Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Unit was working fine. Ground up some brocolli. Now won't drain. Things tried: 1. Removed u-trap: water drained from sink. 2. Ran water w u-trap removed: water drians from sink. 3. Re-connected u-trap: Water does not drain. 4. used Allen wrench on bottom" spins freely. 5. Checked baldes inside: spin freely.
  • 312 Answers
If you pull the U trap out and run water through the Disposal and it comes out of the pipe, then there is nothing wrong with the drainage through the disposal. It's not clogged. If it isn't running, there is a small red button on the bottom that is a circuit breaker. If the button is sticking out, push it and it will reset the breaker. Every thing else with the Disposal you did perfectly.
It appears to me as though there is a clog after the Trap. There are several ways to unclog it.
A small snake will do normally, unless the clog is far down the drain system, such as between the house and the sewage or septic system. I have used another device with a hose that is a rubber bulb shaped device that attaches to a garden hose at one end and has a **** at the other end. When you put it into a drain pipe and turn on the water, it inflates and anchors itself against the walls of the pipe that is clogged. Then it forces water down the pipe to remove the obstruction.
Here is a photo. You can find these at places like Harbor Freight, Home Depot, etc.
Hope this helps. Happy New Year, Mark
Posted on Dec 31, 2010
Sink erator
First, unplug the power cord to the "Sink aerator" disposal from under the sink storage area. Next, remove the black rubber strainer from the upper sink area leading down into the disposal. (It simply pulls upward to remove) This will allow you to put your hand down into the disposal area to physically clean out the disposal deposits by hand. Pull out whatever is plugging the disposal and throw the debris in the trash, not back into the disposal. Once everything is removed from inside the disposal, flush it out completely with water from the faucet until it drains freely. Reassemble the black rubber strainer and plug in the disposal once clean. Be sure not to put potatoe peelings and other non-disposable items which can't be ground up easily in the garbage disposal. Keep in mind, just because it says garbage disposal, it doesn't mean all "garbage." Also, always use plenty of water when using the disposal and allow the water to run for a minute or so afterwards to finish washing down the debris in the sink "P" trap drain out through the outer sewer line.
Jul 07, 2014 | Home
Dishwasher won't drain
Good Morning Jean,
I see that you are having trouble with your Frigidaire dishwasher, model# FFBD2411NS, draining. There are a few things I would suggest:
1) If the appliance is hooked up to a food waste disposer, make
sure the disposer is empty.
2) Check to see if the knockout plug has been removed
from inside the food waste disposer inlet.
3) Check to see if drain hose is kinked.
4) Check the glass trap filter to see if anything is preventing the water from draining.
5) Overfill Protector should move up and down freely about one inch. If it does not move, lift and clean underneath. Clean occasionally with
household cleaner containing vinegar or bleach to dissolve any buildup.
If none of these suggestions help your dishwasher to drain the water, I suggest contacting your local authorized technician.
-Best Regards-
WP
Mar 26, 2014 | Frigidaire FFBD2411NS
Kitchen sink drain plugs every several days, sink has garbuator and dishwater attached
Yes, I had a really terrible time with my daughter's sink for the same situation.
After unplugging it about 4 times, I discovered 2 things.
1) She was putting stuff in the disposal that was not chopped up well enough to go through the drain.
2) The pipe I installed for the "tee" between the disposal and the "P trap" was not for a disposal, it was for an additional water drain like the dishwasher, so it was clogging all the time.
First I cautioned her to stop putting stuff to be ground up that would plug the drain.
Second I changed the "tee" fitting to a "large volume tee" and that solved the problem.
Be blessed.
Feb 14, 2013 | Dishwashers
I have a Badger 5xp & a double sink. When I turn the disposal on I get a small eruption of water, air and disposed of debris from the other drain.
Take apart the tubular drain pipes beneath sink and clean out everything.
Take photos before removing pipes so parts go back together easily.
Loosen 2 nuts on trap, and trap falls loose.
Remove 2 bolts/screws and remove tailpiece from side of disposal.
Then run snake down drain line leading away from sink to make sure blockage is removed.
I wrote ez disposal steps that give tips on reconnecting tubular drain pipes:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Sep 24, 2011 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Will not drain...but is turning....i tried to reset by pushing the red button and did nothing...i took the L wrench and turned it from the bottom and still nothing...sink is full of water too..what can i...
1) If disposal will not drain: Clean the tubular drain under sink.
Remove 2 nuts on p-trap, and trap falls loose, then remove tailpiece on side of disposal, hand rag over opening to direct water downward, turn on water, turn on disposal and see if disposal empties, clean p-trap, and then reassemble tubular drain.
2) If disposal will not drain and will not run: Clean tubular drain, check for power to disposal.
If disposal is getting power and will not run, and reset button is not tripped out, and cutter disk rotates freely, then disposal is bad.
I wrote ez disposal replacement steps that include tips for tubular drain.
Aug 21, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
BADGER DISPOSAL UNIT 5-81 SEEMS TO WORK, IT'S NOT STUCK BUT THE WATER WON'T GO DOWN IN THE SINK. ANY SUGGESTIONS.
Clean out the p-trap and tubular drain under the sink:
I wrote ez disposal replacement steps that cover how to take apart tubular drain pipe and put it back.
Jun 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Unit motor runs OK, but I have standing water. Water is not draining from sink.
The trap has a clog.
Put bucket under trap.
Get out some old towels.
Remove 2 nuts on trap, and it falls loose.
Clean the tubular pipes and then re-assemble.
Read tips about tubular pipes under the sink:
Mar 02, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How to replace the trap for kitchen sink..there is a leak in the kitchen trap
open to drain pipes. remove the collars that hold trap on, sometimes you may need pliers or a pipe wrench to remove.install is reverse of removal the trap is there to contain the gases in drain pipe. if no trap. you will smell sewer water all the time. 1-1/4 for bathroom drains and 1-1/2 for kitchen sink drain.
Sep 07, 2010 | American Standard Plumbing
Figidaire Dishwasher ModelFDB65BRAC1
I just had this problem with a zanussi dishwasher - I opened it this afternoon to find the bottom full of water - luckily not deep enough to flood my kitchen when I opened the door. I determined that the sink drain was clear (ran water, could hear it going down the drain outside), so the problem had to be in the dishwasher or drain hose. I poured just a little mr muscle sink & plughole unblocker in the bottom of the machine where the trap is, left it about 30 mins as per instructions, followed by a little boiled water - no difference. Scooped out the water, removed the filter (the big round bit, not just the trap that you pull out and empty) and scooped out till I could see what appears to be the out pipe. Thought what the heck and ran a rinse cycle - no dishes, no detergent and lower tray and arm thing removed for convenience. Water drained just fine, ran a second rinse cycle which got rid of the suds from the plughole unblocker. I now have an extremely clean and sparkling dishwasher and am about to run a load of dishes through it.
I hope that my post is helpful to you, I don't know if all the steps are necessary, it may have been a freak occurrence that would have gone away with a simple rinse cycle. It may of course be a problem with the pump on yours, I was hoping that wasn't the case on mine, and I had lots of old towels on hand in case water came out when I opened the door. But it's possible your machine has the same problem as mine and that this info works for you, I hope that is the case.
Sep 19, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
111 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
