Question about Briggs & Stratton Briggs and Stratton 030451 5000 Watt Portable Gasoline Generator
My neighbor gave me a 10 year old 5000 watt Coleman with a 10hp Briggs that was not running. It would run on starter fluid so I focused on a fuel problem. New fuel, fuel filter and oil. Dissassembled the carb and found no obstructions. The fuel pump guts looked fine too. The Briggs drawing showed 2 small springs in the pump that were not in this pump. I ordered a new pump. In the mean time I removed the pump and plugged the fuel tank line straight into the carb bowl and it started on the first pull. The tank is above the carb, so why is a fuel pump needed? Runs fine without the pump. Anyone have a good reason to reinstall the new pump when it gets here?
  • 6,826 Answers
That's interesting that you bypassed the fuel pump after noticing that the carburetor was below the tank, not needing a fuel pump to start the engine.
Maybe they put a fuel pump in to ensure that the float bowl valve is not the only thing preventing gas from overflowing into the carburetor when stored for a long period of time.
I would put the pump in if that's the way they originally designed the fuel supply for the engine, just to be safe.
Good luck on this repair.
Posted on Dec 31, 2010
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
My 3500 watt Coleman genset with a Briggs and S engine starts fine but shuts down after 10 mins to 1 hr of running. then starts again on the first pull??
Most likely oil sending unit or fuel vacuum lock. Easy to check. Run with gas cap loose to allow air into tank. if it still shuts down, temporarily disconnect oil sensor. If the oil sensor is giving false reading and shutting down the engine, just leave disconnected, however, be diligent about checking oil level. Good luck.
Feb 02, 2016 | Coleman Electrical Supplies
It is not a problem like to know if i can use my coleman 5000 maxa er plus 10 hp. With A welder with out damage it. Tanks
Yes, you can use a welder with it. Pay attention to the ratings of the welder, don't exceed running watts of the generator. It would also be a good idea to try and use a welder that is less than the running watts rating of the generator. Then you would have some extra capacity to deal with fuel quality, maintenance history, momentary undervoltage, altitude, etc.
Jun 20, 2010 | Coleman Powermate Powermate 5000W...
Coleman Powermate generator will not start.
Changed plug since last year?Choke adjustment? try premium gas?
Aug 13, 2009 | Electrical Supplies
Backfire problems
If your genset is back firing then it could be carberator, bad ingnition coil, fuel pump, poor compression, which should be at least 100 psi.
May 05, 2009 | Coleman Powermate Powermate 5000W...
Powermate 5000 leaks gas from the air filter..not sure how it's getting into the air filter?
My Coleman Generator 5000w with a Tecumseh 10hp story. Mine engine finally did die before I pulled the carburator off.
On mine the float was defective. It was full of fuel! I repaired the hole in it. I removed the air filter and saw fuel pouring out the side so much that I had a jar to catch it. I removed the carburator and took the nut off the bowl to examine the float. Then I removed the pin holding the hinged end of the float. Carefully pulled it out with the needle valve attached. When I removed the needle valve (just slides on mine) it was free to test. I tested by shaking it near my ear and I could hear the fuel inside the float. Mine was brass or copper. I wiped mine off with a napkin and finally found the hole. I drained the fuel by polking a needle sized hole and removed the fuel. I then soldered the hole shut with using just electronic 60/40 resin solder and a small soldering iron. Mine works like a champ now.
Mar 08, 2009 | Coleman Powermate Powermate 5000W...
Briggs & Stratton Briggs and Stratton 030451 5000 Watt Portable Gasoline Generator Logo
527 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
