Question about Saeco Classico Espresso Machine
No crema We have a Saeco Classico that worked very well when we first got the machine. Now the coffee is bitter and there is no crema in the shot at all. We tried changing grinds and tamping, nothing seems to work. Can you help? Thanks so much. We miss our morning coffee :-)
  • Anonymous Aug 06, 2008
    This is precisely what happened to my unit a few weeks ago. The machine is about a year and a half old, and has until recently produced excellent shots with thick crema. Suddenly, the shots have become extremely bitter, and virtually without crema. I had not decalcified the machine as frequently as suggested, but did in fact clean it a couple of weeks before the problems started. I've since replaced the coffee bean supply, adjusted the amount of grounds used, and tamped with varying degrees of density, all to no avail. For what it's worth, the unit also leaks a bit, dripping from the portafilter when frothing and likewise dripping from the steam wand when pulling shots.
  • patriceb Oct 25, 2008
    I hace the exact same problem !!!
    I have decalcefy it 3 weeks ago but now no more Creama !!!
  • 4 Answers
Sounds like the handle where you put the coffee in needs replacement, if you leave the machine on for long periods with the handle on there is a metal spring inside with plastic parts that regulate the pressure in the tamping basket. 9 BAR is the desired pressure to produce crema. the plastic parts can melt and the spring looses tension. If you place the handle on, lock it, the it should shift slightly backwards on its own if you have to help it I have bad news replacement time. I have seen replacement from 25.00 - 90.00. I have two classicos and already replaced one handle and have to do the next. It could take one time of leaving the machine on all day. Good to get in habbit of turning off the machine immediately after use let it cool slowly attached to unit and clean it when you get home. Immediate cleaining in cold water could make the spring fatigue faster and also cause this problem.
If you are brave and can remember where parts were; take the three screws off where the coffee comes from handle slowly separate the parts and you will see if plastic melted, is distorted or spring is like mush.
Here is the saeco parts diagram and parts ordering site but I warn you its the most expensive
www.saecoparts.com/SaecoEspressoClassicoBodyparts.html - 70k -
Posted on Feb 17, 2009
  • 515 Answers
How old is the machine?
Have you decalcify the machine?
Posted on Jul 12, 2008
My Saeco Classico has problem. The pump is working
It sound as though the boiler is blocked by scale. May also be the coffee filter that's blocked. I am not familiar with this machine, but assuming that it's just a manual espresso machine, try running it with the filter handle removed. Any water emerging? If so, the coffee filter cup and/or filter handle outlets may be blocked. If there is only a small flow the boiler is almost certainly blocked with scale and descaling may cure the problem (do the first run with the filter handle off the machine. Next run with it on)
Oct 22, 2013 | Saeco Classico Espresso Machine
Water does not heat
More then likely it's the boiler.
Apr 26, 2010 | Saeco Classico Espresso Machine
SAECO fully auto Traditional Very little crema
The crema is created by reducing the grinding to more fine so the coffee will run slower around 20 sec. Inside the coffee bean container their is un adjust control and with special tool you can turn it to grind the coffee to more fine.
Jan 03, 2010 | Saeco Royal Professional Espresso Machine
Baby Gaggia making a bitter brew, help!
Have you tried backwashing, then removing the shower and screen from the grouphead to make sure that there is no coffee buildup on the screen.
As for the leak around the portafilter, the group gasket needs to be replaced,
Jul 02, 2009 | Saeco Classico Espresso Machine
Saeco classico is overheating
Yes. Check the thermostats on the boiler.
Apr 17, 2009 | Saeco VIA Venezia
Hot water come out from steam wand when pumping Saeco Classico
Gasket on steam valve is worn. Replace gasket and or steam valve.
Mar 05, 2009 | Saeco Classico Espresso Machine
Steam still coming through brew group even when pump not ON
I posted response and solution to similar issue see post below and comments :
YOU NEED TO LET MACHINE COOL OFF AFTER YOU TURN IT OFF OUCH!!
You can release pressure placing a cup under steam wand open slowly and partially while machine is OFF and let hiss out slowly. Then open cup slowly if you have to force it open DON'T. That PUCK sound can make you afraid of your machine can't it. I wont admit I haven't done that four or five times.
posted by bronwenmair on Jul 08, 2008 Report abuse
Jan 20, 2009 | Saeco Classico Espresso Machine
Curious
Try to descale your machine, if there are calcium in the boiler then the coffee will have wrong temperature and tast bad.
Aug 06, 2008 | Saeco Aroma Espresso Machine
Saeco Classico is tripping the GFC outlet
Your machine has a bad heating element and is ground out to the boiler ground. You will need to have the boiler rebuilt.
If you need service you can contact Cerini Coffee Services in New York. More information go to www.Cerinicoffee.com or go to saeco's website to find a local service center.
Hope this helps!
Johnny
Sep 20, 2007 | Saeco Classico Espresso Machine
Soggy Pucks & Portafilter retains water Saeco Via Veneto
It sounds like you are short on water due to a blockage somewhere...either in the flowmeter or the group head. You might also have a faulty pump, and you're not getting enough pressure during the shot. If you're not getting crema, then it's most likely pressure related...shots will also have a burnt smell and very bitter taste.
Mar 14, 2017 | Saeco VIA Veneto Espresso & Coffee Maker
Saeco Classico Espresso Machine Logo
242 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
