense with the problem!
Hope this helps you, and me!
Sep 21, 2008 | Samsung RS2534 Side by Side Refrigerator
Whirlpool side-by-side refrigerator - 2 problems
I would suggest that you get a certified person to come out and look at it you very well could have bent the doors in the move.
but... if you want to do it yourself.
click here for a walkthrough
for your drip:
Flush air from the water system the first time it is used and after replacing the filter. Air trapped in the water line or filter may slowly travel through the coiled water reservoir to the dispenser, pushing any water ahead of it. This can cause the dispenser to drip. Water needs to completely fill the lines for all air to be cleared.
  • Use a sturdy container to press and hold the water dispenser bar for 5 seconds, then release it for 5 seconds. Repeat until the water begins to flow. Once the water begins to flow, continue pressing and releasing the dispenser bar (5 seconds on, 5 seconds off) for an additional 2 minutes. Repeat if dripping starts again because air can re-enter from the water supply.
  • As air is cleared from the system, water may spurt from the water dispenser.
  • Make sure the refrigerator is connected to a cold water supply.
One or two drops of water immediately after dispensing is normal. It may be necessary to hold the container under the dispenser for 2 to 3 seconds after releasing the dispenser lever.
Jan 26, 2008 | Refrigerators
Water dripping from the water dispenser on freezer
If the water is dripping from the dispenser tube, you need a water valve. The valve is not shutting off completely. Check to make sure water is not dripping from ice chute. If the chute door doesn't seal off you will get moisture there and it will also frost up the ice chute.
Sep 30, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE 23.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black Logo
126 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
