Question about Air Tools & Compressors
A worker had a nut stuck inside the socket of a dewalt impact tool.The nut had a buildup of paint and got stuck on a regular basis. he put his finger in and accidentally pulled the trigger causing the nut to screw onto his finger. He excaped with his finger but in bad shape, loosing skin and deep lacerations. what could he have done to prevent this happening and what are the alternatives to removing the nut properply and safely?
#1... before attempting to remove the nut, unplug the wrench. #2 .... thread a bolt into the nut, and wiggle the hell out of it with pliers. Easy.
Posted on Aug 06, 2011
Dewalt 734 thickness planer I want to replace the plate but I cannot remove the screws from the guides Need help.
find out what thread direction the screws are before going brutal---an impact driver may have to be use to remove screws---don't know if they used lock tight on them or not from factory---impact driver is a tool that you insert in to the screw then rap the end of the driver with a mallet/hammer---this action keeps the screw bit buried in the screw and twists at the same time after being hit----this will work only if there's no lock nuts opposite the screw (other end).----GL
Jan 22, 2017 | Dewalt Tools & Hardware - Others
Are there any tips or tools to assemble tiny nuts and screws with big fingers?
Tape small screws or nuts to the tool with cellophane (Scotch) tape. ***** or tighten and then pull the tool away and the tape will come with it. Also, I sometimes use double stick tape to start nuts using a flat dowel rod with dbl sided tape on it. If you are working with larger nuts, stick a paper wad in the socket so the nut will remain at or above the level of the socket - put an extension on the socket, push the nut in place and start the nut by hand. When its "on" use the socket wrench to tighten it.
Mar 28, 2016 | Cars & Trucks
Dewalt how to take apart
Remove the 3 screws holding the foot on and remove it.
Slide the insulator and blade clamp lever off exposing the gearcase.
At this point you can remove the gearcase from the handle and can access the entire tool.
Removing the gear assembly will require removing the nut (#18) at the front of the gearcase (under a plastic cover) (best done with a 13mm socket on an impact driver) then removing the blade clamp assembly allowing the mechanism to slide out.
Jul 29, 2014 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
How do i insert bit in cordless dewalt keyless hex chuck?
It only accepts 1/4" hex shank bits and nut drivers. Mine just pops in and to release it, you push the black collar around the bit down. Cannot put round end bits in it. Only hex shanks
Oct 26, 2013 | Dewalt DW056 18 Volt Cordless Impact...
I cannot open a Dewalt 954 cordless drill chuck. My socket adapter is stuck in the chuck. It is a borrowed tool and I need to return it in the same shape that i received it. Help. No TWO men can exert...
if it is a keyless chuck soak the inside of the chuck with oil. charge the battery so you have max power. put a cloth around the chuck and use a pair of channel locks to hold the chuck and put the drill in reverse. good luck
Aug 21, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
My dw056 breaks bits can you change the hammer to a 1/4" or 3/8" hammer they look the same on the manual
in order to make the 1/4" hex drive impact drive 1/4" or 3/8" sockets, you need a 1/4" hex adapter for sockets.
They are available at most hardware stores. While i've broken several sockets, and many screwdriver bits, I've never had an issue with with the socket adapters.
You can also get an adapter that gives you a chuck like a conventional drill.
If you've been working them hard, it's not a bad idea to remove them, and put them back in. this reduces the chance of getting the bit stuck from the repeated impact.
As far as changing the chuck of the unit to another one, i'm not sure if it's possible.
Help me support children’s cancer research CLICK HERE!
Mar 08, 2010 | Dewalt DW056 18 Volt Cordless Impact...
How do I get the clutch hub nut off in order to replace the clutch hub?
You would be best getting an impact driver. Just put the right size metric socket on it then strike the end with a hammer to remove or to tighten the nut. Use it also to loosen and tighten the case screws. It is the most used tool in my shop. Sears has them as does any tool store. Just get a 3/8" drive (not the 1/2" drive) and you will make stuck screws, nuts and bolts a thing of the past.
Nov 27, 2009 | 2004 kawasaki KX 250 F
My drill is stuck in reverse
Use left hand screws.....or take housing apart to see what has jamed the selector switch.
Jul 28, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Need to replace rear air strut what tools do i need
hello, you are a brave man. Well you need a floor jack, or a good bottle jack to start, jack stands, 18mm deep socket, impact wrench, a 3" extension for you 1/2 or 3/8 tool set, several metric 6 point sockets, regular size. You will also need some open-end wrenches, such a box wrench, a vise grip. If you don't have a impact wrench, a 12volt electric impact wrench, the kind used for removing lug nuts will do. Just be prepared to toss it afterwards, if it is a cheap one. Also a 18" breaker bar, 1/2" size is highly recommended, with a 3/8 adapter for using 3/8 sockets. I hope this helps. Did you blow a air bag, or is one of the solenoid's gone bad?
May 10, 2009 | 1990 Lincoln Continental
UNCOOPERATIVE AXLE NUT
If I recall correctly there is no split pin locking the nut in place. Look at the faces of the nut. Any drill hole filled with a pin? Grab a propane torch and heat the nut/bolt. Try not to burn the paint. Tap the nut faces with a small hammer to assist in breaking the nut free from the rust holding the nut in place.
Use a hex socket or hex box end wrench. If you have an impact driver, use it with the hex socket. If you don't have an impact driver I strongly suggest you get one. They are low cost and the most used tool in my shop. I sleep with mine close at hand. If that nut is going to break free the impact driver is what will do it.
Please rate this solution after the impact driver has removed the nut. Thanks for the top rating! :)
Apr 22, 2009 | 2003 Honda CB 250 Nighthawk
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
