Question about GE Washing Machines
Fill mode does not turn off resulting in the tank over flowing
If the water doesn't turn off even if machine unplugged it is the fill valve. This you can fix yourself. It costs around $10. If water does stop when turned off or unplugged it is probably the water level switch. This is also fairly simple to fix. It is the switch that you select the water level with. There is at least 3 wires and an air hose. If your machine does not let you select the water level , just look for a small hose from the bottom of the tub. This will lead to the switch.
Posted on Jul 09, 2008
Kohler 7000 series engine trouble shooting
indicates a problem in the carby , filter or fuel lines as a lack of fuel flow
remove the tap at the tank as there may be a small gauze filter there that is blocked
check tap operation for fuel flow as if it is a metal tap it could be corroded inside restricting fuel flow
check float level --too low
check for blockage in main jet
Jul 10, 2016 | Garden
When connecting the water to the city water connection it filled my fresh water tank. Is that normal?
Probable cause would be a leaking check valve in the pump.
On the RV the city water and discharge from the fresh water pump are tied together. When on city water the discharge of the pump will have city water pressure on it. If the internal check valve on the pump is leaking, water will flow through the pump backwards and into your fresh water tank.
Mar 15, 2015 | Heartland 2014 Gateway 3200RS
When set in smart mode it runs continuously and the core ices up this results in the filter not being able to be removed. water then runs all over the floor. This also happens in normal mode Very li
Ice builds up for two basic reasons:
  1. Impeded air flow. This causes the dehumidifier to run constantly as the humistat never reaches it setpoint as there is limited or no airflow over the coils. Even with a filter, the cooling coils can become clogged and render airflow restricted or non-existent. Check and correct as necessary.
  2. A low refrigerant charge. Systems can leak over time and become low on charge. This causes extended period of running and the resultant freeze-up. If the coils and filter are clean, have the system checked for proper charge of refrigerant.
Jan 02, 2015 | Dehumidifiers
Why does brine tank fill with water and overflows?
It sounds like there is a problem with either the valve in the head not sending water to the venturi jet when it is supposed to recycle or, the venturi or jet have an obstruction that is preventing it from creating the vacuum necessary to draw the brine back from the tank into the resin bed.
If there is water flowing out of the drain line during the recycle it is probably the venturi or jet need cleaning. If no water is flowing it is probably the valve assembly.
Nov 28, 2014 | Plumbing
Is difficult to fill gas tank
Gas pump nozzles have a device in the end that when gasoline runs back up into it, it turns off the fuel flow." There's a tiny hole near the bottom of the gas pump nozzle connected to a small tube.
Normally, air flows through that tube while you're filling and the gas keeps flowing as long as you hold down on the trigger. When that hole gets covered by gasoline (when your tank is full), a vacuum forms inside the nozzle and an automatic shutoff switch gets tripped, turning off the flow of gas with a thunk. Next time your fueling up try to reposition the nozzle.
Feb 26, 2014 | Chevrolet Cars & Trucks
Fill water tank
First, I'm not a Saeco technician.But I've worked on similar Saeco machines.
- Water not getting to machine or not sensing that the water tank is already filled.
* There usually some type of float near to middle of the water tank. It's usually white or colored plastic. This 'float' needs to move freely up-down to 'sense' the filled tank. clean the tank and shake it -note the movement of this float. It will need further cleaning if it's stuck (or you will have to replace tank if it's crudded up).
* Re-install tank and fill with filtered water. Turn machine off, count to 15 then turn on again. This usually turns on pump to add water to inner tank. If this does not happen then there is a CPU problem. If it does hums for 5-10 seconds then goes off but no heating then the pump may have an air bubble in line. Try the turn off and on method several times (up to 5) to get the water flowing. If it's still not working then there is a clog in the pump and will need service and/or replacement.
* Did you change water source? Since this is a table top machine in which you fill the water tank. Try to use filtered (bottled ok) water. Do Not use Distilled or 100% pure water as this type of water will eat out the metals from your machine! Some places use a water softener as it tends to be better for the machine long term (years).
* Still got problems? Check with vendor or MFR for service or replacement. Most machines of this type do not have serviceable parts or adjustments.
Aloha, ukeboy57
Aug 08, 2013 | Saeco Royal Professional Espresso Machine
Tank will not fill up after flush. i hear water
Fill valve in tank has a washer in it you take it off and make sure there is no trash restrcting flow and also chack out flaper to see if it is sealing correctly.
May 03, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
Jackson jpx-300. No water flow. No kinks in water
What you are hearing turning is the pump motor. The manual feature is for deliming the machine and and locks the unit in wash mode only.
It is likely your fill solenoid has malfunctioned if no water is entering the tank in a normal cycle.
Dec 21, 2009 | Jackson JPX-300L Dishwasher
Gas tank over flows when filling up
There is a tube that run down into the tank inside the fill pipe, it vents air as the tank is filled, if it is blocked your problem occurs, most likely it is kinked.
Sep 16, 2008 | 1998 Nissan Altima
How do I descale the saeco magic deluxe coffee machine?
Try this:
Standard descaling
Switch off the machine.
Pour a descaling product into the water tank.
Switch the machine on to the programming mode(see below). Place a large container under the steam/hot water dispensing tube and open the steam/hot water knob slowly, turning it counterclockwise.
Turn on the machine by pressing the main switch and let the descaling product flow out of the dispensing tube for approx. 1 min.
Close the knob again.
Turn off the machine with the main switch and let the solution take effect for approx. 5 minutes.
Repeat this procedure two or three times, to allow all of the descaling product in the water tank to flow out of the dispensing tube.
As soon as descaling has been carried out, rinse the tank thoroughly and fill it with fresh water.
Switch on the machine and let fresh water (approx. 2 l) flow out of the steam/hot water dispensing tube in order to rinse away residue.
The machine is now ready for operation.
When the machine is on, the warning light switches off automatically, by pressing the steam selection button for at least 5 seconds.
To enter the programming mode, turn the machine
off with the main switch.
Press steam , espresso coffee and the
main switch at the same time.
Release the buttons.
Hope this will help you.
/Mirran
Aug 16, 2008 | Saeco Magic De Luxe Espresso Machine
Washing Machines Logo
22 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
